SDTW Custom Wheels & Tires
Old 06-08-2012, 11:07 PM   #1
tjk_art
Drives: 2010
Is my Aux cord the center of my problems?
My problem is static through my speakers.. but only when I listen to music off of my iPhone? So.. it's either go to be the aux cord, or the quality of the music I have, right?
I bought a $10-$20 aux cord awhile back from best buy to listen to music off my iPhone . I normally keep my iPhone in the cup holder and have the center console close on the aux cord. After two years, maybe that has gotten to it?
Can anyone recommend a good aux cord?
tjk_art is offline   Reply With Quote
Old 06-08-2012, 11:16 PM   #2
joshuah57
joshuah57's Avatar
Drives: 2012 Camaro SS2 45th Ann. Ed.
Check out www.monoprice.com. Their cables are good quality at a great price. I order almost all my cables from them.
joshuah57 is offline   Reply With Quote
Old 06-08-2012, 11:18 PM   #3
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
If you are going thru the aux port and getting static/noise, a noise filter will typically remedy it. It could also be the cable if you weren't previously experiencing this. You'll find a link to the filter I was referring to.
http://www.crutchfield.com/I-rCHVc11...se-Filter.html
CrutchfieldBrooke is offline   Reply With Quote
Old 06-08-2012, 11:19 PM   #4
Wantconvertible
Wantconvertible's Avatar
Drives: 2011 SS/RS VERT
I have a apple cord and it does it from time to time ,i pull it out then install it again ,it works for a while before it happens again
Wantconvertible is offline   Reply With Quote
Old 06-09-2012, 12:35 AM   #5
SS Drifter
Drives: 2010 2SS/RS L99
Your best off to use the iPhone through USB. In most cases the head unit will have a better A/D converter than a smart phone. (Well, maybe not with the GM stock head unit.)
I've tried various combination of cable and filters using AUX input with both the iPhone and iPad. Using a filter helped with the noise but the frequency response suffered. My theory is that the noise is generated from a ground loop issue rather than a problem with the mobile device or head unit.
Try using using USB rather than an analog input. This way the A/D conversion takes place in the head unit, not the in the mobile device. You can also try bootooth (that's not a typo) but the bandwidth stinks and it's unreliable for the most part.
SS Drifter is offline   Reply With Quote
Old 06-09-2012, 01:33 AM   #6
KidKilowatt
KidKilowatt's Avatar
Drives: 2011 Camaro 2LT RS
Every once in a while I have to replace my usb cord because of static. Especially the cheap apple ones.
2011 LLT RS Black on Black Loaded. [x]Showstopper 45th Anniversary inspired Camaro RS Stripes, [x] MPD1 Spoiler, [x] GM Heritage Grille. [x] Removed RS and Bowtie Emblems. [x] 30% Tinted Headlight Armour DRL's. [X ] Ruff Racing R954 Wheels [X] Solo Cat Back Mach X-LLT Exhaust [X ] Vmax Ported throttle body [x] Halo SC Reverse Hood Kit [x] Showstopper Painted, Modded Engine Cover [x] Cold Air Inductions CAI [x] Tinted Tails and Black Bezels [x] Megan Racing Street Series Coilovers [x] Belltech F&R Sways
Check out my build thread!
http://camaro5.com/forums/showthread.php?t=212178
KidKilowatt is offline   Reply With Quote
Old 06-09-2012, 09:06 AM   #7
CrutchfieldBrooke
Bootooth? Haha. I like that.
