Solo Performance
Old 06-09-2012, 06:47 PM   #1
5thGen2LT
Drives: 2012 2LT 45th Anniversary
Looks like K&N are finally on board!
So, in my random (ok, more like methodical) checking of K&N's website...I spotted a brand new, never before offered product: Cold Air Intake kit for 2012 LFX V-6's. The product code is 69-4523TP. Right now it is only offered in the polished aluminum, but still.....finally!! Thank you K&N!!
5thGen2LT is offline   Reply With Quote
Old 06-09-2012, 07:50 PM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Very cool, not to be a downer but I hope they dont have issues like on the 2010's-11's model
Lil' Nasty is offline   Reply With Quote
Old 06-10-2012, 04:16 PM   #3
5thGen2LT
What issues did K&N have with the '10 and '11's? I know there was a redesign for the MAF sensor and/or thermostat housing on radiator...anything else?
Old 06-10-2012, 06:33 PM   #4
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
K&N cold air intakes on the LLT were throwing Check Engine lights for awhile until they figured out how to fix it. Honestly, I would never consider a K&N intake. Buying a brand name and that's it.
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 06-10-2012, 10:52 PM   #5
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
Thats too bad I have had good luck with their products. Ok found it:
http://www.knfilters.com/search/prod...Prod=69-4523TP
15hp/11 ft lbs torque, estimated (?) then it shows dyno graphs to back it up, that sounds almost too good to be true?
Looks cheap compared to a couple of the others, also no sign of CARB exemption which is a no go here. Ill wait n see.
Henry G. is offline   Reply With Quote
Old 06-10-2012, 11:23 PM   #6
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Looks cheap to me, too. CAI's is only $75 more and it's top of the line stuff.
This K and N setup appears to be a solid piece of aluminum from the filter to the bend before the throttle body connection. I'll bet heat soak would be a big issue.
The air dam doesn't appear to seal all that well, and it looks to be just plastic of some kind.
And I'm willing to bet their dyno measurements are done "hood-up."
Jus' sayin'.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 06-11-2012, 12:14 PM   #7
5thGen2LT
Ok, maybe this thread has already been started, but: What have you guys found to be the best all around cold air intake? CAI? Injen? BBK? Roto-Fab? Airaid? I'm just doing a little research before i take the plunge! Thanks!
Old 06-11-2012, 12:47 PM   #8
meissen
meissen's Avatar
Really it's whatever YOU want to go with. I went with Cold Air Inductions and couldn't be happier. Others went with Rotofab, others are holding out for Vararam.
Old 06-11-2012, 01:19 PM   #9
Les7311
Les7311's Avatar
Drives: 45th Anniv, 2SS, LS3, '07 M109
Send a message via Yahoo to Les7311
.....hhhhhmmmmm am looking closely at the K&N 63-3074 AIr Intake for $247.......
Les7311 is offline   Reply With Quote
Old 06-11-2012, 01:51 PM   #10
5thGen2LT
...only prob is: K&N website says it's for the 6.2L V8, and mine's the 3.6 V6...
Old 06-11-2012, 01:54 PM   #11
Les7311
Les7311's Avatar
http://www.nextag.com/serv/main/buye...26n+air+intake
try this website........
Old 06-11-2012, 01:59 PM   #12
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
my K&N typhoon has never given me any problems from the get go(the aircharger is what has thrown some CELs)..
Old 06-11-2012, 02:38 PM   #13
sprint17
Drives: 2012 ls
I've had a lot of k&n intakes on our cars and trucks and never had problem but with the Camaro I might try the CAI intake with the wash bottle relocator. I think most short intakes from big names are going to be around the same +\- 1 or two hp
sprint17 is offline   Reply With Quote
Old 06-11-2012, 03:06 PM   #14
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
I feel like with K&N you are paying for the name
colingordon is offline   Reply With Quote
