Old 05-15-2009, 06:47 PM   #1
Fogey
Fogey's Avatar
Drives: 2011 2SS/RS A6, IOM
Nits and Lice
If one orders the full sized spare tire option, where does it fit?
Is the tire sealant and inflator a reasonable option to a spare either full sized or space saver?
What is the Black roof ditch?
"Hood blanket with debossed Chevy Bowtie? What is a hood blanket?
What is the tire pressure monitoring system?
Thanks
Fogey is offline   Reply With Quote
Old 05-15-2009, 06:51 PM   #2
MerlinZero
Big Orange
MerlinZero's Avatar
Drives: 2010 Chevrolet Camaro 2SS/RS
the full size spare i do not believe IS an option... and yes unless you have a complete tire blowout you should be just fine.
the black roof ditch molding is the black molding on the sides of the roof that help shed water
I have no idea what the hood blanket is
and the monitoring system is a system within the cars computer that actively monitors the tires presure it will display this in the display on the dash... it will alarm if any tire drops 10psi below the others.
" First, there was darkness, Then, On March 16th, Scott said LET THERE BE CAMARO, and there was Camaro, and Scott saw that it was good. Camaro5 3:16"
VIN: 2G1FT1EWXA9120523
ETA 7/6/09 (Delivered 7/10/09)
MerlinZero is offline   Reply With Quote
Old 05-15-2009, 06:58 PM   #3
Fogey
Fogey's Avatar
Thanks for the info
I was afraid the tire pressure monitoring system was this option on the Chevy Camaro build your own site that are valve stem covers with a little area in the caps that goes red or green depending on pressure-fairly Mickey Mouse.
On my contract it says" Hood blanket with debossed Chevy Bowtie". That's where that came from. Also, a full sized spare is an option. I imagine it fits in the floor of the trunk.
Thanks again
Old 05-15-2009, 06:58 PM   #4
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
Originally Posted by Phenix View Post
No, the roof ditch is not the reverse mohawk. It is the seam at the outer (left and right) edges of the roof, where it meets the A to C pillar arch. Check out the pics in the official color galleries to see the difference between RS color matched vs black on non-RS cars.
EDIT:
RS (body colored roof ditch)
No RS (black roof ditch)
Old 05-15-2009, 07:11 PM   #5
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
The hood blanket is the material on the underside of the hood. It is a sound insulator. It has the Chevy bowtie embossed into it. It is visible in many photos on the site
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 05-15-2009, 08:30 PM   #6
nonsensez9
Drives: 05 mustang gt
if you want a full size spare, would you make it a full size front spare, or rear?
nonsensez9 is offline   Reply With Quote
Old 05-16-2009, 12:35 AM   #7
prostreet67
prostreet67's Avatar
Drives: 67 prostreet
I would say get one of each but they both wont fit in the trunk. flip a coin
2LT/RS-RJT, auto, sunroof,
polished wheels, spare.
order placed 3/13
3000 5/27
brought home 7/30
prostreet67 is offline   Reply With Quote
Old 05-16-2009, 12:49 AM   #8
Teleplayer
Drives: 92 Bonnie SSEI - 2010 GT Soon
That's why the 19" is a better deal, all four are the same I think. And I would get the spare if I got the V6, there are a lot of cases when the tire sealant thing is not going to work.
1992 SSEI Supercharged 177k miles. 2010 GT coming soon.
Teleplayer is offline   Reply With Quote
Old 05-16-2009, 01:50 AM   #9
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
tire sealer/inflator is good enough for me.....livin on the edge!
GMtothecore is offline   Reply With Quote
Old 05-16-2009, 02:58 AM   #10
racert33
waiting for white
racert33's Avatar
Drives: vertically challenged 95 c/k
is there a reason they all dont have body color ditch molding?
racert33 is offline   Reply With Quote
Old 05-16-2009, 08:01 AM   #11
chevy dude
chevy dude's Avatar
Drives: 2010 1LT/RS IBM Camaro
If i'm not mistaken?The full size spare is only available on non-SS models,even with the 20" wheel option.The Brembos won't accomidate the spare tire.I have a 1Lt/RS with the full spare and i ordered the 20" polished wheels.The spare will come in handy if i get a blow-out,not so much if i only had the sealant
Camaro nut!!!
chevy dude is offline   Reply With Quote
Old 05-16-2009, 09:34 AM   #12
dougmac
Drives: 2011 V6 MCA & 1969 GT Mustang
The spare tire option IS NOT A "FULL SIZE" spare, it is your typical "temporary" mini doughnut type.
Also to clear the V6 brakes, it has got to be at least a 17" size rim, so it is not as "MINI" as on other cars.
One concern for V6 "Manual Transmission" buyers ...
Hopefully o/a spare dia. is close to std. tire dia. (28.6") other wise putting it on back you will be putting excesive wear on the LSD clutch pack. To avoid this, you could put the spare up front 1st then swap the good front to the back.
Doug
dougmac is offline   Reply With Quote
