SDTW Custom Wheels & Tires
Old 06-11-2012, 01:34 PM   #1
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
Pheonix gold amp power issue
Hi guys I tried to search all over but couldn't find solution for this. I have a pioneer x930bt, the scosche gm5201b and the pheonix gold amp/sub kit. Everything sounds fine but when I move the power seat, the amp seems to cut off the power. I checked all the harness and wire it seems to be correct. Any clue?
wabibito is offline   Reply With Quote
Old 06-11-2012, 09:42 PM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Could you post the wattage specs for your amp? I don't wanna look all that stuff up on my phone. I also don't see any reason this should go unresolved.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-11-2012, 09:48 PM   #3
thahemp
Geek
thahemp's Avatar
I don't know what the stock alternator is capable of, but 90 amps is 1080 watts at 12V. If you're flirting with that edge you could have a voltage sag when you run the electric motor for the seat.
x = ~x
Old 06-11-2012, 10:03 PM   #4
thahemp
Geek
thahemp's Avatar
Nah. Something isn't right. You aren't pulling that much power. You have a defect somewhere. I need more information.
x = ~x
Old 06-12-2012, 07:56 AM   #5
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
There is a known issue with that, i had the same problem and went back to where i had it installed and they contacted Phoenix Gold and there is a wire that has to be cut on the remote cable where it plugs into the amp. If u call Phoenix Gold they can probably email u the picture and directions of what u need to do to fix it.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 06-12-2012, 12:32 PM   #6
wabibito
wabibito's Avatar
Drives: 2013 2SS RS
Thank you! I was able to locate the tech doc on their site to see which cable to take out. Will give it a try.
Thanks again.
