Jason 98 TA
Old 05-15-2009, 09:50 PM   #1
restodaveny
Drives: 1972 Chevy Camero
LS3 spark plugs
Does anyone know where the plugs are on the LS3? i had to change the plugs on my 98 camaro and just remembered how much of a pain in the butt it was
restodaveny is offline   Reply With Quote
Old 05-15-2009, 10:00 PM   #2
camaro67
Drives: marina blue 67
duh
camaro67 is offline   Reply With Quote
Old 05-15-2009, 10:07 PM   #3
Lovestanda
Large Member
Lovestanda's Avatar
Drives: Yugo SS
Lovestanda is offline   Reply With Quote
Old 05-15-2009, 10:17 PM   #4
restodaveny
Originally Posted by Lovestanda View Post
ok let me clarify I do not own any modern cars i have a 72 camaro and a 98 so i dont know how well designed the LS3 is, my brother has a acura and it takes him 10 mins to change plugs because his car is designed well so I want to know if GM pulled there head out of there ass and designed a better car or is this camaro repackaged shit. All the pics i find are top down views with engine covers on so its a simple question.
Old 05-15-2009, 10:33 PM   #5
Lovestanda
Large Member
Lovestanda's Avatar
Drives: Yugo SS
Sorry, the engines all have covers. I'd remove the cover and follow the sparkplug wires till you find the plugs.
Old 05-15-2009, 10:44 PM   #6
restodaveny
guess that means no one knows
Old 05-15-2009, 11:22 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
very similar to an LS1, however there is a lot more room between the engine and the fender wells on this car
I piss excellence
and fart awesomeness
Old 05-16-2009, 07:24 AM   #8
camaro67
follow the yellow brick road plug wires.why worry you wont need them for a long time.gas cap on your pass. side.
Old 05-18-2009, 12:36 PM   #9
LDGn63
LDGn63's Avatar
Drives: WNABEE
looking at mine it appears it may be the easiest chevy plugs i've ever changed.
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Pulstar Spark Plugs hollywoodGU Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 08-26-2015 10:14 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Nitrous oxide and Challengers Superman09 General Automotive + Other Cars Discussion 16 01-29-2009 09:14 PM
