Rick@Livernois
Old 06-11-2012, 08:30 PM   #1
heemoo
Drives: 2011 CAMARO RS
Unhappy Tire Pressure Monitoring System cant be reset
when i started to reset tire Pressure Monitoring System i suppose to hear the horn when i inflate the tires. the first tire and the second tire goes well but the third one goes wrong i cant hear the horn.
heemoo is offline   Reply With Quote
Old 06-11-2012, 08:36 PM   #2
warren3537
warren3537's Avatar
Drives: 2010 Camaro 1LT Plus Victory Red
Just a thought here, air up all the tires with the same psi then reset the relearn, thats what I did when I swapped out my old rims for new ones and it worked.
warren3537 is offline   Reply With Quote
Old 06-11-2012, 08:43 PM   #3
heemoo
i did what you said before the horn goes with two tires only
Old 06-11-2012, 09:01 PM   #4
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2010 2SS/L99) (1999 Corvette)
Bad sensor.
"If it's too loud...well, you know the rest."
kmcd is offline   Reply With Quote
Old 06-11-2012, 09:09 PM   #5
heemoo
Old 06-11-2012, 10:08 PM   #6
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Keep trying, it took me 4 tries the other day.
Try letting the air out as well.
stratman2SSRS is offline   Reply With Quote
Old 06-15-2012, 04:34 PM   #7
heemoo
i did it 5 times i think the sensor is not working.
Old 06-15-2012, 04:52 PM   #8
SSTG
SSTG's Avatar
Drives: 2014 Z51 Corvette
Sounds like a bad sensor to me. Take it to a shop, they can confirm.
SSTG is offline   Reply With Quote
