BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 06-11-2012, 09:53 PM   #1
RagtopCamaro69
Drives: 1969 I6 Convertible Camaro
How to verify numbers matching engine
I just bought a 1969 Camaro convertible. It has an I6 engine. I want to see if it is the original engine. How can I check to see? Thanks
RagtopCamaro69 is offline   Reply With Quote
Old 06-12-2012, 01:23 AM   #2
speedmon
Drives: C6 Z06
How many miles on the car?
Those are rare....they made 2 6cyl versions. 140hp and the beefed up 155hp.
They are rare because most have been used to duplicate the more valuable V8s.
I actually don't know if they stamped the 6s like the V8s, but there would be a pad on the engine block with two sets of numbers.....one set, a smaller font would have your VIN embedded in it then the other set in a larger font is an assembly date stamp.
What kind of transmission? Is it 3 on the tree....I've seen those before...they are funny.
speedmon is offline   Reply With Quote
Old 06-12-2012, 07:56 AM   #3
AintQik
Drives: 67 Pro-Tourer, 12 SS
http://www.camaros.org/
Lots to read.
AintQik is offline   Reply With Quote
Old 06-12-2012, 10:25 AM   #4
SC2150
Good link AintQik!!
Pull the valve cover off to look at the casting date codes on the head, block has it all as well.
Old 06-12-2012, 12:14 PM   #5
speedmon
Drives: C6 Z06
Here's the link within the site that gives you the pad location on the 6s where your VIN could be stamped.
http://www.camaros.org/drivetrain.shtml#PadStamps
I've never even bother to look at those.....people totally ignore those cars.
If your was damaged by fire, its a good opportunity to convert to a V8...Carbed V8s are cheap, probably cost less than to retore the 6.
You'll enjoy it more when its done and it'll be worth more.
