Jason 98 TA
Old 06-12-2012, 07:29 AM   #1
JackRabitSlims
Drives: 2010 Camaro 2SS RS LS3
Leaking Oil
My 2010 Camaro SS LS3 is leaking oil. It is not from the drain plug or the filter. Any ideas? Thanks for the help.
JackRabitSlims is offline   Reply With Quote
Old 06-12-2012, 09:27 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
Yep. It will be any or all of the following:
1) Oil Cooler
2) Oil Pan Gasket
3) Rear Main Seal
Prepare for 2-5 days of your car being parked at the dealer. There are many threads on these cars leaking. A quick search will provide you with the details.
TheHorse13 is offline   Reply With Quote
Old 06-12-2012, 10:01 AM   #3
Russell James
Russell James's Avatar
Drives: Camaros
Have your dealer wipe it off and put dye in it. After a short drive they will be able to tell the root cause leak by the dye and black light. The oil cooler would be highly suspicious, especially if dripping off the bottom of the cooler. The wind can blow it around and make it look like many other things are also leaking.
I had a '10 that looked like the pan, r seal, and cooler was leaking.... actually it was just the cooler. And just replacing the seals won't fix it, often needs the whole cooler. I found that out on my third trip in.
Old 06-12-2012, 11:12 AM   #4
TheHorse13
TheHorse13's Avatar
Originally Posted by Russell James View Post
...And just replacing the seals won't fix it, often needs the whole cooler. I found that out on my third trip in.
This.
The problem is that most dealers will tell you that they have a process outlined by GM tech and they must do the o-ring and seals first. Consider that your wasted trip because they will start leaking again soon after.
Old 06-12-2012, 11:41 AM   #5
JackRabitSlims
Thank you
Old 06-12-2012, 11:41 AM   #6
Kiss My SS
Drives: 2012 Camaro 1SS/RS
In 1997 I bought a new Camaro SS, after 2500 miles it developed a rear main leak, I refused to let the dealer remove the engine to replace the seal because we all know the car would have never been the same, I went round and round with GM and they finally sent me $2,500 and told me to trade it on a new SS, I did. After about 3,000 miles on the 2nd one it did the same thing. I immediately took the 2nd SS and traded it for a Cobra Mustang. Problem solved. I did find out afterwards that GM was having problems with whatever they use as glue or whatever when they were installing the rear main seals in these SS's and it was a problem on thousands of camaro SS's, I havent owned a Chevy since until I bought this 2012 SS, only 700 miles, no leaks (knock on wood) but if it develops the same problem I will give this car back to GM and demand a refund.!!!!!!!!! And if your rear main is leaking you should to.
Kiss My SS is offline   Reply With Quote
Old 06-13-2012, 11:44 PM   #7
rosario
Drives: 2010 camaro
OK so i got the oil leak fixed all went well ,however the stupid person or if u want to call him a mechanic left the ac hose to close to fan belt and cut the hose what an A$$
rosario is offline   Reply With Quote
Old 06-18-2012, 06:17 AM   #8
WhiteHP
2011 Camaro 2SS/RS
WhiteHP's Avatar
Drives: 2011 Camaro 2SSRS
I just noticed a small puddle of oil in my garage. It's good to know this isn't too uncommon.
A good decision is based on knowledge not numbers-Plato
2011 Camaro 2SS/RS M6 :CAI intake/ADM scoop/Rotofab washer : Corsa CB Exhaust
2006 Suzuki GSXR 750 : Turbocharged, -1/+1, Extended Swingarm, M4 s/o exhaust, K&N filter, Bazazz with self mapper, Airbrushed paint.
WhiteHP is offline   Reply With Quote
Old 06-22-2012, 04:13 PM   #9
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
I had my oil cooler and seals replaced. About 3 months later had it up on a lift and noticed more oil leaking again. Took it back in and they replaced just the oil cooler seal this time. Mechanic also put dye in the oil. I am taking it back in on Monday so he can check again for leaks. Hopefully it is solved, but we will see.
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
BigBlue2010 is offline   Reply With Quote
Old 06-25-2012, 10:18 AM   #10
Chevrolet Customer Svc
Drives: GM Vehicles
I apologize for any inconveniences that you may be experiencing with this issue. If you could please let me know how service goes, I will be able to take note of it and enter it into our database where several departments of GM can access the information.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 06-26-2012, 07:18 PM   #11
BigBlue2010
Brandon
Dealer said everything looked good and there were no leaks. I understand this was a problem on early Camaros, and as long as they fix it I am not mad about it. Hopefully this is really the last fix for it though. Thanks for the response! OP, sorry to thread jack.
Old 06-26-2012, 08:04 PM   #12
5150 Maro
5150 Maro's Avatar
Drives: 2012 SS 45th Anniversary
My rear seal went out on my 2010 SS last year at 6,000 miles. Fixed it and no more problems
5150 Maro is offline   Reply With Quote
Old 06-30-2012, 06:11 AM   #13
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
I found oil on the garage again. Took the car to a local dealer and I looked under the engine. All seals looked dry but noticed oil coming from the hollow frame support below the engine. I'm hoping it was just the oil that was trapped in there after the pan was dropped. I'll keep everyone posted.
George
george is offline   Reply With Quote
Old 06-30-2012, 06:14 AM   #14
george
ZL1 Driver
george's Avatar
Brandon/Chevy customer support:
My warranty is up in January. This was my 4th trip to the dealer because of this issue. If it really is leaking, what then? Regards
