Flowmaster Exhaust
Old 06-12-2012, 08:41 PM   #1
dxy2jbaby
Drives: Summit White Camaro
Question Help , Which wire do i cut to get rid of center speaker??
So I popped my trunk , pulled the carpet from the left side corner. I see 2 different yellow wires, you can notice it in the picture. Do I cut both or just 1 to get rid of center speaker .
I know there is manual way to pop the center speaker , but i can't pop the lid by using a knife for some reason .
dxy2jbaby is offline   Reply With Quote
Old 06-12-2012, 10:38 PM   #2
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
just get a microfiber towel and a flathead screwdriver, pop up the cover covering the center speaker and unplug the speaker. I would go cutting anything. Just my .02
Chad's ZL1 is offline   Reply With Quote
Old 06-13-2012, 12:47 AM   #3
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Just like the previous poster said. They might hard to pop out but they will. Then there are 3 or 4 7 mm screws that you take out to get to the speaker connector
Caddy
Caddyroger is offline   Reply With Quote
Old 06-13-2012, 01:05 AM   #4
dxy2jbaby
i got it !!! Pop that thing open was pretty hard, to get 2 screws off was pain in the butt took me forever . But in the end i'm really happy with the result
Old 06-13-2012, 02:26 AM   #5
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
Does it sound better or something? If so, why?
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 06-13-2012, 08:48 AM   #6
MrGood
MrGood's Avatar
Drives: Broken palmghetto test car
Send a message via Yahoo to MrGood
IMO it doesn't sound better in any way. I tried this two days ago. Don't cut anything or you will regret it. Pry it open with your fingers then get you a
Wratchet or a wrench I believe it's an 11 but I cannot remember remove the cover then two bolts and unplug it. It takes 2 mins at the longest. Then when you decide you like it better with it you can plug it back in. Or say you go to sell it and you can plug it back in instead of explaining why the speaker doesn't work. Much easier than fixing the wire.
MrGood is offline   Reply With Quote
Old 06-13-2012, 09:24 AM   #7
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
I disagree, I replaced the stock amp with a JL Audio and in the process lost the center speaker and couldn't be happier with it.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
