Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 06-13-2012, 07:09 PM   #1
camaro104
camaro104's Avatar
Drives: 2010 CGM Camaro
Send a message via AIM to camaro104
Single din radio install.....
Got bord so i had an extra radio laying aroun so i decited to come up with a single din radio with the original face plate, This is what i came up with.....
camaro104 is offline   Reply With Quote
Old 06-13-2012, 07:38 PM   #2
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
so does the screen just slide into the headunit? and more importantely, will it work?
Stieger's BLACK Build Thread thanks for the sig Russ
Old 06-13-2012, 11:13 PM   #3
Alfieboy
Madman
Alfieboy's Avatar
Drives: Black 2010 2SS 6sp man w/IOM stripe
its a retractable screen that goes back into head unit.. now if it works..that I dunno..
Alfieboy is offline   Reply With Quote
Old 06-13-2012, 11:18 PM   #4
The Stig
The Stig's Avatar
If it works, can I buy it?
Old 06-13-2012, 11:20 PM   #5
LandonB
LandonB's Avatar
Drives: 2011 Camaro LS M6
I'd buy one too
LandonB is offline   Reply With Quote
Old 06-14-2012, 02:37 AM   #6
Wuiquen
Wuiquen's Avatar
Drives: 2011 Summit White 2LT/RS
how did you cut the glass part? also what are you using to support the radio in place. This is actually a pretty smart idea.. congrats in this.. the only issue would be that unless you have strong support for the radio, it would make noises..
Wuiquen is offline   Reply With Quote
Old 06-14-2012, 03:46 PM   #7
camaro104
camaro104's Avatar
Why wouldn't it work? The circuit board is not touch, All I cut into was plastic so all the knobs and switches are going to work. I cut the glass with a dremel cutting tool. The metel radio frame is nice a solid so it's not going anywhere. Now this is a radio i had laying around im sure it would look better with a different (nicer) head unit..... I install the Alpine system on my car and I wish I came up with this sooner.....
Old 06-14-2012, 03:55 PM   #8
The Stig
The Stig's Avatar
so does the single din screen display what was on the little OEM screen?
Old 06-15-2012, 07:14 AM   #9
black12lt
Drives: black 1lt 2012
I remember when these were first out, a deal was 800 bucks. Double din came and made them prehistoric. However, as a few others mentioned, if it works, ill entertain the option
black12lt is offline   Reply With Quote
Old 06-15-2012, 11:52 PM   #10
jeffa
Drives: 2012 1LT Victory Red
If I am not mistaken, you are going to need an interface module to connect the aftermarket radio to the factory radio harness. The turn on signal for the radio is a digital signal, and needs to be converted into a 12 volt signal that the radio can use to turn on and off.
jeffa is offline   Reply With Quote
