Emblempros
Old 06-13-2012, 08:38 PM   #1
crashprime
Drives: 2010 Camaro 1SS IOM M6
Base 6-speaker locations?
What is the location/count of the basic 6-speaker setup on the Camaro LS/1LT/1SS?
Are all of those speakers replaced with different Boston Acoustics speakers when upgrading to the premium sound, or are some of the speakers in the base sound system still included?
Who designed the speakers in the base sound package?
I am having a hard time finding out if the speakers are shared across the two packages, or if the 9-speaker setup has an entirely different lineup.
crashprime is offline   Reply With Quote
Old 06-13-2012, 08:46 PM   #2
Blue17CamaroZL1
650HP soon to come
Blue17CamaroZL1's Avatar
Drives: 2017 Chevy Camaro ZL1
6 speaker set up in the base system is as goes, i believe:
drivers door 6.5"
drivers door tweeter
passenger door 6.5"
passenger door tweeter
driver side rear deck 6x9"
passenger side rear deck 6x9"
The 9 speaker Boston Accoustic system goes as is:
drivers door 6.5"
passenger door 6.5"
front dash center channel
driver side rear deck 6x9" tweeter
passenger side rear deck 6x9" tweeter
I also believe the base system is not BA and entirely different.
2017 Camaro ZL1
Hyper Blue Metallic
A10, PDR, NAV, Premium floor mats
Blue17CamaroZL1 is offline   Reply With Quote
Old 06-14-2012, 10:11 AM   #3
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
Although some of the speaker locations and sizes are shared between the two systems, they are setup completely different because of the amp in the Boston system. Although I'm not sure who makes the speakers for the base system in the Camaro, those speakers aren't the same quality.
CrutchfieldBrooke is offline   Reply With Quote
Old 06-21-2012, 12:04 AM   #4
crashprime
When I go to crutchfield, and type in my car, it shows me options for 6.5's for the doors, and 6x9's for the rear deck. It doesn't list anything for the door tweeters tho. What size am I looking for to replace them? It looks like on crutchfield, many of the speakers include the tweeter .. I guess that must be pretty standard?
I have heard bad things about the BA setup, and ended up not prioritizing it when looking for my car, thus ended up with just the base setup.
I am sure I can integrate an amplifier with the stock head unit, and get a pretty decent sounding system without worrying about adding a subwoofer for now, but if I am going that direction, I want to make sure I get all the speakers matched and swapped out.
Old 06-21-2012, 10:18 AM   #5
CrutchfieldBrooke
Yes, it is standard for our system not to filter for tweeters in most cars since they don't have an exact aftermarket replacement size or mounting provisions. It doesn't mean you can't fit tweeters in the original location though, it just requires a bit of extra work to get them mounted.
If you are going to replace the tweeter, then I'd go ahead and get a component system that comes with the separate tweeter and crossover. This will give you a good sound stage up front in the car.
