Vivid Superchips
Old 06-14-2012, 07:54 AM   #1
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
check engine light after K&N filter install?
I installed the filter at 1,200miles and at 1,400 miles the check engine light came on. I did not abuse the car (yet). I called Onstar and was told that it's the oxigen sensor on the right side exhaust signaling emission problems. I think there's a high chance they're related, as the events are too close... I also bought gas from Shell for the first time and I'm at half a tank...who knows.
Did you experience this and what was the fix, other than throwing out the KN filter? Will resetting/recalibrating the cumputer at the dealer work?
Thanks
Mr.R is offline   Reply With Quote
Old 06-14-2012, 08:00 AM   #2
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
If its an O2 sensor that is acting up I can't imagine it was caused by the K&N filter. Have your tried reinstalling the OEM filter to see if that clears the code?
Stieger's BLACK Build Thread thanks for the sig Russ
Old 06-14-2012, 09:06 PM   #3
16floz470ml
16floz470ml's Avatar
Drives: 2012 ZL1 GLJ MG9 WBP RTQ
You need to look at your fuel trims and o2 sensor readings on a scanner. If the filter throws the fuel trims off really far it could throw an o2 sensor code. On stock car long term trim should be around -1 on both banks. If you are + the car is seeing a lean condition and adding fuel. The front o2 sensor readings should switch like crazy and the rears should stay right around 500mv.
16floz470ml is offline   Reply With Quote
Old 06-14-2012, 09:52 PM   #4
Mr.R
Mr.R's Avatar
Thanks! They mentioned it was the front right O2 sensor.
Great news! It went away by itself. I Pushed it a bit today and who knows what happened. It was on in the morning and off in the afternoon. So I'm happy, plus I hit 1,500 miles!!! I can tell it runs better, smoother. I can also sense a bit more power, especially when I open up the exhaust all the time. It unbelievable what a difference an open exhaust and an air filter can do...
thanks again
Old 06-17-2012, 05:18 PM   #5
AMCBimmer
Drives: 2002 BMW M5
Even though the light went out the fault is still there. I work for a dealership and our manufacturer light comes and goes.
AMCBimmer is offline   Reply With Quote
Old 06-17-2012, 05:38 PM   #6
Mr.R
Mr.R's Avatar
so are you saying there's still a problem then? I'm scheduled for an oil change next week adn I can ask them to check the code...
thanks
Old 06-17-2012, 05:47 PM   #7
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
thanks
Your ECM will set 'hard' and 'soft' codes. A hard code remains logged even if the CEL goes out. Anything to do with emissions will set a hard code. You should definitely have them check it and see if any other codes were set.
RoketRdr is offline   Reply With Quote
Old 06-17-2012, 05:51 PM   #8
Mr.R
Mr.R's Avatar
Thanks!!
Old 06-17-2012, 11:18 PM   #9
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
I have not had any lights. i also have a Code Reader to check for codes and I have no codes and I also have a program on computer to monitor the engine and no codes or issues with my program also.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 06-22-2012, 06:06 PM   #10
AMCBimmer
Drives: 2002 BMW M5
Interesting! Keep us updated!
Old 06-24-2012, 09:46 PM   #11
Mr.R
Mr.R's Avatar
The check engine went out after 100 miles. I guess the computer adapted to it. Dealer checked the code Friday and said not to worry. You might get that with bad gasoline too. All I can say is that the throttle response is a bit quicker, someone said it gained 5hp on the dyno and I can hear the supercharger whine a bit more. It's worth it!
I will however get a CAI that doesn't need a tune. The engine bay looks so much better and I'll probably get 20HP more and a lot better exhaust/intake sound. I love that music so much I drive with my windows down and radio off.
