BeckyD @ James Martin Chevy
Old 06-14-2012, 01:34 PM   #1
altair
Drives: white 2012 camaro LS, stick shift
Exclamation Exhaust and clutch help!!
maaaan do i need help! i just bought a brand new 2012 camaro LS stick shift and i have no idea what to do! i was wondering if you guys could help me find an exhaust thats pretty cheap (less than 500) and sounds like a muscle car should! i live in LA, cali so if you could refer me to someone who could install it, i will appreciate that very much!
also somethings wrong with the tranny or gearbox idk? every time i drop it into second gear it feel likes i get 3 clicks, and when im just driving the stick is rumbling. so far i havent burnt the clutch enough to smell it but it is worrying me that i have to be extra careful when i change to second gear.
thanks in advance!
altair is offline   Reply With Quote
Old 06-14-2012, 01:40 PM   #2
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
thanks in advance!
First one- MRT 2.0 google it! Second one- dealer warranty... Good Luck and Welcome to Camaro5!
Monchy36 is offline   Reply With Quote
Old 06-14-2012, 01:43 PM   #3
sikkone
Drives: 2012 camaro ls
I had the same problem with my car ur just breaking in the clutch it should be fine.
sikkone is offline   Reply With Quote
Old 06-14-2012, 01:45 PM   #4
THE1chopper
Drives: 2010 Camaro 2SS
no exhaust sounds better that NO MUFFLERS... CUT THEM OFF!!!!
THE1chopper is offline   Reply With Quote
Old 06-14-2012, 01:46 PM   #5
jmontalvo
jmontalvo's Avatar
Drives: 2011 Rally Yellow 2LS
You should go with magnaflow mufflers. Axlebacks tend to be a little on the pricey side. I got a magna flow resonated x pipe + 2 magna flow mufflers + 2 4" tips installed for $360 out the door but my uncle was able to get me the cheaper price.
|Trifecta Tune|Custom Magnaflow Exhaust|Cold Air Inductions C.A.I.|BBK LTs w/ HFC|Anvil Rear Notch Glossy CF Spoiler|Body Color Heritage Grille|10 spoke polished ZL1 replica wheels|VMAX ported TB|RS Headlights|Night Owl RGB Halos
jmontalvo is offline   Reply With Quote
Old 06-14-2012, 01:56 PM   #6
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I doubt non-nephews would get nearly as good a price.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint
PalmerGA is offline   Reply With Quote
Old 06-14-2012, 01:57 PM   #7
PalmerGA
PalmerGA's Avatar
Old 06-14-2012, 02:24 PM   #8
altair
isnt that illegal? i mean if i wont get caught sure but would that be more expensive than just getting an exhaust?
Old 06-14-2012, 02:33 PM   #9
colingordon
Her Name is Mila
colingordon's Avatar
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS
MRT v1
look here for exhausts
http://camaro5.com/forums/showthread.php?t=222713
colingordon is offline   Reply With Quote
Old 06-14-2012, 02:51 PM   #10
bluecam805
Team LFX
Drives: 2012 Camaro LS
i got the exact same. and sounds great! i have a cat-delete though, im sure itll be just as loud. get this and open your pipes to 2.5 inch. dont get 'muffler delete' as the other guy mentioned. they sound good but u loose power off the top end
bluecam805 is offline   Reply With Quote
Old 06-14-2012, 03:15 PM   #11
SoCalThug
Drives: 2012 Summit White 1Ls
thanks in advance!
Get used to the sounds the clutch makes because its not going away. It seems our manuel trannys make those sounds. I know it feels and sounds horrible but there are ways to prevent it. When in 1st gear, always shift into 2nd gear at 2k rpm's or higher. I also learned when your driving slow (in traffic for example) and need to be in first gear, I noticed that if you give it a little gas(or just keep your foot on the gas as you inched forward in traffic) and then press the clutch in, it makes the clicking noise a lot less. Plus you can hear your "Mrt 2.0 muscle car sounding exhaust" Rev up!
Try this and see if it helps out, it works for me in my 1ls. Good luck! Post some pics of your car too we want to see!!
SoCalThug is offline   Reply With Quote
Old 06-14-2012, 03:17 PM   #12
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
FASTER than my SS....for now
2500HD (with a couple parts)
Originally Posted by Coyotekiller View Post
I wonder if this could be why my car idles like its retarded...
GaBoy25 is offline   Reply With Quote
Old 06-14-2012, 03:29 PM   #13
bluecam805
Team LFX
Old 06-14-2012, 08:26 PM   #14
Magilla gorilla
Magilla gorilla's Avatar
Drives: 2012 45th Edition 2LT RS,2005 Tahoe
thanks in advance!
I went to triple AAA exhaust off of La Cinega, I ended up getting Magna Flo mufflers I went with cat back system.
They put on different type of mufflers so you could hear the difference in them and allow you to pick out the ones you want.
He put on Flowmaster's, Corsa's etc...
The MRT sounds good, you do have to order them though.
Magilla gorilla is offline   Reply With Quote
exhaust clutch ls v6 muscle
