Old 06-14-2012, 02:09 PM   #1
vicredLS
Drives: 2012 LS
Jet Power Module
Has anyone installed or know about the Jet Performance Module?It plugs directly into the factory PCM on the outside port as a piggy back device to the factory wiring harness,installs in just a few minutes.It is suppose to feed the PCM modified signals telling it to increase timing,shift points & better power gains?They have one that just came out for the 2012 V-6 engine specifically.......
vicredLS is offline   Reply With Quote
Old 06-14-2012, 02:36 PM   #2
45anni-gen5
Chevy 4 Life
45anni-gen5's Avatar
Drives: 2012 45th anniversary RS Vert
ive been waiting for this to come out...do they have any research charts showing how much gain?? id like to see that spec sheet before i buy
45anni-gen5 is offline   Reply With Quote
Old 06-14-2012, 02:46 PM   #3
vicredLS
Drives: 2012 LS
15 hp with premium fuel
Old 06-14-2012, 07:12 PM   #4
blackknight0512
blackknight0512's Avatar
Drives: 2012 Camaro L/S
I've been wondering about this too.. I hear from so many people that these do not work, but jet has been around for quite a while and a lot of reputable venders carry their products.
blackknight0512 is offline   Reply With Quote
Old 06-14-2012, 09:25 PM   #5
vicredLS
Drives: 2012 LS
Yea,alot of people get this module confused with those fake ones on ebay & such.JET is a reputable company they do alot of programing for nhra drag cars,indy cars,nascar & others.Been around a long time.
Old 06-14-2012, 09:47 PM   #6
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
I'd like to see some kind of spec sheet on this also.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
One of 82 GF Ragtops built in '15 out of 811 Total
Member of SEPA5+
theragtopguy is offline   Reply With Quote
Old 06-14-2012, 10:25 PM   #7
blackknight0512
So what dies this do to the ecu?? I'm assuming it changes the afr?? Does this act as a "mini tune"?? The dealership will be able to see this during a regular check up because it will alter the ecu?? Please correct me if I am wrong because I really am not sure..
Old 06-15-2012, 11:29 AM   #8
vicredLS
Drives: 2012 LS
Yes it does change the a/f ratio but it is only detectable if you leave it plugged in the ecm when you take it in to the dealer,simply unplug it and plug the factory harness back in its place then everything is back to normal.Its basically an external device that changes signals & info going into the computer.It doesnt alter speed limiters & rev limiters though.
Old 07-25-2012, 02:47 PM   #9
Iceyone
Iceyone's Avatar
Drives: 2012 2LT/RS
I just bought one and it arrived yesterday, I will let you know!
Iceyone is offline   Reply With Quote
Old 07-26-2012, 03:13 AM   #10
shadycamaro
Imperial Stunner
shadycamaro's Avatar
Drives: 2012 2LT/RS (IBM)
Please do!
shadycamaro is offline   Reply With Quote
Old 07-31-2012, 07:14 AM   #11
Iceyone
Iceyone's Avatar
Drives: 2012 2LT/RS
Sorry for the delay, still have not installed it yet, had to work last weekend but, I will have it installed by Friday and give an update.
Old 07-31-2012, 07:19 AM   #12
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
Damn I woulda had that thing in 3 minutes. Let us know pls.
Henry G. is offline   Reply With Quote
Old 08-01-2012, 07:05 AM   #13
Iceyone
Iceyone's Avatar
Drives: 2012 2LT/RS
I hear ya, I have to get it installed by Friday at the latest, want to test it out before I install the Injen CAI which is also due to arrive on Friday :-) I'm even trying to find a local shop here so I can get some true dyno numbers with just it installed and then with both it and the CAI installed.
Old 08-01-2012, 08:31 PM   #14
theragtopguy
Lifetime Philly Fan
Definitely let us know!!!
Phillies Baseball, Hot Dogs, Apple Pie and Chevrolet!!!!
Member of SEPA5+
