| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
needs gas money
Tuning wizards of the forum... educate me on correction factors used on typical dynos.
I finally found a semi-local shop with a Dynojet and I went down yesterday to do a few pulls and get some numbers. I chose Dynojet because I feel like I know what a stock LS3 makes on a Dynojet based on what I have seen on this forum (about 365-370). I wanted to see how much of an increase I had made. I was a bit disappointed, my best WHP number was 384 and my best Torque number was also 384, but on different runs. I had hoped to hit 400 WHP with the mods I have. The Dyno operator told me they didnt use a correction factor on theirs. Now that I look at all the dyno sheets posted on here, most seem to have SAE correction on them. How does this affect the dyno numbers? Does it make them higher or lower? I dont really know exactly what the correction entails other than ambient air temperature and barometric pressure. It was 94 degrees in the shop on my best run, I feel like that affected things a bit. I also feel like I need some more hot rod parts for my car! Can anyone guesstimate what my 384/384 numbers would have been if the dyno operator had used SAE correction on my runs? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Here's a good read from GMHT about dyno numbers. http://www.gmhightechperformance.com...wer/index.html
Basically SAE numbers are corrrected to 77 degrees STD numbers are corrected to 60 degrees And uncorrected numbers are just that uncorrected. That's why STD numbers are traditionally higher than SAE numbers. Uncorrrected numbers can be high or low depending on the weather. altitude, etc. So your numbers would be a little higher using SAE numbers and you'd most likely see a nice jump if using STD numbers in summer conditions. My best guess is you'd be in the 39x rwhp range SAE and 40x rwhp range STD.
needs gas money
hey SGOS252382, thanks for the info and a most informative link. That makes me feel better about the numbers since it was so hot in the shop at the time of the runs
There is another link within that GMHP article that will supposedly let me download the Dynojet Winpep software. I am about to go try that. If I can get the software loaded, I will then call the dyno shop and get them to e-mail me the .drf file of my dyno runs. That will give me something to play around with. Maybe I can even get it to show me some corrected numbers. Thanks again for the info and the link, now I guess I need to start looking around for camshafts... |
#4 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
Basically on a Hot day, Anything above 60 Degrees, Dry air, 29.92 Baro, your Corrected Numbers would be Higher than actual. We have seen Corrected numbers that don't add up from a couple Dyno jets where I believe that the Baro Sensor calibration is off by as much as 10%
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
needs gas money
Ted, Thanks for the info and thanks for taking a look at my tune the other day as well.
I wish I could find a place around here that sold ethanol-free gas that was consistently good. I think my car pulled 5-6 degrees of timing at high rpm even with the octane booster I added to the "good" gas I thought I was buying. I got the Dynojet software loaded, now if I could just get the shop to e-mail me the .drf file I could look at the corrected numbers. My best uncorrected numbers were 384 hp + 384 tq on a 94 degree day. I still need to make some changes to get more power though. Does anyone know how much of a HP/TQ gain I would get from LT headers vs my current JBA shorties/JBA midpipes combo? |
#6 |
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
The shorties and midpipe added very little over stock. And ive heard people getting 70 hp with just headers and a good tune
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ |
#7 |
LOL, 70 rwhp with headers and tune.....no. Hell no.
GM Performance Parts Sales, Installation, and Calibrations rhino-79@hotmail.com Kooks, EFILive, Edelbrock, Powerbond, Comp, Mast, LPE, Circle D and many more! 2010 SS L99 Cam, Bolt-ons, 3.91s, CircleD 1E 10.87 @ 124 THE Fastest NA L99 |
#8 | |
Like us on Facebook!
![]() Drives: C5 corvette/ 2012Dodge hemi Charger Join Date: Oct 2010
Dynos are great to see numbers and play a roll in tuning, but the numbers arent the best factor. Track times are the best tool. I enjoy both dyno and street tuning, but street tuning give me reading through all the gears. Dynos are one gear. If you have a very good air intake like Vararam, on the steet while scanning, you'll see it leaning out some because if the extra air your pulling in at speed. On a dyno, you can only allow for it. the good side of dyno tuning it sure saves me time from a business sense. www.TampaTuning.com Phil |
#9 | |
LS3s make on average 415 RWHP with CAI LT headers and Tune on 93 octane.
#10 |
70 hp from headers and a tune is as likely as seeing Bigfoot on your way home from work. Jannetty's numbers are more realistic.
#11 |
![]() Drives: 2010 2SS/RS Join Date: Sep 2010
I made 445/444 with LT's, Vararam, UD Pulley, Tune. Never got a baseline done, so mine might have been stronger from factory
#12 | |
The Highest LS3 with your mods ever Recorded on an Accurate Dyno was like 421 and we are skeptical at that.
#13 | |
With 445 rwhp your traps speeds would be really fast.
#14 |
Let me dig up the dyno sheet. No cam when the dyno was done...has one in it now though!
Just with VR and UD pulley + Tune I was trapping 109-110....havent gotten back to the track since though. IIRC, a E-Forced Corvette A6 with Gears and Converter made around 540 ish on same dyno, same night....could be off a little bit on the Vette's #'s though! |
#15 |
needs gas money
Well, it sounds like I need to move on over from shorties/hi-flow midpipes to the LT Headers alright. The Stainless Power LT's that JRE has on their website look like a good option for me, especially since Ted will also provide an updated tune to go along with them.
Does anyone know if the Stainless Power headers come with extensions for the oxygen sensor wires? Or maybe they dont require any because the stock wires are already long enough to reach to the new O2 bung? Some of the LT header kits I have seen photos of appear to come with wiring extensions. My JBA midpipes have the O2 bung in the same place as the stock midpipes so it wasn't an issue. |
#16 | |
#17 |
needs gas money
Well, I took the plunge and ordered some 1 7/8" LT headers from JRE this morning. They already sent me my invoice and my shipping information too. I should have the goods on Thursday. How's that for some awesome service?
If I really do pick up 28 horsepower from these headers and the new tune I will be completely stoked. If it was 5 HP it wouldn't be worth it but I think 25+ HP will be quite noticeable. I wonder how much louder these will be? I guess I will find out soon enough. Thanks go out to JRE for great service. |
#18 | |
Ted.
#19 |
If you go to Mustangdyne.com then go to performance dyno's there is a link on the bottom left that has a dyno locator and you can find a dyno closest to you
2010 Camaro 2SS/LS3
Magna Flow Street series Exhaust Airaid Intake+throttle body Custom tune by Bob Morreale www.thetuningschool.com QTP Electronic Exhaust cut-outs 12'' Alpine type R with 1500watts double ported box Tinted windows 392RWHP on Mustang Dyno #13933 |
| Thread Tools | |
