Tire PSI
After I had new rims/tires put on, My sensors do not work. In fact, I don't even think I still have them. The place that put my new wheels on still has my old ones. Where are the sensors located? And how could it be fixed?
![]() Drives: 2010 2LT Victory Red Join Date: Sep 2011
The tire pressure sensors were / are inside the original rims . Actually they are screwed to the inside of the valve stem and set flush on the rim ( inside the tire rim assy. ) You may want to call them and ask if they did transfer your pressure sensors to the new rims . They usually do it anyways but I would check as they are a little expensive to replace .
#3 | |
![]() Drives: 2011 Camaro Convertible SS Join Date: Oct 2011
Tire Rack sells the sensors--not expensive there. Shop that put your tires on should install for free.
knows 2 facts about ducks
to install them they have to unmount and remount the tires.
#6 |
So, basically they have to take apart 8 wheels, transfer the sensors, then put them all back together?
Thread Tools | |
