JDP Motorsports
Old 06-15-2012, 12:52 PM   #1
Bonemaro
Bonemaro's Avatar
Drives: 2010 RJT 1SS M6
Send a message via AIM to Bonemaro
Bonemaro's build thread
This thread is going to be about my rebirth if you will for my 2010 RJT 1SS. If you don't know allready my camaro is dead in the water. As bad luck would have it something went wrong internally, but to what extent and how remains unknown. For now i am patiently shopping around looking for my next best move to get me back out there.
On or about May 30th i pulled into my driveway after a long night at work, and the info on the DIC said Low Oil Pressure turn off engine followed by loud clanking. I shut it off right away and called for a flatbed to have it towed for further review. Turns out the bearing's in the crankshaft in GM's word's were showing wear typically seen from high revving of the engine. I also had metal shavings in the oil pan. Having an aftermarket cam i knew allready that my warranty was void, and i'd be hard pressed to state anything contrary to my situation; whatever went wrong did, and it was going to be all on me.
Over the past two weeks i've been doing some homework deciding on what approach i would use to get my car back to life. First thought was a total rebuild. "x" amount of dollars to have the engine pulled, stripped, and looked over to see what i could still use, and what i couldn't. From there i thought about anything from a mini stroker to a long block 454. From the boards here i've talked to DanD, my friends at Livernois, and my buddies at Vector Motorsports bouncing one idea after another off them trying to nail down the best fit for me. Then it hit me... why not just get another LS3?
Currently i am carrying around the idea of getting a brand new zero miles LS3; the very same engine i had, but use a different approach than before. For now that's where i am at; square one, and the best thing about it that i didn't feel until yesterday?? This is actually going to be fun. I'm finally at peace with my 40K mile engine failing, and i am closing that door to open up anew.
Pic's to follow as we progress
Bonemaro is offline   Reply With Quote
Old 06-23-2012, 04:08 PM   #2
Bonemaro
Bonemaro's Avatar
Here are a few pic's of the LS3 6.2L crate engine i ordered from GM. It's pretty much bare bones as i'll be swapping a few bits and pieces over from my old one-
Old 06-24-2012, 02:47 AM   #3
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
Subscribed and sorry for your loss man
Old 06-25-2012, 09:07 PM   #4
Bonemaro
Bonemaro's Avatar
Thanks Pierre.
Another setback as i got word today from Paul @ Vector Motorsports that this is how my car was put back together; or not so much from the dealership.
***Found A/C Belt Missing***
***Found Multiple Bolts In Front Clip/Radiator Support Loose
or Not Tightened***
***Found Multiple Nicks On Front Clip and Fendors/Hood***
More to come in the next few days.
Old 06-28-2012, 07:25 PM   #5
Bonemaro
Bonemaro's Avatar
Let the tear down begin!! Finally underway with high hopes of making the C5fest deadline.
Old 07-07-2012, 05:42 PM   #6
Bonemaro
Bonemaro's Avatar
Memoirs of an oil starved engine
We got most of the engine tore down to inspect. Unfortunately we found your camshaft was wiped out and took some lifters as well. We have a new camshaft on the way!
Take a look at that block, and the internal damage. Big old rip there. Kids this is what it looks like when an oil pump fail's.
Old 07-12-2012, 03:40 AM   #7
Bonemaro
Bonemaro's Avatar
7/11/2012
In with the new
A few pic's as the new LS3 is lowered into it's cradle
Old 07-12-2012, 07:51 AM   #8
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
looking good bro
Old 07-12-2012, 08:50 AM   #9
Bonemaro
Bonemaro's Avatar
Thanks guys! Coming along quite well thanks to Paul and Jon at Vector Motor Sports http://www.vectormotorsports.com/ind...mart&Itemid=28
They've been my saving grace.
Old 07-12-2012, 09:19 AM   #10
Dan@VectorMotorsports
Drives: 2010 Camaro SS, TVS 2300
Nice thread Dave! I will have some more updates for you again shortly as well!
Dan@VectorMotorsports is offline   Reply With Quote
Old 07-12-2012, 09:33 AM   #11
Bonemaro
Bonemaro's Avatar
Sweet ! Thanks Jon
Old 07-16-2012, 05:25 PM   #12
Here are a few pictures of the engine bay as of tonight!
Old 07-16-2012, 06:38 PM   #13
Grey Ghost
Grey Ghost's Avatar
Drives: 2013 HWSE 2SS
Its good to see your car coming back to life. This may be a lesson to me to not void my warranty too soon. Scary
2013 Hot Wheels 2SS
Grey Ghost is offline   Reply With Quote
Old 07-17-2012, 05:18 PM   #14
Getting some break in miles done on the car, changing the oil, back up on the dyno, and back to David!
