Old 06-15-2012, 06:29 PM   #1
mikester0612
Camaro 5 Muscle
mikester0612's Avatar
Drives: 2010 CGM 2SS/RS L99
How to clean this... ?
Hey guys,
So I was wondering if any of you guys have had this problem before and how I would go about cleaning it. I know my rims are dirty because I have not cleaned the car in a while, but before I clean it, I want to know how to get this done.
I am going to be taking the rims off so it will be a lot easier to access. But how do I clean up that rust ?
TSW Donington 22" Matte Black / Corsa Cat-Back Exhaust / Kooks Signature Stepped Headers 1 3/4" - 1 7/8" / High Flow Cats / Custom Tune / CAI Cold Air Intake / BMR 1" Lowering Springs / VMax Ported Throttle Body / Heritage Grill / Havoc Rear Diffuser
mikester0612 is offline   Reply With Quote
Old 06-15-2012, 06:34 PM   #2
ballistic
LS1 to a LS2 to a LS3
ballistic's Avatar
Drives: 2011 Camaro 2SS/RS IBM
Since you are taking the wheel off, use a wire brush and some brake cleaner. I would also paint it with some cailper paint when I was done.
ballistic is offline   Reply With Quote
Old 06-15-2012, 06:54 PM   #3
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Agreed, wire brush to remove the rust... once its clean wipe down with alcohol or a surface prep for paint. Mask off the surrounding area and spray with high temp paint. All GM cars and trucks have that issue... best solution is to paint it, they become much easier to keep clean with a coating on them.
Old 06-15-2012, 07:41 PM   #4
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Agreed with everyone, clean them and paint them, if you can get some clear coat them also.
Old 06-17-2012, 09:24 AM   #5
YOUNGnRECKLESS
Building the Beast
YOUNGnRECKLESS's Avatar
Drives: 2010 VR LS3
How much of it should be painted? Bought some paint to do this and have been wondering how much I should actually paint behind there
YOUNGnRECKLESS is offline   Reply With Quote
Old 06-18-2012, 03:29 PM   #6
ballistic
ballistic's Avatar
You should paint the whole gray area (the rotor hat). Once you take the wheel off you will see what I'm talking about. Just be carefull not to get any on the rotor itself. Where the pad makes contact.
Old 06-18-2012, 05:19 PM   #7
YOUNGnRECKLESS
Building the Beast
Drives: 2010 VR LS3
Gotcha, thanks for the info
Sent from my myTouch_4G_Slide using Tapatalk 2
Old 06-18-2012, 05:27 PM   #8
jwoair23
jwoair23's Avatar
Drives: 2010 Camaro 2LT
Honestly in my experience it really doesn't matter if you get it on the rotor, the paint is gone within a minute of braking, and I haven't noticed any negative effects. It actually gives you a nice clean line from the pad wearing off the paint.
jwoair23 is offline   Reply With Quote
