Cold Air Inductions
Old 06-15-2012, 10:42 PM   #1
GFORCE1320
Drives: 05 GTO
Gforce 9" gets some changes and new model coming
Just thought I would pass along some exciting news.
We are always looking for ways to improve our 9" kits and since we came out with them we've been making changes along the way to make sure you are getting the best product available.
If you are not familiar with our 9" kits, I'll give you a quick run down.
Lets start with the housings.
We fabricate the entire housing here in house using all laser cut and cnc machined parts.
Everything is jig located in our weld up fixture and then tig welded.
We use 3/8" thick face plates and 1.25" thick axle blocks to make sure you get zero deflection from the housing.
You will also notice we only use BMR heavy duty bushings in our 9" kits. No cheap stuff here.
All the mounting ears and brackets are also jig located and tig welded ensuring you get a perfect fit with no grinding or hammering required.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****91.jpg[/IMG]
Why do we build it so overkill you ask?
In an IRS car the center section is bolted directly to the cradle, if the housing isn’t strong then you get flex and distortion.
We've talked with Strange Engineering about this at great length and that is the reason we offer what some call an "overkill" package.
We use the Strange Pro-Iron pumpkin for strength. Strange doesn’t recommend the street case for anything making much more then 500 rwhp and we wont even sell you a Street pumpkin in our kits because of this, it's called a street case for a reason.
We also only sell pumpkins built at the Strange Engineering facility by the Strange techs. The way we look at it, it might cost more but if we're going to provide you with the best 9" kit and best warranty on the market then we should have the professionals build the pumpkins.
Strange builds the pumpkins to the specs you want in your 9". Gear ratio and posi selection to name a few.
Our kit comes standard with the 35 spline Strange S-Trac posi unit. This is the top of the line when it comes to posi units and it also comes with a Lifetime warranty from Strange.
We also offer our 9" kits in a 31 spline Eaton True-trac pumpkin but don’t recommend it if your making 600+ rwhp. it also does not come with the Lifetime warranty like the S-Trac does.
We've never had a problem with a bad pumpkin built by Strange and we (and Strange) feel the reason is because of the heavy duty components we offer and the fact that the pumpkins are built in house by Strange.
We also offer Moser pumpkins built by Moser, they also have a 35 spline posi called the Wavetrac that is also covered by a Lifetime warranty.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****41.jpg[/IMG]
One of the latest improvements we've made to our 9" kit is the use of a larger OEM style bearing with OEM sealing so you get a leak free and long life out of your 9".
These bearings are also readily available at any parts store if you ever get in a pinch and need one.
The new larger bearings also allow us to go up an even larger 40 spline axle stub that we now offer with our custom Outlaw kits.
The outlaw 9" kits use larger custom built cv joints and huge 33 spline axles and can be ordered with either 35 spline stubs for the Strange S-Trac, 35 spline spool or even a 40 spline spool.
If you want to see what kind of car needs an Outlaw 9" kit, take a look at Speedster's build.
We also have another change we are making, we are now using a one piece billet inner stub instead of a bolt together stub.
The bolt together stub was a very innovative design allowing you to just swap out the inner portion if you ever broke one or decided to up-grade.
Problem was nobody ever up-grades it seems and we have only had 1 person have an issue with one of the stubs and it was an issue with the bolts and not the stub itself.
So we decided to just go with a 1 piece billet stub to reduce the amount of parts we have to make.
Here is a photo of the new 35 spline 1 piece stubs just before they get splined.
If you wonder why we use a 35 spline stub, here is the reason.
The stock Camaro inner stub is a 32 spline, not small by any means but if you’re going to improve the rear in your car then why go with a smaller 31 spline stub?
Here is a side by side comparison photo showing the 35 spline stub on the left, the 32 spline stock Camaro/G8 stubs in the middle and a 31 spline stub on the right.
You can see the 35 spline is a vast improvement.
We also have a new option on our pumpkins.
Strange has a new heavy duty aluminum case out, it's called the Strang HD Pro-Aluminum case.
You can get your 9" with this pumpkin as well, we have to do a little machine work to the pinion support to fit our front mount but it sure is a nice unit.
Saves about 15 lbs over the steel units.
Here is the BMR car with the same Strange HD Pro-Aluminum case installed at last years PRI show. BMR got one of the first few that Strange made and did a great job of displaying.
We make it a point to test our products every chance we get, we test our 9" kit in our shop car just about every weekend. It's a 2005 GTO with a GTO 9" kit, very similar to the Camaro 9" kit.
Our shop car runs 9.90's at 138 mph all motor and pulls 1.39 - 1.40 60ft times.
Here is under the car shot of our GTO, it sports a full line of Gforce goodies.
Another important factor in our 9" kits is the fact that we machine almost all the components right here in our shop.
This allows us to make design changes on the fly and make custom kits when needed.
We also only use US steel for all of our products, no foreign stuff.
If your ever in the area, stop by for a tour.
And one more piece of exciting news,
We are about ready to start machining our first billet aluminum 9" housing.
The new billet aluminum cnc machined housing will get the weight down comparable to the stock rear.
So for you guys concerned about weight, this is the way to go.
More details on this later.
And here is our 9" kit all laid out.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****14.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****15.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****18.jpg[/IMG]
GFORCE1320 is offline   Reply With Quote
Old 06-15-2012, 10:52 PM   #2
jrpxxii
jrpxxii's Avatar
Great write up Chris as this is the baddest kit out there and exactly why I chose GForce for all of my components.
Old 06-15-2012, 11:06 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Very nice Chris.
Your engineered products provide the ultimate solutions.
People don't give warranties like yours unless they have an impeccable track record. That speaks volumes.
Old 06-15-2012, 11:52 PM   #4
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
YAY BILLET ALUMINUM!!!
Kyle2k is offline   Reply With Quote
Old 06-16-2012, 12:04 AM   #5
monstertodd
monstertodd's Avatar
So what is the going rate on a 9" kit these days?
Old 06-16-2012, 01:25 AM   #6
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Question about your 9" kit, and also indirectly about all other non-stock differentials.
Does an after-market diff eliminate the stock driveline "clunk"?
I figure if GM insists on saying the clunk is normal, that means it was intentionally designed in, and they know what causes it. Why won't they tell us?
Is it too much ring & pinion backlash, spider gear slop, axle spline slop, posi slop or what?
Does you differential eliminate the clunk?
Thanks for listening to my vent.
Meh
My 5th is offline   Reply With Quote
Old 06-16-2012, 09:37 AM   #7
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Awesome write up Chris! I am glad I went with a Gforce kit myself. Couldn't be happier! Your quality, experience and customer service is unmatched in my opinion. No problems with unbearable gear whine here! Gforce rocks!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 06-16-2012, 10:21 AM   #8
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
doesnt strange build dss pumpkins as well.. and they have been having trouble with them alot !
Whipped416 is offline   Reply With Quote
Old 06-16-2012, 10:57 AM   #9
GFORCE1320
Drives: 05 GTO
Thanks Jason, you going to have your car at the LSx shootout? Were taking our GTO with a new big nitrous set up and should put on a good show. Lets get together and have a steak
Very nice Chris.
Thanks Bruce, I cant wait to check your car out in person. It's a work of art !
How much power did your car put down to the tires? Wasn't it like 1500 or something crazy? I still need to get some video and pics from you so we can use it for some new advertisements
Yea, were pretty excited about it
PM headed your way, talking about prices is strictly forbidden in this section of the forum.
There shouldn’t be any clunking after our 9" install, I haven’t heard of anyone complaining about it. But then again I haven’t heard of anyone complaining much about it on stock rear cars either. I know on other platforms like the GTO, getting rid of the OEM driveshaft and going with a good solid 1 piece shaft gets rid of a lot of clunk in those cars.
Thanks Brad!
I'm glad your local, some of the new changes and innovations come from having guys like you willing to let us try new things now and then to see if they work out better. Like the new bearings, fluid levels, adapters..
I'm not sure, you would have to call Strange and ask them. We dont use the components that they use so it's like comparing apples to oranges. I dont want to get into a pissing match over this. I know we have excellent results from Strange using the components we use and it just works.
We almost exclusively use the 35 spline S-Trac in Pro-Iron pumpkins, very rarely do we have them build one with a 31 spline TrueTrac and we've never had them build one with a street case.
We feel that is the reason we have had such excellent luck with our Strange build pumpkins, they are more expensive going with the S-Trac and Pro-Iron case but well worth it IMO.
Old 06-16-2012, 11:21 AM   #10
TornadoSS
WICKDSS
TornadoSS's Avatar
Originally Posted by GFORCE1320 View Post
Thanks Brad!
No Problem Chris! You know I am always available and willing to help you guys out! Just let me know! I have a few ideas I think we vaguely talked about, that I would like to see if you want to work them, not anything to do with the 9 inch kits. I'll get with you again here soon.
Old 06-16-2012, 11:30 AM   #11
GFORCE1320
Drives: 05 GTO
We've got a few new products for the Camaro in work, we might need a local test subject
Come by sometime, I'll show you a photo of the new engine I'm picking up next week for the GTO. You thought it was fast before.. you aint seen nothing yet. We're going after some of these locals in the x275 drag radial game
Old 06-16-2012, 12:56 PM   #12
TornadoSS
WICKDSS
TornadoSS's Avatar
What's wrong with the monster you have now?! And where's the old motor going?
Old 06-16-2012, 01:44 PM   #13
GFORCE1320
Drives: 05 GTO
It's going in Ryans car, it's about done.
I'm heading up to Chicago to pick up the new motor next week
Old 06-16-2012, 01:48 PM   #14
TornadoSS
WICKDSS
TornadoSS's Avatar
Interesting! Let me know when you get back!
