JUICEDMOTORSPORTS
Old 06-18-2012, 06:00 PM   #29
jrpxxii
jrpxxii's Avatar
Chris - I will definitely be at the LSX Shootout and would love to grab a steak with you while we are there. I was really hoping to make the Atlanta race but we had some issues with the intake and injectors so we are just taking our time making sure everything is perfect and the way we want it. It should make some noise when it is dialed in. I would love to hear more about the rear kit to fit 15" wheels as I also have a source that is making a kit as we speak and should be on my car in a week or so. Looks like you guys are ready to go REALLY fast with that new motor and all that nitrous.
Old 06-18-2012, 06:15 PM   #30
Allanski
Drives: Car
Ship soon please!
Allanski is offline   Reply With Quote
Old 06-19-2012, 12:34 AM   #31
se7en
Drives: 87 Pinto on 32's
Chris: ive got 17's on right now.
Lets talk about this 15" kit in Joliet if you dont mind. Im interested
se7en is offline   Reply With Quote
Old 06-19-2012, 12:16 PM   #32
HumanWiki
Drives: Car
Originally Posted by GFORCE1320 View Post
Those axles wont work, they are too long to be used in a 9" kit.
I bet we can work something out, I'm sure you could sell them.
The bushings we use in our 9" kit is the same BMR bushing kit they sell for the OEM rear plus they all pick up the same factory locations.
I cant release a weight yet on the aluminum version as it is still going through some different machining variations to see how much weight we can take out of it but still have the rigidity in the FEM (3D CADD Finite Element Models).
Will probably be another month or so before we have one ready for testing.
Thanks
Chris
Thanks.. I'm sure I could find a buyer for them....
That's cool that it uses the OE bushing size and locations.. Hopefully, it would be possible to order w/o those pieces since I already have the upgraded HD bushes and whatnot.
As long as it's not stupid heavy, I'm more concerned with the strength.. Plenty of people tell me I should be fine with DRs and my upgraded axles.. But.. This is my only car and I have limitations.. I'd rather upgrade first, than break then buy.
HumanWiki is offline   Reply With Quote
Old 06-19-2012, 04:37 PM   #33
GFORCE1320
Drives: 05 GTO
Yes, we can sell you the kit minus the bushings. If you have some now then it would only make sense for you to re-use them and save some $.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 06-20-2012, 04:07 PM   #34
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Did a couple of those photo's look familiar? LOL
Very familiar! Cant wait to get it back out and start beating on the setup again....this time with over 800rwhp! Hopefully the new motor will hold up! HKE has my dragon slayer and thats the only piece we have been waiting for.
Steve the the SNL Performance crew will be setting everything up....hopefully will be driving in a month!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 06-20-2012, 09:07 PM   #35
GFORCE1320
Drives: 05 GTO
Cool, I bet your ready to drive her again.
Check out the new 35 spline stubs just back from getting the aerospace e-coat black coating
Old 06-21-2012, 12:21 AM   #36
se7en
I WANT 35 spline with aerospace e-coat black coating!!!
Old 06-21-2012, 01:09 AM   #37
GFORCE1320
Drives: 05 GTO
You got it bud, the housings and brackets get powder coat but the stubs and axles all get the e-coat finish. Years later and your parts you paid all this money for still look brand new
Thanks
Chris
Old 06-21-2012, 07:48 AM   #38
se7en
Thanks
Chris
Thats awesome man!! Thank you
Old 06-21-2012, 11:55 AM   #39
GFORCE1320
Drives: 05 GTO
I've talked about this before, there is a considerable amount of strain put on the center section of an IRS rear.
When we put our 9" kit to the test in our GTO shop car, we were able bend the front mount when launching off the trans brake at 5500 rpms. The front mount on that kit is 1/4" thick, same thickness as our Camaro front mount. We are adding gussets to make it stronger for the GTO.
The Camaro mounts different and the loads are applied differently but you get the idea.
That is the reason we make such a bullet proof housing and use the heavy duty Pro-Iron case.
Old 06-21-2012, 07:21 PM   #40
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Not the biggest market but anything for the 2012 A6 3.6L Camaros? Looking to go posi and gears.
etmx183 is offline   Reply With Quote
Old 06-21-2012, 07:28 PM   #41
GFORCE1320
Drives: 05 GTO
I bet we could come up with something. I dont have a v6 set of axles so I would have to get a set to see how they are different.
Thanks
Chris
Old 06-21-2012, 07:42 PM   #42
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Chris that aluminum housing with a pro strange or moser thru bolt aluminum case sounds like the ticket for me for sure.. I'm all about dropping some weight on my 9 inch.
JLE58 is offline   Reply With Quote
