Emblempros
Old 06-16-2012, 03:14 AM   #1
Jpzero3
Jpzero3's Avatar
Drives: '12 Camaro 1LT RS package
2012 ABL Door Lighting
Is it possible to get the blue ambient door lighting that comes standard on 2LT and 2SS installed on my 1LT?
I currently have this interior without the trim; it is just beige cloth.
i WANT this.
Jpzero3 is offline   Reply With Quote
Old 06-16-2012, 04:45 AM   #2
v6
v6's Avatar
Drives: 2012 45th 2LT RS
that looks like an aftermarket install. stock ABL is just the top part of the door sill lit up. But i know you can buy a kit for this. Not sure where tho
v6 is offline   Reply With Quote
Old 06-16-2012, 09:01 AM   #3
skinman
skinman's Avatar
Drives: Convertible Camaro
Cool! Haven't seen that yet. Mine just has the top strip. I want the aftermarket dash strip.
skinman is offline   Reply With Quote
Old 06-16-2012, 09:18 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
i WANT this.
that's not standard ABL. I believe that is 2SSRS' door panel. But regardless 2SSRS sells an ABL kit on his website - www.gen5diy.com
2SSRS sells a kit on his website for the dash ABL.
Click to view my build thread
Old 06-16-2012, 01:45 PM   #5
StangKiller-SS
Drives: GM products
The bottom ABL part is not stock, and even then the upper trim may be modified. You can install the actual 2SS style trim panels with ease as it's just a removal of your stock cloth trim and mounting the silver panels with some very short screws. Dash trim is only clipped on and passenger dash piece has like 5 clips across holding it in and the drivers side dash pieces has like 2.
StangKiller-SS is offline   Reply With Quote
Old 06-16-2012, 04:12 PM   #6
Runawayhacker
Runawayhacker's Avatar
Drives: 2012 Camaro 2SS
Looks good. I have a 2012 2SS non-RS. What all do I need in addition to the kit they provide? Surprisingly, there is barely a description there. If anyone has the actual instructions on how to install it so I know ahead of time, that would be awesome too.
In my first 5th gen, I had a 1SS, so I ended up lining the dash and doors with EL wire. It looked positively AMAZING and at 99cents a foot, it was cheap. One of the drawbacks though was the high pitched noise coming from the inverter for the EL wire. I was working on silencing it, but then my car was wrecked :(
Runawayhacker is offline   Reply With Quote
Old 06-17-2012, 05:38 AM   #7
Jpzero3
Jpzero3's Avatar
i'm soooooo sorry for your loss ,
have any pictures though?
Old 06-17-2012, 05:40 AM   #8
Jpzero3
Jpzero3's Avatar
do you have any resources where i could learn how to install it? or where i could even buy all the parts i need to make it look liek the stock ABL lighting...i know the picture i put up was not stock but i'd want the original stock ABL lighted doors
Old 06-17-2012, 09:42 AM   #9
The Stig
The Stig's Avatar
Check the marketplace for a set of used ABL door panels. Then 2SSRS sells kits to retrofit the ABL
Old 06-17-2012, 11:30 AM   #10
Runawayhacker
Here are some photos before I finished doing the writeup. If you want further instructions, just ask and I'll give more
Old 06-17-2012, 08:22 PM   #11
Jpzero3
Jpzero3's Avatar
[QUOTE=Runawayhacker;5140690]Here are some photos before I finished doing the writeup. If you want further instructions, just ask and I'll give more
it looks super sexy!
i'm definitely interested!
Old 06-17-2012, 08:27 PM   #12
Jpzero3
Jpzero3's Avatar
would i be able to just remove the beige cloth and place the plastic trim in its place ?
or just replacing the whole door?
which is better?
Old 06-17-2012, 08:37 PM   #13
The Stig
The Stig's Avatar
which is better?
you just need to replace the black cloth one with the plastic ABL piece.
Old 06-18-2012, 01:52 AM   #14
WCoolBreeze
2SS
WCoolBreeze's Avatar
Drives: 2016 2SS, Red Garnet Tint
2SSRS's (Ofer) car is a 2SS with the IOM interior, so his ABL is Red. He has also modifed his to the way the concept cars ABL is. The entire door panel, top and bottom and also all the way across the dash. By the way, I have done the Full ABL install on my car, which is a 2LT/RS
and I will changing out the Light Tubes to better/improved ones which I have recntly aquired.
Walt B.
2016 Camaro 2SS
2005 Dodge Magnum R/T (Yes it has a Hemi)
1987 Camaro RS (California Special) - For Sale
Gen6, 2016 Camaro 2SS, Red Garnet Tint (with Silver Rally Stripes)
Ordered: 2-12-2016
TPW: 3-7-2016
Built: 3-7-2016
VIN 1G1FH78G0157626
Delivered: 4-26-2016
WCoolBreeze is offline   Reply With Quote
