Old 06-16-2012, 10:04 AM   #1
MediumLabowski
MediumLabowski's Avatar
Drives: '16 FiST
Exclamation Intake vacuum seal Question
I just put my catch can on.
The outlet line, or rather the intake manifold vacuum fitting seems cheap, and I am worried its not making a perfect fit now with the hose for the can now attached. Is this a non-issue or is the intake going to suck it down and make the seal, or should i expect a CEL?
(I havent started it yet)
MediumLabowski is offline   Reply With Quote
Old 06-16-2012, 10:17 AM   #2
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
Everybody that install the catch can (including me) has no problem... Perfect fit!
Monchy36 is offline   Reply With Quote
Old 06-16-2012, 10:35 AM   #3
MediumLabowski
Drives: '16 FiST
Ya, but the LLT fitting looks a little more robust, plus its sitting on metal, not composite.
(maybe im just mildly freaking)
The hose that came with the kit was nice and thick (giggity), so i had to push the cover down hard, leaving an indent in the insulation that lines the cover. so with everything so snug in there, there is pressure on the fitting further pushing it down, most likely making this a non-issue.
Old 06-16-2012, 10:57 AM   #4
45anni-gen5
Chevy 4 Life
45anni-gen5's Avatar
Drives: 2012 45th anniversary RS Vert
if your hose is that thick(giggity) then there shouldnt be an issue ...i have the composite fittings and a thick hose(giggity) and have zero issues
45anni-gen5 is offline   Reply With Quote
Old 06-16-2012, 12:15 PM   #5
MediumLabowski
Drives: '16 FiST
Ok, thanks for the reassurance.
Hows the AF treatin ya, i got out in '04 as a staff... regreted it.
