JUICEDMOTORSPORTS
Old 06-16-2012, 10:40 PM   #1
camaro2rs
camaro2rs's Avatar
Drives: camaro
WANT TO REPLACE KICKERS AND TWEETERS
hey guys i want to change out my BA kickers and tweeters to an aftermarket brand that sounds better. I am new to the audio world. I want this to be an easy plug and play or maybe some splicing....anyone have any suggestions thanks! also i would like to upgrade my amp to a better one again want it to be plug and play or minor wiring
camaro2rs is offline   Reply With Quote
Old 06-17-2012, 01:02 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Since you have the BA system in your car, adding an aftermarket amp will be much easier by using the following product from ********:
http://camaro5.com/forums/showthread.php?t=170290
Using the above product, I added a JL Audio xd400 to replace the factory BA amp.
As far as speakers, you will get a lot of different answers as far as which brand to get. I'm perfectly happy with my Alpine Type-R components and 6x9's, but some brands that I've seen mentioned are:
Hybrid Audio Technology
Focal
Hertz
Also, what is your budget?
Old 06-17-2012, 04:02 PM   #3
camaro2rs
camaro2rs's Avatar
Drives: camaro
under 300 were the jl ones you have plug and play?
Old 06-17-2012, 09:40 PM   #4
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
By using ********'s FARK harness, the JL xd amp was plug and play.
Old 06-17-2012, 10:54 PM   #5
camaro2rs
camaro2rs's Avatar
Drives: camaro
do u have a link to which jl amp would be good for me?
Old 06-18-2012, 08:34 AM   #6
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
Although that question was directed at Iwantone2, I'll give you a link to the amp he is referring to since he hasn't seen this yet.
http://www.crutchfield.com/I-rCHVc11...Xd400&skipvs=T
Hope that helps!
CrutchfieldBrooke is offline   Reply With Quote
Old 06-18-2012, 11:08 AM   #7
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Thanks Brooke! Yes, that is the amp that I have been using.
Old 06-18-2012, 12:21 PM   #8
camaro2rs
camaro2rs's Avatar
Drives: camaro
and if i get the ********s harness this will work plug and play? what wattage is the stock amp? and does an amp help with sound? thanks for your help
Old 06-18-2012, 05:48 PM   #9
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Well, it won't be completely plug and play since you'll still have to run power from the battery to the amp. ********'s harness will come with instructions on how to connect the cable from the harness into the amp.
Not quite sure off the top of my head what the wattage of the stock amp is, but any aftermarket amp will definitely help with sound
Old 06-18-2012, 06:15 PM   #10
camaro2rs
camaro2rs's Avatar
Drives: camaro
where can i buy ********s harness? and the setings on the back of the amp what are those?
Old 06-18-2012, 09:49 PM   #11
CrutchfieldBrooke
You're welcome. Nice amp.
Old 06-19-2012, 12:46 AM   #12
camaro2rs
camaro2rs's Avatar
Drives: camaro
http://www.crutchfield.com/p_107MM69...dio-MM691.html
are these the decklid speakers in the rear? and are they plug and play?
Old 06-19-2012, 03:29 PM   #13
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
Click on the link in my first reply. It should tell you where to purchase it.
To be honest, my settings were a lot different because I had the Alpine speakers installed. So I set the amp settings to output full range to the speakers so that the crossover in the components could do the work.
Old 06-19-2012, 03:31 PM   #14
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
If you are referring to size, yes the rear speakers are 6x9. Unfortunately, they are not plug and play. I believe Steve at ******** sells a harness for the rear speakers. If I were you, I would contact Steve for details.
