ADM PERFORMANCE
Old 05-16-2009, 10:18 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
music file types
What file extensions can the USB port read? Is it MP3 only or can it read wma or other formats ?
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 05-16-2009, 11:45 PM   #2
kdoske
Waiting For My 1SS/RS SIM
kdoske's Avatar
Drives: Sold My Lancer, now carless :/
that's a good question, I wonder if FLAC would be supported. That would be pretty awesome for the audiophiles out there...
kdoske is offline   Reply With Quote
Old 05-16-2009, 11:52 PM   #3
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Yep...good question.
As far as wanting to play WMA files, why would you want to play those? They are huge file sizes and would take up much more room on a memory stick vs an mp3.
I know you asked what are the other file types and I'm sure someone will respond. However, as I'm sure you know, there are file converters (such as "switch") that are free and downloadable from the internet. That's what I use to convert my cd's that I download onto my hard drive. They are downloaded as wma's to the drive and then I convert them to mp3's.
Old 05-17-2009, 10:08 AM   #4
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
MP3 and WMA
from owner's manual
Old 05-17-2009, 11:11 AM   #5
LS/V6
LS/V6's Avatar
Drives: 1LT
It should be able to read all formats because the Ipod i be leave uses MP4. But as Tag said WMA file are huge. Just use a converter to make them MP3s
LS/V6 is offline   Reply With Quote
Old 05-17-2009, 11:52 AM   #6
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
I've found WinFF to be the simplest, fastest, best-quality converter. It's actually a GUI front end for the command line tool ffmpeg, which works really well.
http://www.biggmatt.com/winff
However, there's nothing inherently wrong with playing WMAs. If you don't have the original in a lossless format, then any transcoding from WMA to MP3 will lose a slight amount of quality. WMAs I've seen are no larger than equivalent MP3s.
So, to answer the question of why someone would want to play WMAs...that'd be if you've got WMAs and no lossless version to encode from.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 12-11-2009, 09:48 PM   #7
u812
Drives: 2010 Camero
Thumbs up FLAC to WMA
I think you are confusing WAV files with WMA files. WMA files are not so large as WAV files.
WMA encoded form lossless FLAC files are far superior to mp3's.
Use the following program to convert any format to any format, Its freeware.
Code:
http://www.erightsoft.com/SUPER.html#Dnload
u812 is offline   Reply With Quote
Old 12-14-2009, 10:10 AM   #8
theholycow
theholycow's Avatar
Code:
I've always found the interface in that program to be just awful.
Here's a much easier to use program that's free (in fact, it's open source):
Old 12-14-2009, 05:43 PM   #9
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
every single person that is running windows, and want to convert store bought CD's to mp3's can just use Windows Media Player. Start the program, Go to the "Library" tab, go down to "OPTIONS". The options box opens up. go to the "rip music" tab, at the top you can select or brouse and select the folder you want to always have your music ripped to, then below that select MP3 as the file type. and at the bottom the audio quality. Then jsut rip away....works like a champ.
Old 12-15-2009, 09:13 AM   #10
Ccecil
Drives: 2010 Camaro B/B 2ss/rs A6
If people are having issues with file types. Use a program like Switch to convert your media.
Ccecil is offline   Reply With Quote
2010 Camaro 1SS in Rodney Atkins Music Video... Screen Shots Inside! gm4life05sle Camaro Photos | Spyshots | Video | Media Gallery 8 03-29-2009 08:21 PM
Music of Camaro5 kdbolt70 Off-topic Discussions 23 02-12-2009 07:06 PM
