| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#51 | |
![]() ![]() ![]() Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
The second thread they are making fun of the number right off the bat....+ the second one has CAMS so it must be a special engine to have more than 1 cam and and hes running a meth kit.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 11psi 11.20 @ 126mph TVS2300 , Twin Carbon Street Slayer Clutch & 1000HP Axles,JRE cam & tune,LPE Fuel, Super Chiller,Nitto555R |
#52 | |
![]() ![]() Drives: 2010 IOM SS Join Date: Aug 2009
There is no need for me to defend him as his reputation on this site speaks volumes. But come on, your acting childish with the Jannetty bashing.
Jannetty Racing Built
#53 |
Drives: 2010 2SS RS Black on Black Manual 6 Join Date: Sep 2009
http://camaro5.com/forums/showthread...17#post1369061
Hmm 736, RWHP? Hmm post #3 6.5PSI, 650RWHP.. Hmm.. i guess im not the only one. |
#54 | |
#55 |
Basic napkin math
Target Number: 665 rwhp 370 - Baseline (370rwhp) 410 - Longtube Headers + Tune (40rwhp) 475 - Custom CompCamps Custom Grind 112LSA with 600+ lift. (65rwhp) 485 - Custom made exhaust via Spintech (10rwhp) Now, From what I understand a Supercharger can provide between 25 and 45% increased horsepower? @ 25% of 485 thats 121.5 @ 45% of 485 thats 218.5 So..@ 25% = 606 So..@ 45% = 703 Please, ****ing explain this to me because now im actually frustrated becuase it seems logical, and plausible to me. Yet for some reason we have people saying BS. I've found numerous forums and posts including some on C5 stating its fairly common and expected from a Procharger unit. Especially considering all of us in this bracket are around the same horsepower. |
#56 |
#57 |
![]() Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
Yeah but he also has ported and polished heads
#58 |
Taken from http://boostzilla.com/store/allzilla/faq/supercharger
How much horsepower will a supercharger add to my engine? Although some manufacturers claim a specific horsepower increase, superchargers actually add horsepower as a percentage gain (percentage of an atmosphere). After adjusting for thermal and mechanical energy transfer, if an efficient centrifugal supercharger is generating ~5.5-6.5 psi (just under 1/2 an atmosphere), you will see around a 35-50% gain in horsepower and 35-50% gain in torque at your non-supercharged maximum horsepower rpm. At higher boost levels, the heat generated by compressing air will produce diminishing returns as the boost is increased, although the use of intercooling or racing fuel can avoid this scenario of diminishing returns. Assuming the use of intercooling to run higher boost levels while maintaining reliability, a 50-70% increase can generally be achieved at around 7 psi on an engine with 11:1 compression running pump gas. The gains in horsepower and torque delivered by each BOOSTZILLA™ system can be found on the "Spec Page" for each kit within this site. |
#59 |
Every link you have shown is 9-10psi not 6.5 and they are all running meth on top of 10psi
#60 |
Table math revisited.
Assuming 480RWHP... headers, cam, exhaust, tune... (baseline of 370) 35% 648 40% 672 45% 696 50% 720. So again, please explain to me why my 664 rwhp, is impossible? Just trying to understand.. at least im arguing with numbers to work with... and information... |
#61 | |
Is this Calbert? Are you brothers? If not somethings wrong with that Canadian air. Another D1 Procharger thread. So at 10 Psi you'll make 1000 Hp just like Calbert. Do you 2 use the same shop. He has outrageous claims also.
#62 |
#63 |
Heres what I find interesting..
NO one is correcting my napkin math.. Just talking.. Talk talk talk talk talk talk talk talk talk. BACK YOUR SHIT UP? nyny69 , I know Chris on the forums, we both goto the same place for performance but beyond that no, I don't directly know the individual. |
#64 |
If you go to post 10 he tells you he also has ported and polished heads. This means more then all his other mods put together.
#65 |
I'll respond when we can focus on the 'math' since that seems to be holding its ground pretty well..
#66 | |
BTW, why the hate for Jannetty.
#67 | |
So now just because someone posted it its true? WTF dude
#68 |
Ok so is the consensus then that there is no way I am capable of 665 rwhp, my napkin math is wrong (somewhere?) and the guys at booststill are out to lunch? Headers with tune 40ish horsepower Aggressive CAm often custom grind.... 60+ horsepower Exhaust 10 horsepower baseline 370. Thats like 485ish rwhp.. 35% - 50% is all based on temperature humiity **** it, you guys can't argue the #'s so we default to splitting hairs. Bunch of pathetic sore losers. Get with the program, run the numbers, accept reality and move on. Procharger all the ****ing way. |
#69 | |
#70 |
Can you please provide your 'math' on how you came to that conclusion.
I think you need to repeat gradeschool. Somewhere along the way you skipped out on math. According to Boostzilla supercharger writeup its between 35 and 50% of your currently exhisting RWHP. So 370 + 40 = 410 410 + 60 = 470 470 + 10 = 480 So 35% on top of 480 is just shy of 650 40% of 480 is just shy of 675 Stupid kid. |
#71 | |
#72 |
It's not a claim, its fact. I'm siting @ 6.5 psi.
Why is it so hard to comprehend DO I have to requote. 5.5 - 6.5psi net a 35 - 50% increase over already exhisting RWHP. So if I'm @ 480... wouldnt that be about right... 42%ish 665 rwhp? out of 6.5psi The post I made earlier, if you read up a bit (not being rude here) states it clear as crystal, as obvious as a pimple, as subtle as a gynocologist with a gasmask. 35 - 50% @ 6.5psi.... not my word, a companies word... not my word... people who do it for a livings word. I dont know what else to say... but I think ive made my point fairly well.... at least you respect that fact that its doable, and are just shocked to see 6.5psi.. but it ried to account for that by getting information to reenforce my claim. |
#73 | |
#74 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
Again, the Canucks seem a tad off. Run your car, not your mouth. Show us the track slip from this car and prove us wrong.
Oh wait, you guys don't drag race.
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#75 |
You can't just ad 50% to the base line dyno. Your going to lose about 15-20% threw the drive train.
| Thread Tools | |
