Old 06-17-2012, 01:35 PM   #1
SemyDaCop
LocoBee in da RGV
SemyDaCop's Avatar
Drives: '10 Custom RY 1LT, '14 BlK SS/RS
Kicker 10C128 help...
I purchased a pair of Kicker 10C128 12" Sub-woofers. They are 8ohm. Should I have gone with a 4ohm? They said the 8ohm would be better to use. I can still take them back for the 4ohm. Havent opened the boxes yet. If I stay with the 8ohm what would be a good amp to power them by. Crutchfield recommend sthe kicker dx300.2 for a proper amp. Any help would be appreciated. FYI I cant return the speakers I got them at a big discount I can only exchange them. What is the differnce as far as buying 4ohm vs 8ohm? Thanks, I know you guys have plenty of answers!!!
It is better to deserve honors and not have them than to have them and not deserve them.
2010 Camaro 1Lt Custom
2014 Camaro 2SS/RS Custom
SemyDaCop is offline   Reply With Quote
Old 06-17-2012, 05:38 PM   #2
SemyDaCop
LocoBee in da RGV
SemyDaCop's Avatar
Bump
Old 06-17-2012, 07:27 PM   #3
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
The difference lies in the resistance that the amplifier sees once subs are wired together. The higher the impedance (ohms), the less power the amp will put out since it sees more resistance. It doesn't make one impedance better than the other, it's all about picking what's best for your individual sub/amp setup.
With that being said, the Kicker amp that a colleague of mine recommended would work perfectly with the 8-ohm version of the subs you have now.
http://www.crutchfield.com/I-rCHVc11...11DX300-2.html
If you choose to go with the 4-ohm version, you will then be able to get a mono sub amp to power the subs and the amp will see a 2-ohm resistance once wired correctly. The Rockford P300-1 would be a good match then.
http://www.crutchfield.com/I-rCHVc11....html?tp=35834
I hope that might help without confusing you. If I can help further, just let me know.
CrutchfieldBrooke is offline   Reply With Quote
Old 06-17-2012, 07:49 PM   #4
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
You said you have a pair, which means that if you wire them in parallel, they net resistance will be 4Ω.
jeepguy_1980 is offline   Reply With Quote
Old 06-18-2012, 03:22 PM   #5
SemyDaCop
LocoBee in da RGV
SemyDaCop's Avatar
Thanks for the advice!!!
Old 06-18-2012, 09:50 PM   #6
CrutchfieldBrooke
You're very welcome!
