| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
Allyourbasearebelongtous
Drives: 2010 Cyber Grey Metallic 2SS/RS M6 Join Date: Nov 2009
Replacing my fuel pump.........what else?
I bought a ZL1 pump and am planning on tearing apart the rear end to replace it.
What suspension stuff should I replace while I've got it all taken apart?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
The bushings would be a LOT easier with the rear end down.
Halltech Yellowjacket fed Kooks LT's/ Dynomax VT Pfadted (springs/sways) JRE tuned Aint nobody got time for that |
diff bushings or subframe bushings? Or both? lol.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
Full bush kit and be done with it.
MAST 416 STROKER: RDS STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS NITROUS KIT CMGS METHANOL INJECTION RX CHILLER CIRCLE D 2800 TCFLEX PLATE /ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES LPE 3.70 GEARS/JRE POSI MOD DYNATECH HEADERS/MAGNAFLOW EXHAUST/ TEST PIPES SQUASH RETURN STYLE E85 FS/ID 850's BMR/EIBACH SUSPENSION Killing mustangs,because the good Lord wants me to |
Bushings and trailing arms to cure wheel hop.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++ |
#6 |
![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Definitely sub-frame bushings. It will make cutting out the old ones out much easier and touching up the chassis if it gets scratched doing so.
Trailing arm and toe links, that really doesn't matter if you have a lift. Can't say about the diff bushing since I won't change those until I upgrade the axles.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Well if you've already got the rear subframe down it makes really any bushing replacement much easier... especially the subframe bushings. The arms aren't particularly difficult to install whether the subframe is on the ground or not, but it's a tiny bit easier to install the rear tie rods.
If you ever thought about Solid Subframe Mounts now is the time to get it done! |
#8 |
If you are going to up the power, then you should think about upgrading your injectors as well.
#9 | |
Sounds like sub frame bushings and diff bushings are an obvious choice since I will have the rear down on the ground. I suppose everything else suspension wise could be R/R'd without dropping the rear no? Sent from my abacus using precise finger movements......
#10 |
SoCal C5 Family Member
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Unless $$$ is an object, I'd do LCAs while it was out and you're doing the bushings. Why crawl under her more then once? Save your back.
![]() Sent from my iPhone using Tapatalk
#11 | |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
![]() While you are in there, call your local Chevy store and order up a pair of ZL1 upper rear strut mounts complete with bushes. They are an improvement over the SS bits. The driver's side toe bolt requires the sub-frame be dropped or tilted to remove it so you may as well add eXtended Range Alignment bolts. If you are changing those and are on the phone with Chevy grab a set of ZL1 toe links too. Should I stop now
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
| Thread Tools | |
