Emblempros
Old 06-18-2012, 01:22 PM   #1
cris
Drives: 2010 Camaro SS L99
scosche dash kit arrive
Hello
I will like to know when I change the OEM Stereo for a new one, if Is any way to keep the stock Ipod ore USD port from the center console working.....
Because I dont know if I can keep the stock USB working with other stereo.....
thanks
I just get the Scosche dash kit
cris is offline   Reply With Quote
Old 06-18-2012, 02:06 PM   #2
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
You can get this cable from monoprice.com You unplug the the factory usb and plug the Monoprice cable in it place and route the cable to your usb cable input on your radio. That how I got mine setup.
http://www.monoprice.com/products/pr...seq=1&format=2
Caddy
Caddyroger is offline   Reply With Quote
Old 06-18-2012, 02:33 PM   #3
cris
Do you have any pics from your install???
I dont understand to much how to do it......
Old 06-18-2012, 03:28 PM   #4
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Check out this post:
http://www.camaro5.com/forums/showth...74&postcount=4
jeepguy_1980 is offline   Reply With Quote
Old 06-18-2012, 04:09 PM   #5
cris
So. the back of the USB and the AUX port have the other conection??? like the mini USB?? so I can use a extension to connect the new stereo USB to this port in the center console.
thanks
Old 06-18-2012, 04:19 PM   #6
Caddyroger
Caddyroger's Avatar
You just unclip the the side panels with a plastic trim or taped screw driver. At end there are 2 screws one on each side to remove. left up to remove this cover. There are 2 plastic tabs on each side that holds the USB and AUX inputs in place. Press them in to remove the module. Follow the car wiring zip tieing along the way to the back of your radio.
Caddy
Old 06-18-2012, 04:25 PM   #7
cris
So I can use the stock wire??? I donīt need to use a new one??
thanks for all
Old 06-18-2012, 04:47 PM   #8
Caddyroger
Caddyroger's Avatar
thanks for all
no you will have to use the cable you get from Monoprice. Their no usb connector on the factory cable going to the radio.
Caddy
Old 06-18-2012, 05:34 PM   #9
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
Hey Cris, saw your PM. Like Caddyroger already mentioned you need that new usb cable. It needs to be a male usb to a Mini-B 5pin Male. Length you need is 6 feet. The one Caddy posted is fine. The one i got is USB 2.o compatible, gold plated, and has the ferrite core. See link: http://www.monoprice.com/products/pr...seq=1&format=2
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 06-19-2012, 08:47 AM   #10
cris
hello.
I just need to ask you how you connect the OEM USB port to your after market stereo.
I just get my Scosche dash kit and I will use other radio, but I will like to use the same USB port from factory. can you help me how to get this done please.
Thanks
cris
Old 06-19-2012, 05:09 PM   #11
jeepguy_1980
hello.
Thanks
cris
Did you read my post???????
Old 06-20-2012, 01:58 PM   #12
robotfighter
robotfighter's Avatar
Drives: Black 2011 Camaro 2LS
What if you want to use the factory aux input? My Kenwood DNX6980 does not have an aux input, unfortunately. Is there any way?
robotfighter is offline   Reply With Quote
Old 06-20-2012, 02:24 PM   #13
cris
Yes I see it
thanks
Old 06-20-2012, 04:55 PM   #14
robotfighter
You mean the DNX6980 does have one? Where is it located? The install guy said he couldn't find one on the back of the unit. Were you able to reconnect the factory aux line to it? How?
