| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#26 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
I'm unbalanced. So maybe my engine should be too!
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#27 |
Turbo LSX Vert - HP??
Drives: 2SS RS IOM Convertible Join Date: Jul 2009
Really, spraying pre-blower results in uncertain amount of no2? If that was the case wouldnt the same be true for regular fuel intake into the cylinders?
I would like to here from some people running both and some shops about their opinions. Thanks
#28 | |
![]() Drives: summit white ss2 Join Date: Jun 2010
I may be going friday also for data loggin sure would like to see what you will run! |
#29 | |
H-Town Camaro Club
Posted in the Houston Thread.. http://www.camaro5.com/forums/showpo...postcount=1232 |
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
This should work
#31 |
How big is that shot Jas? All at once or progressive? Inquiring minds want to know!!!!!!!!!!!!!!!!!!!
#32 | |
Dont mind if I do!!! lol
#33 |
Thanks mlee!!
#34 |
Everything is tuned thru the Holley Dominator system and literally, EVERYTHING can be finely tuned to anything you can imagine or desire. I am going to set the nitrous up as progressive as there is no way my setup will take 1 hit at once and will be tuned to maximize the efficiency of the nitrous from launch to end.
#35 | |
Can you get this thing on the track already.
#36 |
Perfection takes time but it truly is getting close and when it does hit the track it is WFO from there.
#37 | |
The question is do YOU have your comp license or will you be subbing out the driver like some other guy (who shall remain nameless ).
#38 | |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
So how does the blower disperse the air evenly? ![]() I think this myth was started by the people who wanted to sell everyone a custom direct port intake.
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
#39 |
No subbing here. I will jumping in and going off trans brake immediately. Ill either have one helluva a time slip or one helluva video.
#40 | |
Thats what I'm talkin' bout. Go big or go home....in an ambulance!
#41 |
Loves Nitrous
FOr you big Nitrous guys I have a question. I have a NOS Launcher whic pretty much lets me to to my nitrous what i want. I'm running a bolt on car, stock axles with 18" MT et streets.
We are debating with a 1st gear lock out then hitting it 100% from second on... or Putting a .8 second delay on the Nitrous ramp it in from 70% in a 1 second interval for all gears... Opinions??? |
#42 | |
H-Town Camaro Club
Edit: I see team LS3 there. |
#43 |
R6P Marketing Lab Rat
Drives: 2010 2SSRS for weekends mostly Join Date: Feb 2009
They all say that at first and it's not enough.
Yes, fogger via port is best. Use a delay, dedicated fuel cell and high pressure pump and Ray's thickest spacer for the maggie. |
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010camaro Join Date: Aug 2009
air is not a explosive viotile component, nos , on the other end is...if you were to shove your hands thru the blower blades at wot turning somewhere 15000rpm, do you think that each cylinder would get a even amount of fingers..lol...it probably is not a major amount of difference, but a engine running on same amount of nos shot wot at 7000rpm is def gonna outperform a shot going b4 the blower/intake runners
#45 | |
I Wanna Go Faster!!
#46 |
![]() Drives: Various Join Date: Sep 2009
#47 |
![]() Drives: 2010 A6 SS/RS Join Date: Sep 2009
I am going with the NOS Outlet 1 gallon cell ( For 110 octane) with the Pump and regulator, NOS Outlet system up 200 worth of N2O with remote heater, Timing Delay, N2O controller and 15 lbs bottle. If the car allreadt went 11.30 hopiing to be close to that 10:00 mark...
Also added built rear with 3:70 gears..
Jannetty Built
Scott(Retired Navy)(Paralyzed Triathlete) SOLD 2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass NA 1.57 60ft 10.490 134.78 mph, Special Thanks:Jannetty Racing, Moroso,Livernois,Pro Torque,JW Racing and Fabrication,Paint&Powder Works LLC,Gary Gonzalez |
#48 |
Bayou City Muscle Cars
Drives: 11 Camaro SS LSX & 12 Corvette GS Join Date: Mar 2011
Location: When you get to the middle of nowhere keep going I live past that
#49 | |
11.12 @ 130mph
Drives: A 4000 Lb BeaSSt Join Date: Jul 2009
![]() I'm gonna go 100% everything on tomorrow! No holding back no more haha
TEAM LS3
Built by: J-Rod6410. Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com) Check out my youtube channel: http://www.youtube.com/user/6410Jrod |
#50 | |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
![]() Nitrous Oxide is an oxidizer it still needs the fuel and spark.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
| Thread Tools | |
