Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 06-21-2012, 08:15 PM   #51
mikepage0007
mikepage0007's Avatar
Drives: 2010camaro
the oxygen present in nitrous oxide causes combustion of fuel to take place more rapidly.
so, in laymans terms, the cylinders with the most nitrous will combust{explode} quicker then the cylinders that have less, resulting in uneven power cycle...if direct porting was not better to hit each cylinder, then why use fuel rails and injectors for each cylinder for fuel ...just thro a couple big fuel injectors in front of the blower and shoot some fuel thru it and hope each cylinder gets a even flow of fuel..wait , that almost sounds like a carbarateur , i should pull my injectors and go with a carb, that would be more efficient for even dispertion..lol
iom 2010 camaro ss - kb supercharger-comp cam- razzi ground effects-pedders suspension 1 1/2 drop-gforce 9in-meth- -black out emblems -painted stripes-mike norris catch can- autometer pillar pod w/aem gauges.cor wheels -magnaflow 3in cat back- mikes orange crush-aac halo-aac sidemarkers-mgw shifter-act twin disc clutch-sjm line lock-kooks headers-misc mods-
mikepage0007 is online now   Reply With Quote
Old 06-21-2012, 08:39 PM   #52
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Whatever makes you feel better.
You still haven't answered how the blower manages to disperse air (a gas) evenly but won't disperse nitrous (also a gas) evenly....
Jes sayin...
Gasoline....isn't a gas..it's liquid. Nitrous is a gas....not a liquid like gasoline...so your carburetor example is kind of not relevant.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline   Reply With Quote
Old 06-21-2012, 08:57 PM   #53
mikepage0007
Drives: 2010camaro
Jes sayin...
yur outhinkin me,...hmmmmmmmmmmms m0:
Old 06-21-2012, 09:22 PM   #54
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Not sure how to respond here.."...out thinking someone is unfamiliar ground for me....
9.31@154.81 mph
Procharger F1-X
Old 06-22-2012, 09:43 AM   #55
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
Nice debating here....I think that you heavy hitters are showing/teaching us a lot here. Exactly what I was hoping ot see and hear.
As far as installing goes, how are most of you running your lines and mounting your bottles?
Old 06-22-2012, 10:23 AM   #56
CyberPredator
Drives: TT/SS
On top of what Huffer said N20 is not nearly as volatile as one might think. It's very similar to the air we breath but instead of 21% oxygen it's 38%. Pure oxygen would have a lot more punch but would be very combustible and dangerous. Hence the use of the inert gas nitrogen for stability. But Mike you are on the right path for the benefits of Direct port. But not the nitrous part more so the fuel part. Our intakes and superchargers were not designed to flow liquid so without proper fuel atomization you start to have issues with insufficient amounts of fuel in certain cylinders and said cylinders running lean. But that's something you usually have to worry about when you start getting to the bigger shots usually over 200.
CyberPredator is offline   Reply With Quote
Old 06-22-2012, 09:30 PM   #57
mikepage0007
Drives: 2010camaro
i have read that resting with direct port it is actually less effective with carb engines as the time required for the fuel to flow thru the runners...but oppisite with fuel injectors as the fuel is there immediate...also if you look at my direct port, you will see another nozzle on each cylinder, that is the 110 octane nozzle...when wot, the 110 will flow with the nos ,
Old 06-22-2012, 10:03 PM   #58
Pro Stock John
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Originally Posted by scottywheels View Post
I am going with the NOS Outlet 1 gallon cell ( For 110 octane) with the Pump and regulator, NOS Outlet system up 200 worth of N2O with remote heater, Timing Delay, N2O controller and 15 lbs bottle. If the car allreadt went 11.30 hopiing to be close to that 10:00 mark...
Also added built rear with 3:70 gears..
Look forward to your results, is this a plate or a direct port setup you will be doing? My 2000 Z/28 went 11.3 and 10.00 on a 150 on a 1.38 so I'm thinking you could 10.00 on a 200 shot leaving a little easier.
2010 Camaro SS | LT's Cats UD CAI Tune DR |12.37@112
1951 Mercury | Chopped | SBC
1998 Formula | 348 TH400 88mm | 9.40@145 sold
2000 Camaro | 348 TH400 150 NOS | 10.0@134 sold
~All installs and tuning by Speed Inc.
Old 06-23-2012, 12:39 PM   #59
Texas2SS
Loves Nitrous
Texas2SS's Avatar
Drives: Bolt Ons w/ Dope
First time out spraying last night. Time for a tire upgrade...
Car left the line spinning ending up with a 1.98 60ft. ET sucked, went 11.65x but @ 126.2 mph.
Texas2SS is offline   Reply With Quote
Old 06-25-2012, 11:47 PM   #60
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: EB Expedition, 2SS/RS M6
Envy. Hope my tune gets straightened out soon. :(
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot Coated LTs, JRE SCT Tune, CAI, Rx Catch Can, Gates heater hose relocation, Metco loop, Momentum Tunnel Brace, Autometer wideband, Fesler Pillar Pod, LED strips (interior), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, Plasticoat Bowties, vinyl Bowtie center caps. No holes drilled.
2010 2SS/RS, M6, Blk Rally & Int
Ord: Oct 5, 2009 Rec: Nov. 19,2009 drove off lot at 10:30pm
13.17 @ 112.6 Bone stock
Badbubba is offline   Reply With Quote
Old 06-26-2012, 01:29 AM   #61
B-Rex
B-Rex's Avatar
Drives: 2011 2SS/RS
It sounds small fry next to some of you guys but, im waiting on a few parts to get here through the mail and i will have everything i need to install my 100 shot. i will post up some pics whenever i can get it into the car
B-Rex 2011 2SS/RS LS3
Hurst, LG, C.A.I., Flowmaster, Pfadt, Pedders, U.S. Gear/Axle Tech, LPW, SJM, Nitto, Nitrous Outlet, ZEX
B-Rex is offline   Reply With Quote
Old 06-26-2012, 07:59 AM   #62
Texas2SS
Loves Nitrous
Texas2SS's Avatar
How big of shot are you running?
What kind of system will you be running?
Old 06-26-2012, 08:27 AM   #63
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: LS-3 429 TT with other odds-n-ends
Small fry is relative... You'll be the big dog compared to the vast majority of folks on here...
Looking forward to the pics..
Old 06-26-2012, 08:35 AM   #64
Southwestspeed.net
Agreed! There are not a grip of people squeezing (or at least that are chiming in to say so) so you'll have the upper hand by far.
Makes me wonder if N2O has gotten such a bad rap in the past or if people just aren't educated on it's benefits as to why there aren't more people jumping on it.
Either way, I guess it's nice for those who are runnin it........
Old 06-26-2012, 08:51 AM   #65
Texas2SS
Loves Nitrous
Texas2SS's Avatar
I think it's a little bit of both.
A good system and a good tune makes all the difference in the world.
Prime example being my car. It has no interior engine work and went 126mph in the 1320....When the damn thing finally hooks that will be high 10s. Not too shabby for a stock motor with some bolt ons.
Old 06-26-2012, 10:51 AM   #66
scottywheels
Drives: 2010 A6 SS/RS
We shall see John....The rear goes in tomorrow, I got new DR coming with bigger side sidewall.... all that is left is putting the spray on the car next week.... running 110 in the one gallon fuel cell, so I wont have to pull as much timing...
Jannetty Built
Scott(Retired Navy)(Paralyzed Triathlete)
SOLD
2010 A6 ss/rs White-VORTECH YSI/LPE fuel system/ID 850's/LG Motorsports full Exhaust/Protorque 3400 stall/Livernois Stage 3 Heads/Cam/Bogarts/ Moroso subframes/JRE Rear with 3:70 gears/Aluminium DS/line lock/drag alignment/Suspension/JW Racing 10 pt cage/13.6 psi 719.34 rwhp 558.4 TQ/ Best Pass NA 1.57 60ft 10.490 134.78 mph, Special Thanks:Jannetty Racing, Moroso,Livernois,Pro Torque,JW Racing and Fabrication,Paint&Powder Works LLC,Gary Gonzalez
scottywheels is offline   Reply With Quote
Old 06-26-2012, 11:06 AM   #67
Badbubba
GrINned & JUICEd
Badbubba's Avatar
[QUOTE=Texas2SS;5190787]How big of shot are you running?
Put a 50 in it just to make sure everything worked. But motor n/a tune is off. Working on getting the afr corrected. Then will tune n20 system for a 100 shot. If no fuel issues, maybe more.
Old 06-26-2012, 11:22 AM   #68
Texas2SS
Loves Nitrous
Texas2SS's Avatar
[QUOTE=Badbubba;5191802]
Running a stand alone fuel system with it or no?
Old 06-26-2012, 04:56 PM   #69
Badbubba
GrINned & JUICEd
Badbubba's Avatar
[QUOTE=Texas2SS;5191916]
No plan on stand alone, but plan on a zl1 pump.
Old 06-26-2012, 04:59 PM   #70
Texas2SS
Loves Nitrous
Texas2SS's Avatar
[QUOTE=Badbubba;5194157]
I got ya.
Old 06-29-2012, 10:34 AM   #71
Southwestspeed.net
Damn! That's awesome! Hows your 60' on that and what kind of shot you running? 100? 150?
Hearing alot about the pump swap. Anybody do it and know if it's a plug and play?
/Ivan
Old 06-29-2012, 11:13 AM   #72
Texas2SS
Loves Nitrous
Texas2SS's Avatar
/Ivan
That was with a 2.0x 60ft. Still running my little 305/35/18 tires I ran with just bolt ons. They spin the whole way out even with 14psi.
Will be upgrading to 305/45/18 and a set of skinnies, that should do the trick.
Old 06-29-2012, 11:16 AM   #73
Southwestspeed.net
Hell of a backend on that run yeah! Love hearing those times with a 2.0x 60'.
Rock out!
Ivan
Old 07-01-2012, 03:16 AM   #74
B-Rex
B-Rex's Avatar
Drives: 2011 2SS/RS
im going to be running a zex wet, waiting on a fuel pressure sensor and window/TPS switch to get here, then gotta find time for the install, and finally gotta find time to get a little bit of timing pulled. Im running pretty hot right now, so i don't want to become a carnage horror story before i even get up and running properly lol
Old 07-01-2012, 07:32 AM   #75
Texas2SS
Loves Nitrous
Texas2SS's Avatar
Completely understand what you mean. We pulled 4 degrees on mine but I'm also using 116 race fuel.
