Centerforce Clutches
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 06-19-2012, 02:09 PM   #1
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Spare ECU for tuning?
I suspect there is a security relearn if the ECU is swapped for a spare one?
Anyone have experience with this on a '12 SS?
'12 T3 2SS/RS LS3 M6 - SLP TVS2300 & stuff on corn squeezins
Iam Broke is offline   Reply With Quote
Old 06-19-2012, 02:15 PM   #2
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
It has your VIN locked with the PCM in it I believe...you would have to go through a dealer to get a new one and I believe they would require you to send the old one back in
EDIT: From what I've heard.....for what it is worth
KnightRiderSS is offline   Reply With Quote
Old 06-19-2012, 02:25 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
and even if it works the mileage and data would be off. the dealer will know. gotta pay to play. dont try to cheat the dealer on warranty
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 06-19-2012, 02:43 PM   #4
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Yes global diagnostics tell a lot, I have replaced E38s here and you have to do a clutch learn, case learn, relearn the immobilzer, etc, not a direct swap over at all.
GM Performance Parts Sales, Installation, and Calibrations
rhino-79@hotmail.com
Kooks, EFILive, Edelbrock, Powerbond, Comp, Mast, LPE, Circle D and many more!
2010 SS L99 Cam, Bolt-ons, 3.91s, CircleD 1E 10.87 @ 124 THE Fastest NA L99
Rhino79 is offline   Reply With Quote
Old 06-19-2012, 02:52 PM   #5
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
If you had you would have found the other 26 threads on this topic that say that having a spare ECM for tuning doesn't work on the Camaro.
Old 06-19-2012, 06:08 PM   #6
Iam Broke
PHAT B33
Iam Broke's Avatar
Ya, ok so I'm a newb here. I'll admit I didn't search. The LNF Cobalt I sold was a Bosch ECU that you could swap back & forth after one HPTuners security seed relearn.
Thanks for the info guys.
Long time HPTuners, CobaltSS, GMSC forum rat, just a newb here.
