Old 05-17-2009, 09:36 PM   #1
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
Question USB port stopped working
Suddenly, my Zune will not play when connected to the USB port. I tried unplugging and plugging it back in, shutting it down and restarting the Zune. Also tried turning radio and ignition on and off. Then I tried using a flash drive and it played fine. Unplugged that and tried the Zune again and would not work. Put the flash drive back in and now it will not read that either, the flash drive lights up, but the radio will not switch to USB input. The screen display reads "auxilary input device" and will not swith to "USB device" when something is hooked up to the USB port. The Zune powers up when plugged in to the USB port, controls on the Zune work, but the radio is not getting the signal. If I plug the Zune into the Auxilary input, It plays through the stereo just fine. I don't get why the USB to radio connection suddenly will not work after three days of operating fine.
Anyone else having a similar problem?
2LT Victory Red w/ Black leather interior, automatic trans, polished 19" wheels, R6P (Early Order)
Factory style spoiler, Magnaflow axleback exhaust with resonated x-pipe, Injen CAI, RX catchcan, ABL dash mod,
Drake billet shifter with leather boot, GM splash guards, Toyo Proxes4 tires for summer, Blizzak tires with Moda rims for winter driving
Pre-ordered November 17, 2008
Delivered May 14, 2009
philthy is offline   Reply With Quote
Old 05-17-2009, 09:46 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
is your usb plug for the Zune messed up?
I piss excellence
and fart awesomeness
Old 05-17-2009, 09:53 PM   #3
philthy
philthy's Avatar
No that seems to be fine. It powers up when plugged into the USB port. I doubt it is the cord, since the head unit will not read the flash drive either (it did before.)
Maybe I inadvertantly changed a setting on the head unit (?)
Old 05-18-2009, 07:42 PM   #4
philthy
philthy's Avatar
Problem solved!
Well, the problem seems to have fixed itself. I unplugged the Zune with the car off today, started the car, plugged the Zune back in while in FM mode and it kicked on just fine. Tried the flash drive later in the day and that works also. Maybe I confused the head unit unplugging and plugging everything.
Jammin' now!
Old 05-18-2009, 08:15 PM   #5
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
It probably just realized it wasn't an ipod! ..................
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 05-19-2009, 12:56 AM   #6
etrigan
etrigan's Avatar
Drives: 2010 2SS/RS Black Camaro
"No matter where you go, there you are."
-B.B.
VIN #2G1FT1EW6A9106795
1100, Preliminary order accepted:10/13/08
6000, Del. to me:5/20/09
etrigan is offline   Reply With Quote
Old 05-19-2009, 01:55 AM   #7
kdoske
Waiting For My 1SS/RS SIM
kdoske's Avatar
Drives: Sold My Lancer, now carless :/
LOL, omg thats funny. Probably start up another apple toss...
kdoske is offline   Reply With Quote
Old 05-19-2009, 05:21 AM   #8
2SSJIM
2SSJIM's Avatar
Drives: 2012 CRT ZL1 #1400
2SSJIM is offline   Reply With Quote
Old 05-22-2009, 10:58 AM   #9
LDGn63
LDGn63's Avatar
Drives: WNABEE
My iPhone has done something similar. I turned phone off and on and of worked.
I am wondering if it has something to do with what mode the stereo is in when I last killed the ignition.
Maybe it's best if you don't kill it while using USB?
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-22-2009, 12:15 PM   #10
philthy
philthy's Avatar
Last night it stopped working again while my wife was using the car. I think she had it on FM, hit the source button to get to USB, and the same Auxilary input message comes up again and will not switch to USB. I have to mess with it tonight to see what the deal is. :bangdesk:
Old 05-22-2009, 12:22 PM   #11
CamaroHutch
CamaroHutch's Avatar
Drives: 2010 Camaro 2SS RJT
Maybe there is a flash update or something that your dealer can complete?
Ordered Jan 09
2SS RS RJT
Delivery?? 5/27/09 #10630
AFTERMARKET:
Hurst STS
Borla ATAK Catback
CamaroHutch is offline   Reply With Quote
Old 05-22-2009, 01:15 PM   #12
codeman71
GM Employee
codeman71's Avatar
Drives: 2006 Pontiac G6
I wonder if it is a cable issue. Since it is so intermittent, it seems like that could be it. When it's not working, can you wiggle around the cable on the USB side and the Zune side? If it happens to not work when you try it again, see if a flash drive works. If that doesn't, then there might be a cable problem with the jack itself. I'm sorry that you're having so much trouble with your Zune.
Oh, and what message is it that comes up? Aux jack out? The Zune should be one more source button press after that screen.
I work for GM and I designed the interface for the Camaro USB and Bluetooth audio streaming interface. Feel free to ask me any questions you have about how the USB or Bluetooth works!
Check out my videos on YouTube here. Let me know if you'd like to see any other type of video.
codeman71 is offline   Reply With Quote
Old 06-05-2009, 08:19 AM   #13
cojo2005
Drives: 2010 black 2LT
Unhappy Same problem
I had the same problem you had with my zune. It will not recognize it. I have had my car for about a month and just started using my zune this week. How do you fix this problem? The message keeps saying Aux jack out. It does not show a zune as a source button after this screen.
cojo2005 is offline   Reply With Quote
Old 06-08-2009, 08:30 AM   #14
Rizzo
Drives: 2012 Camaro ZL-1 SIM
I had a similar issue with my first gen iPod Nano. I had to switch to FM, unplug the device, and plug it back in. It doesn't do it all the time, but seems to occur about once a week. Maybe something is a little buggy with the interface?
-Rizzo
Rizzo is offline   Reply With Quote
USB port The_Stache Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 85 09-20-2009 02:44 PM
USB Port location/relocation 2ssJB Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 15 05-01-2009 05:28 AM
USB Port and Acc input in stereo Amelia98 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 18 03-06-2009 06:11 AM
Fbodfather says usb port in dash.... shank0668 5th Gen Camaro SS LS LT General Discussions 76 07-18-2008 11:32 AM
Microsoft working with automakers. TAG UR IT General Automotive + Other Cars Discussion 11 02-23-2008 02:21 AM
