Wretched Motorsports
Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection Anything related to keeping your Camaro clean and in good cosmetic condition.
Old 06-21-2012, 10:09 AM   #1
ihaveacamaro
Future Dentist in 4 yrs!
ihaveacamaro's Avatar
Drives: #198
Have you seen this?!
This guy did a test for 2 years on the effectiveness of Optimum Opticoat 2.0.
Be warned there is READING! Skip to the last link if you want to just see before and afters.
This is amazing!
Initial application: http://prodetailing.blogspot.com/201...at-review.html
2 weeks later: http://prodetailing.blogspot.com/201...at-review.html
Five months after video: http://prodetailing.blogspot.com/201...r-beading.html
15 months later: http://prodetailing.blogspot.com/201...ate-after.html
Final Update: http://prodetailing.blogspot.com/201...r-2-years.html
Consider me sold! Once I correct my paint, this is what I'm going to be using!
Props to the guy who made that experiment and stuck with it!
Mods:
Lambo Doors, Hex Vents and GM High Wing Spoiler Both Painted Summit White
Custom White NS-1 Stripes
SS Exhaust, Injen Intake
White RS Wheels, White Trunk Bezels
ABM Painted Brake Calipers, ABM/White Painted Engine Cover
Dash Ambient Lighting Extension, Rear-View Camera, RX Catch Can
Chevy Emblem Vinyl Overlays, Dye Stitching
AAC:
Amber (Orange) Headlight And Fog Halos Installed As DRLs
ABL Footwells x 4, ABL Dome And Trunk Light
Afterburners, Reverse LEDs, Illuminated Rear Bowtie (Amber/Orange)
Old 06-21-2012, 11:53 AM   #2
jrisebo
jrisebo's Avatar
Drives: 2011 Camaro RS "Bumble C"
I read thru it, and didnt see if after washing it ever he added a wax to protect it, or dont you add wax on top?
jrisebo is offline   Reply With Quote
Old 06-21-2012, 12:10 PM   #3
ihaveacamaro
Drives: #198
I've been reading up on it. You can apply wax, but it won't bond properly and will thus have a much shorter life.
Apparently, after using the optimum opti coat, you just have to use your normal car wash soap, or if you're in between washes, just a detail spray will suffice!
Mods:
AAC:
Old 06-21-2012, 01:11 PM   #4
WiSSDiver
WiSSDiver's Avatar
Drives: 1968 Coupe, 2010 2SS
I'm wondering if after initial paint correction, application of Opticoat, would your wax work better if you apply a sealant, Glaze first, then wax?? Dylan or Todd. would you guys be able to weigh in on this?
WiSSDiver is offline   Reply With Quote
Old 06-21-2012, 01:17 PM   #5
ihaveacamaro
Drives: #198
honestly, I think that the whole point of the opticoat is so that you don't have to wax anymore.
Think about it this way, wax doesn't add shine, it's for protection. Opticoat is a permanent PROTECTION.
Once you clean it up with a glaze or detail spray, it should be as shiny as you can get it.
This is assuming you've done the appropriate paint correction first though.
Mods:
AAC:
Old 06-21-2012, 01:38 PM   #6
Stinkpickle
Stinkpickle's Avatar
Drives: Black 2LT/RS
Think of Opti-Coat as a over the counter clear coat for your vehicle.
You need to make sure your paint is in perfect condition and flawless, or imperfections left after application will be there for the long run.
The only way to safely remove it should be with a compound. You should still be able to use a cheater product with it like a Glaze, and/or detail spray to help enhance the clay.
I don't see why there would be any harm using a wax or sealant on top of it, it just probably wont last nearly as long.
All IMO.
Stinkpickle is online now   Reply With Quote
Old 06-21-2012, 02:41 PM   #7
jrisebo
jrisebo's Avatar
I see. I guess I was thinking if I put this on top of my clear coat, as another clear coat, what stops it from getting all beat up and dull like my clear coat if I dont wax or protect it? Seems a bit daft to cover a clear coat with clear coat. How does it still bead water after 2 years? seems amazing stuff!
Old 06-21-2012, 05:04 PM   #8
ihaveacamaro
Drives: #198
Its much harder than clear coat. I've been stalking an optimum employee on the autopia forums and he posted that the optimum opticoat can get to a hardness level of 9 h. diamond is at 9 h. Yeah apparently there is a scale measuring hardness.... Hehe
Mods:
AAC:
Old 06-21-2012, 05:28 PM   #9
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 73 Camaro Z28 (Sold)
Optimum Opti-Coat 2.0 cross-links to form a permanent film ( coating ) that outlasts and outperforms all LSP's out there. It provides better scratch and mar resistance on the surface and, better UV resistance, better chemical etch resistance so therefore keeps your ride's finish clean much more longer and continues to bead for a very very long time. I don't see any purpose in using glazes or waxes on it all I recommend is a good QD and enjoy it. To the OP I do remember that write up and also remember someone else over there by the name of KC doing one also.
Old 06-21-2012, 05:39 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
But can i use polishes and waxes n sealants on it?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 06-21-2012, 06:12 PM   #11
cbass
Drives: .
I believe the answer is yes, but you are wasting your time and money by doing so.
cbass is offline   Reply With Quote
Old 06-21-2012, 06:25 PM   #12
ihaveacamaro
Drives: #198
Polishes clean paint. But here's the thing, before you apply opticoat, you're supposed to have it your car totally polished and swirl free. That way, you "lock in" your paint job.
Once you lock in your paint job, polishes won't be effective, because they won't be working on the paint anymore, they will be working on the Opticoat. You simply won't have to use polish and if you do, it will be wasted.
Similarly, you can use waxes and sealants, but since opticoat will be much better at protecting your car than either of those could ever be, that would also be a waste.
Mods:
AAC:
Old 06-21-2012, 06:25 PM   #13
cbass
Drives: .
That doesn't sound right. As hard as diamond? What happens when you get into an accident or get a dent and have to repair a body panel? You have no way of sanding down the finish unless you find diamond sand paper?
Old 06-21-2012, 06:41 PM   #14
CamaroDreams07
CamaroDreams07's Avatar
Drives: Carefully and without sarcasm.
Yeah that's absolute BS.
Give it a little tappy tap
CamaroDreams07 is online now   Reply With Quote
Old 06-21-2012, 06:49 PM   #15
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Lmao..its as hard as a diamond it also.protects u.from.dents!!!and accidents lol
Old 06-21-2012, 06:58 PM   #16
ihaveacamaro
Drives: #198
don't shoot the messenger....
http://www.autopiaforums.com/forums/...tml#post328520
Mods:
AAC:
Old 06-21-2012, 07:22 PM   #17
CamaroDreams07
If you read down it also says you can polish it off if there's a high spot. I don't know about you all, but none of my polishing equipment would touch diamond. Sounds like their company boy is exaggerating a little. Or a lot, more likely.
Old 06-21-2012, 07:50 PM   #18
ihaveacamaro
Drives: #198
maybe, but I could care less about the hardness of the product. I'm sold purely on what is shown in the OP.
Fixing a clear coat failure for over 2 years is a win in my book
Mods:
AAC:
Old 06-21-2012, 08:01 PM   #19
cbass
Drives: .
If anyone has this product and is around the Chicagoland area, then I can give it a durability test. I would need very little of it.
Old 06-21-2012, 11:39 PM   #20
ihaveacamaro
Drives: #198
The links I posted to in the OP show a durability test... of over 2 years! Not sure why you would offer to do a durability test if it's already done lol
Mods:
AAC:
Old 06-21-2012, 11:48 PM   #21
cbass
Drives: .
Test the "diamond" hardness finish. With it being that hard it should be pretty chip resistant?
Old 06-22-2012, 05:49 AM   #22
destroyerofu2
xbox360 tag
destroyerofu2's Avatar
Drives: 2010 inferno orange 2SS
the last link had them fixing the swirl marks from "improper washing" so are you saying that the car wash was using Dimond rags to wash the car.
so there is your durability test. It works but is not dimond hard and is still able to get scraches
Originally Posted by babytiger
And like destoryerofu2 said, WOT should be a moment of silence...
It's mine, like it or not. http://www.camaro5.com/forums/showthread.php?t=108079
destroyerofu2 is offline   Reply With Quote
Old 06-22-2012, 07:20 AM   #23
ihaveacamaro
Drives: #198
As destroyer says below, there can still be swirl marks in the optimum opticoat, so yeah doubt it is "diamond" hard, and I don't think it is chip resistant lol
Again, don't shoot the messenger. I was just quoting chris@optimum.
Personally, like I said before, I don't really care for the whole diamond hard thing.
The thing to take away here is that the optimum opti-clear coat is supposed to be harder than the soft urethane clear coats that we get from the factory.
AND it can restore a car from clear-coat failure.
Mods:
AAC:
Old 06-22-2012, 08:46 AM   #24
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
This is amazing!
Several years ago I worked with a friend (the experiment was his idea) to tape half of his car and apply Opti-Coat (before it was officially released) to one half. Almost 2 years later, after washing the paint with caustic soaps, acidic soaps, acid, degreasers, and dawn, the water was still beading like new.
Old 06-22-2012, 08:53 AM   #25
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
But will it shine? Swirl proof?
