Caryle Racing
Old 06-21-2012, 03:58 PM   #1
j0s394
j0s394's Avatar
Drives: 2012 Camaro 2Lt RS Ashen Gray
Arrow ENGINE COVER *PAINT
I WOULD LIKE TO SPRAY PAINT MY ENGINE COVER BUT I'M NOT SURE IF I SHOULD USE REGULAR SPRAY PAINT OR HIGH TEMPERATURE ENGINE PAINT. ANY FEEDBACK IS APPRECIATED THANKS
j0s394 is offline   Reply With Quote
Old 06-21-2012, 04:00 PM   #2
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I use adhesion promotor then Duplicolor and duplicolor clearcoat. Works fine.
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 06-21-2012, 04:10 PM   #3
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
Just like Baron said. Use a good coat of promoter and then use some Dupli-Color of your choice. I painted mine and I didn't even clear coat them.
The "heat" that high heat paint is referring to is much much hotter than your engine cover will ever see. You'll be fine using a rattle can
awfarley is offline   Reply With Quote
Old 06-21-2012, 04:16 PM   #4
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
i just wiped mine off and painted it. no adhesion promoter, no sanding just painted it. came out GREAT! just make sure u get high engine heat paint!
heres mine. GOOD LUCK
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 06-22-2012, 09:52 PM   #5
j0s394
j0s394's Avatar
Thanks for the advice but i also have an other question. I saw this Rust-O-elm spray paint at home depot that has a metallic/chrome finish. ive never seen anything like it, but im thinking it would look cool if i painted the engine cover
Old 06-23-2012, 02:54 PM   #6
zkdreads
zkdreads's Avatar
try it on like a stick or something to see how it really looks. if u dont like it take it back. just dont use ALL the can lol
C-LO or Sonic
Old 06-23-2012, 06:10 PM   #7
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Local paint shop got the factory correct color, did the airbox, fuse cover and engine cover for $150.00, even has clear coat. Fuse cover used a sharpie to fill in and local place for decals ( $15.00 ).
etmx183 is offline   Reply With Quote
Old 06-23-2012, 06:17 PM   #8
bluecam805
Team LFX
Drives: 2012 Camaro LS
Originally Posted by etmx183 View Post
LFX is 323 hp stock
2.5" cat- back Magnaflow exhaust w. resonated x pipe, Roto Fab CAI .. .. JL sound system, Halo fog lights, Escort radar, window tint + turn signals
bluecam805 is offline   Reply With Quote
Old 06-23-2012, 06:22 PM   #9
etmx183
etmx183's Avatar
Everyone that see it tells me that, but it's my HP at the rear wheels on the bottle.
Originally Posted by bluecam805 View Post
LFX is 323 hp stock
Old 06-23-2012, 06:24 PM   #10
bluecam805
Team LFX
haha just happens to be the stock hp that every LLT puts on there engines
Old 06-24-2012, 10:18 PM   #11
moss2029
moss2029's Avatar
Drives: 2012 v6 Camaro
http://www.camaro5.com/forums/showthread.php?t=223807
This might help your choices on paint^
moss2029 is offline   Reply With Quote
Old 07-03-2012, 10:18 PM   #12
j0s394
j0s394's Avatar
i just finished mine today and im happy the way it turned out. what do you guys think? (the last picture shows to much reflection because i had just sprayed the clear coat over the entire cover)
Old 07-04-2012, 09:51 AM   #13
Outlaw_Nation
Drives: 1LT/M6
hard body! i like it alot man!
Outlaw_Nation is offline   Reply With Quote
Old 07-04-2012, 10:21 AM   #14
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
What can I use to re-attach my CAMARO letters, from the fenders, to the engine cover? Is there such thing as a high heat glue?
butters is online now   Reply With Quote
engine cover, engine cover v6 camaro lt
