Vivid Superchips
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 06-21-2012, 09:38 PM   #1
ultrashine
Drives: 1980 camaro z28, 2011 2ss soon
rear shock replacement
i have a leaky rear shock and need to replace it. can anyone tell me whats involved to change the rear shock. Car only has 700 miles on it but hate bringing car to dealer for work unless it is absoultly necessary.
Thanks
ultrashine is offline   Reply With Quote
Old 06-22-2012, 10:15 AM   #2
axis
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Thanks
So you'd rather pay for a strut then take the time to install it, instead of the dealer doing it for free?
If you just want to do it, look in the DIY section and hit the "search this forum" button. Type in lowering springs. There's a good DIY with lots of pics to look at.
Halltech Yellowjacket fed
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
JRE tuned
Aint nobody got time for that
Old 06-22-2012, 10:19 AM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
that should be under warranty. I know dealers suck, but it should be a free fix.
they are struts in the rear...not too bad, but not quite a quick and easy job to swap, and you should get an alignment done as well. Like Axis posted...just search for spring DIY...same job, you just replace the strut, not the spring.
2010 R6P-2SS/RS/LS3 - IBM w/ silver rally stripes / UNDER CONSTRUCTION.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 06-22-2012, 12:19 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Replacing the rear shocks isn't terribly difficult if you have the right tools. If the car has 700 miles on it and the shock is leaking I can't imagine how this wouldn't be a warranty issue.
Take it to the dealer and have it replaced, this is one of the perks you get of purchasing a new car!
