PFYC
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 06-22-2012, 06:45 AM   #1
daxavier
daxavier's Avatar
Drives: 2012 AGM 1SS
JVC KW-NT500HDT Nav while driving?
I have done a ton of research on this and haven't found a solid answer yet. I was wondering if any of you out there have the JVC KW-NT500HDT and have figured out how to make the nav/phone/dvd functions work while moving. I have an SS M6. So far I have tried the relay modification. This allowed the dvd to function with the ebrake off, but as soon as the unit detects motion (around 3mph) it shuts off. This would not be an issue, if it weren't for the other features it locks out. You cannot access the phone's address book. You can't change the address it is tracking in the nav unit, or access the points of interest without pulling over. If I wanted a nav that only worked when I was stopped, I would just get a road atlas. Anyone who knows a workaround would be greatly appreciated.
daxavier is offline   Reply With Quote
Old 06-22-2012, 07:15 PM   #2
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Drives: 2011 2SS/RS SGM
Here you go... I have the 800HDT. Just install this and Bingo! Movies, Nav, etc all work while driving
http://www.amazon.com/MicroBypass-Pa...+parking+brake
Zapote21 is offline   Reply With Quote
Old 06-23-2012, 10:16 AM   #3
daxavier
daxavier's Avatar
Did you have to do anything with the speed sensor cable? Did you ground it or not hook it up or just run it as normal?
Old 06-23-2012, 06:24 PM   #4
Zapote21
Tampa Bay Camaros
Zapote21's Avatar
Had everything professionally installed. So I have no idea...
The GPS and NAV work perfect though...
Old 06-30-2012, 03:52 PM   #5
daxavier
daxavier's Avatar
This worked perfectly. Nothing has to be done with the speed sensor. It's hooked up and functions normally. The MicroBypass required 2 solder points and a ground. All features work in motion now. Thanks for the help.
