Solo Performance
Old 06-22-2012, 05:50 PM   #1
DJJC
Drives: Wanted: 2LT RS Auto
P0451 Code - 2010 LT
Can anyone shed light on this? It came on, I ran some cleaner through a tank and it went off. Then on the last trip I took it came back on. Any ideas?
Thanks!
Black 2LT RS Auto with Performance exhaust
DJJC is offline   Reply With Quote
Old 06-25-2012, 01:05 PM   #2
Chevrolet Customer Svc
Drives: GM Vehicles
Thanks!
If you could please provide me with your VIN, I will be able to research this information further for you. Please send it via PM. I look forward to your reply.
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 06-25-2012, 01:08 PM   #3
Supermaro585HP
Drives: 2011 Camaro SS RS
Just google the code with the year and make of your car..
Supermaro585HP is offline   Reply With Quote
Old 06-29-2012, 02:38 AM   #4
jaysonstuart
jaysonstuart's Avatar
Drives: 2016 Camaro 2SS
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
8
Evaporative emissions systems test for a leak in the fuel tank and associated hoses. To perform the test, the computer pulls a vacuum and checks to see if the vacuum holds. Each car maker uses a different technique to check, but most often it’s some type of fuel tank pressure sensor. This codes relates to a failure in that sensor. It’s either reporting an incorrect value, or is malfunctioning.
This is an OBDII trouble code that will set off the check engine or SES light.
In other words I think you need a new gas cap.
jaysonstuart is offline   Reply With Quote
