Rick@Livernois
Old 06-22-2012, 05:46 PM   #1
ZL WON
ZL WON's Avatar
Drives: too many to list
Clean DIY install of the 90mm LS3/LS7 throttle body.
The only draw back of going with the larger 90mm throttle body of the ZL1 factory 87mm throttle body is that is looks hideous. Below is a picture of what it would look like mounted to the snout without making any changes to the air inlet.
This is what it will look like with a small modification to the air inlet pipe.
In order to flip the TB 180 degrees you need to make a very small modification tot he air inlet. Below are some photos I took describing what needs to be done to make this a very clean install and not have to look at the bulky actuator housing on the 90mm TB.
I hope this helps.
ZL WON is offline   Reply With Quote
Old 06-22-2012, 05:50 PM   #2
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
Great tutorial !
What is the part # and where did you get it ?
Thanks !
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 06-22-2012, 06:01 PM   #3
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Nice job!
sammyv is offline   Reply With Quote
Old 06-22-2012, 06:02 PM   #4
ZL WON
ZL WON's Avatar
Originally Posted by Silverguardrail View Post
Great tutorial !
Thanks !
I got it from Cooler Logic. Their part number is 90MMTB. Ordered it off their website.
Old 06-22-2012, 08:29 PM   #5
alex33x
Drives: 2013 Camaro ZL1
Nice, this is probably going to be my first mod.
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 06-22-2012, 09:02 PM   #6
OldScoolCamaro
Great description in plain english with highlights and tools in the same picture. You should write service manuals. A+
Old 06-22-2012, 09:47 PM   #7
Silverguardrail
Thanks
Old 06-23-2012, 01:30 AM   #8
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Sweet!
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 06-23-2012, 09:48 AM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
genuine gm part cheaper on ebay. 142.00
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 06-23-2012, 08:47 PM   #10
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
ZLWON..Thanks again for the instructions...Very thoughtful of you to put these pics on here. Did mine today..took like 10 minutes start to finish. I did notice when I took original TB off, a couple of the bolts weren't really very tight at all.
The LS7 TB works flawlessly, and I know it could be my imagination, but the car feels snappier. roll on the throttle in second seems better than before.
Very easy mod, and not expensive, and faster to do with the aid of your instructions.
2012 ZL1
Old 06-23-2012, 09:27 PM   #11
ZL WON
ZL WON's Avatar
I'm happy it worked out for you.
Old 06-23-2012, 10:41 PM   #12
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
nice job didn't someone say they got 12rwhp with this mod...no tuning required?
IcePick06 is offline   Reply With Quote
Old 06-24-2012, 06:53 AM   #13
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '15 Z/28
http://www.ebay.com/itm/320760382824...#ht_1125wt_689
On ebay for $142 with free shipping. Just bought one for that price.
'15 Z/28 #325 black a/c & stereo. 2:10.5 VIR Full 1:44.74 Summit Point Shenandoah Circuit
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 06-24-2012, 06:55 AM   #14
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
is a tune required?
rpepka is offline   Reply With Quote
90mm throttle body, zl1 90mm
