sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 09-03-2012, 12:34 AM   #43
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I can't believe you guys are trying to race out there right now with this heat. I tried it once this summer and it was not good. It was a pro street night and very crowded. Had to waint in the stagging lanes for 15-20min in 100* heat. Needless to say my car did not like it. I also couldn't get better than a 1.9 60ft which was pretty bad. I only got 4 runs in because they closed the track due to a spill. I don't think that track is a very good one. There is also really no way to get around the water box when I went. I try to avoid the water box and then back up into it. If you go through the water box your just tracking water up to the starting line and then your rear tires have to drive through it. Most good tracks that I see have a wide clear path around the water box. This is probably why your wife is having so much trouble. Even on stock tires her 2.73 geared car should have no problem hooking up and getting a 2.0 60ft. She needs to do a very slight burn out to just get the water off the tires. I bet she is having trouble becuase her tires are still wet.
Old 09-03-2012, 12:55 AM   #44
08-G35s/6MT
08-G35s/6MT's Avatar
Drives: racecars
A 1.9 60 foot is bad ?????? That's damn good!
08-G35s/6MT is offline   Reply With Quote
Old 09-03-2012, 01:02 AM   #45
VADER SS L99
Its bad for me in this mid 11's capable car. On my DR I want 1.6-1.7 60fts.
Old 09-03-2012, 04:35 AM   #46
08-G35s/6MT
Drives: racecars
Were you at nw 39th this most previous saturday night ?
There was a clean gray camaro turbocharged there.....
Old 09-04-2012, 12:56 PM   #47
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Its fun racing each other in the same conditions. I am working alot on my reaction time since it still feels weird leaving on the 3rd light. November we should put some good times down and hopefully some more Camaro's will be out there since I'm outnumbered by mustangs pretty heavily there.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 09-07-2012, 10:00 AM   #48
jlawrence613
jlawrence613's Avatar
Drives: 2011 V6 Premium Mustang
Meant to tell you... Tell your wife to keep the hammer down when the over rev light comes on. It's supposed to do that, it means it's working. Bama sets the 1-2 gear shift at 7100rpm I believe...
If you can swing it, get her a set of LCA's. A good solid set can be had for $99.00. And Both of you need to get those 60' times down. Don't worry about your reaction times unless you guys are heads-up racing.
Mods: MPT 93 Tune, FRPP 3.73 Gears, Airaid CAI, Boss 302 STB, J&M LCA, Whiteline Relocation Brackets, Eibach Sportlines, 18x9/10 2010 GT500 rims 255/45, 285/40/18 Nitto555, BBK Longtube Headers O/R X-pipe Up next: BBK 73mm TB, Ported Intake Manifold, DSS Aluminum Driveshaft, Mustang GT 2.75" Overaxle pipe.
2011 Ford Mustang V6: 13.258 @ 107.45 MPH Uncorrected
jlawrence613 is offline   Reply With Quote
Old 09-07-2012, 10:27 AM   #49
Gibroni
Drives: '12 IOM LT 'vert
I'm also wondering about my tires, 21k miles on my original all-season tires probably isn't helping. When we move into a bigger house, we may get some drag only tires that we can change out when we go to the track.
Getting a set of drag tires and rims for the would be my suggestion.
Gibroni is offline   Reply With Quote
Old 09-08-2012, 08:18 AM   #50
MagnumForceGB
Told her about the over-rev and I also got a new tune from Bama for the slow shifting. Seems to work a little better for shifting, no lag. Also looking at LCA's when I get the 3.73 gears.
Also I am working on my reaction time because I know that when she gets 3.73 gears I will need to get as much advantage off the line I can or I will see her tail lights. Then when that happens I will be posting in the general discussion forums a topic called "How do I beat my wife".
That is the plan for next year. She keeps her pony package rims which she loves, we use drag racing rims/tires for drag racing only. What kind of size should I look for? She is running 235/50 R18's and I am running 245/50 R19's.
Old 09-08-2012, 08:34 AM   #51
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Ok i remembered the wrong trap. To the left was a blue modified 2010 mustang gt.
Weeks go by faster then i thought, it was august 12, he bought it august 5. DA was awful that night....
You might as well put it in R and go find the parking lot with those RT's. LOL
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 09-08-2012, 09:36 AM   #52
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
looks like your 60ft could be better too, but looking good!
kjkjr27 is offline   Reply With Quote
Old 09-12-2012, 10:09 AM   #53
2012 IngotSilver 5.0
FIVE.OH
2012 IngotSilver 5.0's Avatar
Drives: 2016 Mustang 5.0
I had a 100% bumper-to-bumper bone stock 2011 V6 coupe/2.73/automatic that I raced a few times.
Stability Control can be left on, but Traction Control must be OFF.
October run, mid 60's, brake revved at launch ...
2016 Mustang GT
Magnetic Metallic
2012 IngotSilver 5.0 is offline   Reply With Quote
Old 09-13-2012, 01:48 AM   #54
08-G35s/6MT
Drives: racecars
With your 5.0 ?
Old 09-13-2012, 05:19 PM   #55
KMPrenger
KMPrenger's Avatar
I'm not sure that is the case. If you had the 2.73s...that was a 2LS model with an automatic right?
Some of the best stock V6 60' times here with an auto transmission were achieved by spinning the tires beforehand to at least clean them off, or if they are the PZeros get a little heat in them.
Leave TC on, and hold rpm just able idle....say 1,000 - 1,100 RPM. Foot on break...release on last yellow while simultaneously hitting the gas.
Not saying your technique wasn't any good...just saying what else I've learned on here.
Old 09-13-2012, 10:18 PM   #56
08-G35s/6MT
Drives: racecars
I agree on cleaning them off, the "waterbox" is unavoidable at thunder valley and the prepping is not so good.....
