06-23-2012, 11:07 AM | #1 |
Drives: 2010 Camaro 2LT Victory Red Join Date: Feb 2011
Vmax Ported TB
Ok, so I purchased a Vmax TB and installed it today.
Go to turn key on and get numerous error codes. Check Engine Light on Reduced Engine Power Message Service Stabiltrak Message Code- p0223 Dev 05e8 - TP Sensor 2 Circuit High Voltage I cleared the code and it kept coming back on and disconnected battery and keeps coming on? Wondering if JDP shipped me out a defective unit or Iam doing something worng? |
06-23-2012, 11:10 AM | #2 |
Drives: 2013 2ss Join Date: Mar 2011
i got the same codes when i hooked up my tb, i cleared them with the trifecta software and i never came back
06-23-2012, 11:12 AM | #3 |
COTW 9/16/13
Drives: 2011 2LT/RS Camaro IOM Join Date: Jan 2012
Hmm now I am little worried to install my ported TB now. I know whenever you disconnect the TB the CEL will come on but disconnecting the battery should fix that. Strange.
06-23-2012, 11:13 AM | #4 |
Drives: 2011 Camaro 1LT Join Date: Oct 2011
Me too, except I used a scanguage. I know they said you get the codes from unplugging the TB so I would keep clearing them or drive it a few miles and see if they clear that way.
2011 IOM 1LT RS. K&N Typhoon CAI; Sequential taillights, SLP faded gill overlays, VMAX CNC ported TB, RX Ported IM, RX breather, 3/8" Black Ice-olator, OEM STB, 4 gauge pack, Alpine amp and sub, convertible spoiler, IOM painted rear diffuser, SS front and rear sways, SS front and rear struts and springs, Street Scene front splitter, IOM hideaway headlight covers, 5% window tint.
06-23-2012, 11:16 AM | #5 |
b4 i take the tb off i disconnected the battery and pluged everything in and reconnected the battery no codes!
06-23-2012, 11:27 AM | #6 |
I did the same disconnectted battery.
I cleared the codes 5 times with trifecta code scanner and they keep coming back on. Cant drive car because the power is reduced to nothing. Thinking it may be defective unit. I called JDP and they are going to get more info on Monday and if needed ship me another one. |
06-23-2012, 11:30 AM | #7 |
your sure you plugged everythiing in correctly? it may be defective. i got my tb from jdp
06-23-2012, 11:32 AM | #8 |
Yup, triple checked everything. Only TB plug and MAF plug and there both in.
Going to let it sit and have a few beers then try it again I mean when we get these VMAX TB they are used but do they go thru testing before they get shipped out? Might just ask to upgraded to a new TB |
06-23-2012, 11:33 AM | #9 |
you can ask. jdp was always helpful answering my questions
06-23-2012, 11:35 AM | #10 |
Good thing i have the trifecta software ware or else I wud have to go to autozone to clear the codes
06-23-2012, 11:38 AM | #11 |
Emerald Coast Camaros
Drives: 2017 50th Camaro LT2/RS Join Date: May 2011
I bought and installed mine about 3 weeks ago. As of now no issues. Mine is a V6. just fired up and works fine..
2017 LT2/RS, 50th addition. Airaid CAI, Solo Performance Axle back, sunroof, Smoked Led Markers
06-23-2012, 11:38 AM | #12 |
ZLT!!! COTW (8/5/13)
Drives: 2011 IOM 1LT RS M6 Join Date: Mar 2012
No problems here either... I got a light because i leave my car running with the agressive ghost cam tune, but clear with trifecta and all good! Double check everything... No air leaks...
06-23-2012, 11:46 AM | #13 | |
06-23-2012, 11:59 AM | #14 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
All are tested and have had 3 failures in over 4,000 in use. If it is defective, no problem...JDP will get you one right out to swap....but look closely at the pins in the connector to make sure none got bent or damaged (very rare). Also, are you disconnecting the negative cable in the trunk? The underhood pos cable will not release all stored codes.
Thread Tools | |
