Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 06-25-2012, 05:16 PM   #51
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Originally Posted by JLE58 View Post
Yes. If it's the Maf than it just went bad been a few people on camaro 5 with bad Maf's.
Common in the Camaros for sure.
Built by Vengeance Racing
9.31@154.81 mph
Procharger F1-X
RPM Level 7 4L80e + Coan Converter
Hendrix 9" Rear Axle + 3.50 Gear
ARH 2" LTs+3.5" Exhaust
Fore Fuel System, Bogarts + Hoosier Slicks
Pfadt Drag Pack Suspension
My Build Thread | Best Pass To Date
HufferSS is offline
Old 06-25-2012, 06:26 PM   #52
Chris-HPS
Chris-HPS's Avatar
Drives: 2008Corvette
UPDATE: I called and talked with him. He said it started up fine this morning, and when he got over to the local shop that it started up fine for them as well. After a hr or so, I called him back again to find out the results and he was told that the MAF sensor bolts were loose and seemed crossed threaded. So I talked with my techs and they told me that the MAF bolts used were the ones that came out of his CAI. They did mention that the bolts were tight when screwing in the housing. We use the Cast Aluminum GM Housings in our piping. Not sure if when the housings are welded on to the pipe that it may have distorted the threads a little or maybe a casting flaw inside the threads to cause the bolts to cross thread. Also I asked him if the local shop that looked at this and found the issue actually charged him for a diagnostic fee or anything. I told him I would pay for any fee and he said no. we are also checking each individual MAF Housing and running a thread tap thru them after they are welded to make sure this never happens again. Sorry for the issue, and glad it worked out.
Chris
Chris-HPS is offline
Old 06-25-2012, 06:28 PM   #53
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Chris
Easy fix. Definitely explain the on again off again symptoms.
9.31@154.81 mph
Procharger F1-X
HufferSS is offline
Old 06-25-2012, 06:32 PM   #54
grocerygetter
grocerygetter's Avatar
Drives: 2010 SS (2ss/rs, auto, SW/IOstripe)
Yup. See... Cold side leak.
-John S.
2010 Camaro 2ss/rs-a few cosmetic things, Pfadt stage 2 plus rear arm package, LG chassis brace, Vortech, ADM fpcm/ZL1 pump, Lingenfelter 3.70 gears, JBA catless, ProTorque 3200, 18" TSW N'rings for drag duty, 20" Forgestar F14s for street.
Thanks to: Jannetty Racing, dv8motoring, Gwatney Chevrolet/GPI Jacksonville AR, TCAudio in Benton AR
2012 4Runner -daily driver
grocerygetter is offline
Old 06-25-2012, 06:41 PM   #55
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
Could also be a dirty MAF,it may be oil soaked from the turbo bearings being flooded and passing thru the inlet tube,and if thats the case it'll just be a matter of cleaning the MAF and replacing the oil retrictor to the next smaller size on the turbo,I delt with that early on in my build just something to look@...Good luck and keep us updated.
416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors Lonnies Twin Pump Setup,Circle D built 6l80eCircle D multi disc billet conv,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,AeroforceInterceptor,AEM Truboost Controller,matte black Forgestars.
LSX-80MM is offline
Old 06-25-2012, 06:51 PM   #56
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
chris-hps , glad u explain but man i tell u this if there is a mech out there that said they didnt do something like that i would have to tell them they wouldnt work on my car cause they are full of shit
dekan513 is offline
Old 06-25-2012, 07:01 PM   #57
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
What are you trying to say here? Doesn't make sense..
JLE58 is online now
Old 06-25-2012, 07:03 PM   #58
JLE58
A journal bearing turbo doesn't need an oil restrictor.
JLE58 is online now
Old 06-25-2012, 07:15 PM   #59
Chris-HPS
Chris-HPS's Avatar
My Technician told me exactly what he did and how it went together. I have no reason not to believe him. Thanks for your concern though, I will take it into consideration.
Chris
Old 06-25-2012, 08:10 PM   #60
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
Glad it was a simple fix! Now go enjoy it!
solobaric is offline
Old 06-25-2012, 08:41 PM   #61
SS_Diaz
SS_Diaz's Avatar
Drives: 2010 Victory Red 2SS
Send a message via Yahoo to SS_Diaz
Well....... Had a couple good starts, and it did it again tonight after i left the gym. I drove to a local autozone turned it off and back on and still the same thing. Bought a new aftermarket MAF from autozone but didnt fix it. :( I'll give you a call tomorrow chris.
HPS Turbo Fail
SS_Diaz is offline
Old 06-26-2012, 10:53 AM   #62
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
I have seen oil retrictors on a journal bearing turbo but was because of big oil supply line,And I just assumed it was a bb unit since Chris has been using the comp's,but I guess everybody don't wanta spend the money on bb setup,or water cooled or a billet wheel for that matter,hope he can resolve the issue soon,surely there sum good help in carolina
LSX-80MM is offline
Old 06-26-2012, 11:14 AM   #63
Chris-HPS
Chris-HPS's Avatar
Comp has told us the diameter restrictor to use on there journal bearing turbo's. We have had to use them in the past on there journal bearing turbo's due to the high oil pressure on some of these engines. The turbo on Diaz's car is a ballbearing and has a restrictor as well.
Chris
Old 06-26-2012, 11:22 AM   #64
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Yea Chris I thought so
LSX-80MM is offline
Old 06-26-2012, 11:32 AM   #65
JLE58
I didn't know he had a bb turbo I just figured it wasn't... Must be pushing alot of oil pressure to need one on a journal.
JLE58 is online now
Old 06-26-2012, 01:27 PM   #66
partymn
partymn's Avatar
Drives: Chevy Camaro SS
Chris, dont our kits have 80 lbs resized stock injectors? Is it possible that one of the injectors got messed up durring this proccess and is causing his issues by allowing air in the fuel system? I had a jeep once that would always run like crap until it got warmed up, injectors were old as hell and would leak down when the jeep was turned off.
2011 2ss M6 Turbo
partymn is offline
Old 06-26-2012, 01:33 PM   #67
Chris-HPS
Chris-HPS's Avatar
Yes, they are all flow tested and pressure tested before they leave FIC( Fuel Injector Connection). We are actually checking the fuel pressure and leakdown of a vehicle here at the shop with the same injectors that starts normally, and its twin turbo's vs. the fuel pressure and leakdown that john is seeing.
Chris
Old 06-26-2012, 02:06 PM   #68
Chris-HPS
Chris-HPS's Avatar
UPDATE:
After talking with John and going over some diagnostics and the fact that the starting issue is not a constant issue, I have contacted FIC and after talking with them about the issue, we are thinking that there is a leaky injector or something else so we are having a brand New set of injectors overnighted to them. Hopefully everyone on this site will understand that sometimes issues arrive, however it is how the issue is worked with, or taken care of and that we(HPS) are doing everything possible to care of John and this issue that has occured.
Chris
Old 06-26-2012, 02:45 PM   #69
partymn
partymn's Avatar
Oh, hold up Chris dont be taken parts out of my kit to fix SS_DIAZ Camaro.
On a serious note, I hope that this fixes the issue. I hate seeing a man with out a properly running SS.
2011 2ss M6 Turbo
partymn is offline
Old 06-27-2012, 08:06 AM   #70
rhunley14
Drives: Camaro SS
Speedmon that is a good read. In every proffession there are definitely crooks and people who do not know what they are doing. I will say this. There has been a slight problem with my build. Chris has been paid in full and he his gone above and beyond to make sure that things get taken care of. Not only is he getting it done, he is also putting in new axle and a methanol kit as well. If I did not think he was ethical or trust him, i would move on to another shop. Since the first time I talked to him till now he has always been a straight shooter and i would recommend people to his shop. I understand this is a forum and that you have freedom of speech but your off base here.
rhunley14 is offline
Old 06-27-2012, 08:20 AM   #71
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: LS-3 429 TT with other odds-n-ends
The Drama stops here...
Chris-HPS is a respected tuner and also a sponsor of this site.
Right here in front of everyone, and as stated by the OP, Chris has stepped up and taken care of the issues...
I believe that Chris probably talked to the shop the op took his car to before allowing them to make suggested repairs... to determine in his mind if they were capable of making solid repairs as suggested by Chris.
There is a subforum for vendor reviews, and this thread is not it.
Those of you who's posts disappeared along with the drama posts, I apologize... call it collateral damage...
Any further posts bashing vendors, wringing hands, playing the devils advocate or doom saying will be deleted without further explanation and dealt with as necessary beyond that.
I speak from first hand knowledge that high level tuners and builders occasionally have to depend on others for what may be a temporary fix, or in some cases, a permenant fix... It is certainly not a slap on the tuner/builder/vendor... It is actually a tribute that they do follow up on and pursue the issues their customers have... No one builds these big mod cars without occasional issues; the proof is in the way it is handled after the fact... I contracted with my builder to build my car... not to be with me for thee rest of my life in case anything were to ever happen..
Last year on the way to the Fest in Phoenix, I crapped a turbo, and it took the other one with it from over spinning... My builder was ready to 1, get on a plane, 2, drive out with his trailer... I told him no, there was a builder/tuner from another shop.. I got them on the phone together and the guy that happened to be along with our group, made suggestions, and offered information based on his findings, but only did what my builder asked him to do... and he never charged me a dime for his time either... about five hours total...
Problem was solved, I enjoyed the rest of the time in Phoenix, drove the car 1000 miles home and then my builder went over it with a fine tooth comb...
All is good...
Chris has stepped up as stated by the op... so vendor trashing and bashing stops...
SSE 4 2SS is offline
Old 06-27-2012, 08:24 AM   #72
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Thank you for this confirmation on the integrity of this vendor and forum sponsor...
But.. This is a privately owned and operated Forum, and as such, there is no "fredom of speech." We have rules and forums for specific topics and this is not the location for a vendor review.
Rhunley, Again, I appreciate this post and you certainly did nothing wrong, I just want others to realize we do have and will enforce the rules of posting, for the benefit of the site, the members and the vendors.
Old 06-27-2012, 10:03 AM   #73
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
LSX-80MM is offline
Old 07-01-2012, 03:55 AM   #74
jasycz28
I don't understand
jasycz28's Avatar
Drives: 2010 Camaro SS
So what was the fix?
"JSick"
2010 Camaro 2SS
jasycz28 is offline
Old 07-01-2012, 01:24 PM   #75
SS_Diaz
SS_Diaz's Avatar
Thinking a leaky injector, Im out of town so the car is at home. The new injectors will be installed on thursday and hopefully its good to go.
HPS Turbo Fail
SS_Diaz is offline
