BORLA
Old 06-24-2012, 11:19 AM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Weight reduction (diet)
I wanted to start a thread on weight reduction ideas, and suggestions. I know this is of interest to me, and probably others. There has got to be some tricks to get some pudge off this car...
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 06-24-2012, 11:22 AM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
Good luck
I can give you one piece of advice, ditch the engine cover lol bam like 2lbs gone haha. I don't know much about the ZL1 but if the battery is the same (I would assume so) you could switch to a braille battery.
kjkjr27 is offline   Reply With Quote
Old 06-24-2012, 11:25 AM   #3
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Take out your back seat along with the passenger seat? Swap the driver seat for an all carbon fiber seat. I saw one at a car show last weekend for $3,000 lol.
Get rid of the sound deadening material
KKreme15 is offline   Reply With Quote
Old 06-24-2012, 11:53 AM   #4
DangerZL1
Drives: Future ZL1 Owner
It would be easier for me to do the driver weight reduction mod.
DangerZL1 is offline   Reply With Quote
Old 06-24-2012, 11:56 AM   #5
gmgdave
gmgdave's Avatar
Drives: 12 ZL1 & 08 Suzuki Boulevard C50
I changed out the battery yesterday. Smaller, 5lbs lighter, and easy. The only issue was reprogramming the windows.
2012 ZL1 - #413 - IOM - Mods; Exhaust Commander. GMG Third Brake Light Pulsar, Tinted Windows, color matched Engine cover, ZL1 Floor Mats
gmgdave is offline   Reply With Quote
Old 06-24-2012, 03:20 PM   #6
oortcloud
oortcloud's Avatar
Drives: 2013 ZL1 ordered
The following car journal has some good content. The owner has done a few things such as going to a more powerful clutch weighing 22 lbs less. It's not cheap however.
http://www.camaro5.com/forums/showthread.php?t=45165
oortcloud is offline   Reply With Quote
Old 06-24-2012, 04:54 PM   #7
DangerZL1
What battery did you install?
Old 06-24-2012, 04:56 PM   #8
camslambam
Drives: 2010 SS, 06 SRT10 Ram
http://www.camaro5.com/forums/showthread.php?t=170965
camslambam is offline   Reply With Quote
Old 06-24-2012, 07:30 PM   #9
gmgdave
gmgdave's Avatar
Optima
Old 06-24-2012, 08:11 PM   #10
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Garnet red 2016 Camaro 2SS
Hmmmm, my grand daughter consistently beat me driving my L99 Camaro at the drag strip by 1/10th second no matter what I did. All you had to do in that car was crank it to 1000 rpm and pop the brake and let it shift itself in S mode. I finally realized that she weighs 100 lbs and I weigh 200 lbs. Proof positive that each 100 lbs is worth 1/10th second....lol. So, moral of the story, go on a crash diet!
SOLD: 2016 Camaro 2SS, Garnet Red Metalic, 8A, NPP, Nav, Sun Roof, upgraded silver wheels, lit door sills, Ash gray interior.
Now driving a 2017 Silverado, Red Hot, 5.3, regular cab, short bed and lovin it. Waiting until later this year to buy a Z16, C5...it's hard to wait.
Previous Performance Cars:
1966 Chevelle SS 4M 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto
2002 C5 Corvette 6M
2006 Corvette Auto
ParisTNDude is offline   Reply With Quote
Old 06-25-2012, 01:15 AM   #11
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
yeah...I could lose a few alright...lol.
Besides that, I thought of the seats, and sound deadner.
I think I'll remove the sound deadener, but I like the seats. Maybe the bumper reinforcements and door beams will add up to some weight.
2012 ZL1
Old 06-26-2012, 09:02 AM   #12
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
found some numbers on stuff that isn't visually obvious.
Front and rer bumper reinforce...50 lbs
tire inflator etc.....6 lbs
windshield washer tank, pump etc...4lbs
floor sound deadener...12 lbs
trunk carpet and well cover...15 lbs
headers instead of cats and manifolds...60 lbs
There's almost 150 lbs..
2012 ZL1
Old 06-26-2012, 09:55 AM   #13
DangerZL1
Carbon fiber or Al driveshaft? I haven't seen anybody list this mod.
Old 06-26-2012, 10:29 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It probably goes without saying, but removing door and bumper bars is not good for crash protection. All those things are there in order to protect the occupants. These cars are not designed to deflect impact energy - they're designed to absorb and pass them around the passengers. Enough of that boring stuff...
I'd look into some lightened rotors. I know these are two-piece and lighter already, but there may be some solutions out there to save a few pounds. I believe Pfadts' rear control arms are lighter than stock - not to mention stiffer and have better bushings.
Is there really that much to lose, without taking away from performance? I can't think of much that was added to ZL1, over SS, that could be removed without sacrificing something. Everything is either bigger for more strength or added to control cooling. I like the CF driveshaft, and there are CF trunklids out there. Beyond stripping more from the interior, I'm not sure how long it is until you really start turning ZL1 into a rear racecar...
Subscribed!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
