Emblempros
Old 06-26-2012, 10:47 AM   #15
RobRiot88
RobRiot88's Avatar
Drives: 2010 SS 6m, black on black.
carbon fiber doors will save you some weight. along with fenders and the hood. youll loose a little with the trunk. its pricey though. racing seats will help you loose 20-30 lbs per seat. but you have to consider with a carbon fiber front end if you get into an accident your kind of screwed unless you have a roll cage which weighs about what you dropped. smaller and lighter rims are the biggest way to ditch dead weight. focus on the rotating mass. like your flywheel, driveshaft and wheels. you can strip out the sound deadening material and your windshield washer reservoir and speakers and all that junk but unless your going to remove it all the weight loss is almost not even worth it. my best suggestion. get some smaller, lighter rims, and racing seats and dont race with a full tank of gas.
RobRiot88 is offline   Reply With Quote
Old 06-27-2012, 12:26 AM   #16
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Yeah, Its looking as if this isn't easy to do without major sacrifices. I just don't understand how on earth this car weighs so much. It doen't make sense. Its not that big.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 07-05-2012, 12:31 PM   #17
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
nobody mentioned swaping the air box to a CAI. I'll be doing tha soon and will measure the weights of both. I'm sure it will save 3-5 lbs. Plus you get more power and nmuch better looks under the hood. I'll go to a smaller windshield wiper bottle too.
Mr.R is offline   Reply With Quote
Old 07-05-2012, 12:36 PM   #18
BlAcK MaMbA SS
BlAcK MaMbA SS's Avatar
Drives: 2011 Chevrolet Camaro SS RS L99
Send a message via MSN to BlAcK MaMbA SS Send a message via Yahoo to BlAcK MaMbA SS
For sure replacing the Headers and the Stock exhaust will easily take off about 100 pounds or even more, depends with what you will be replacing.
CrushingAllMustangAndRiceOwners
BlAcK MaMbA SS is offline   Reply With Quote
Old 07-08-2012, 01:43 AM   #19
coanbread23
Drives: 2011 chevy camaro ss
Things you can do to drop weight without sacrifice of safety or comfort.
Battery -10 lbs
Exaust -30 lbs
Air box -5 lbs
Driveshaft -15 lbs
Flywheel -10lbs
CF hood -5 to 10lbs
CF trunk -5 lbs
Racing seats 25lbs per seat
K-Member -15lbs
Thats roughy 100-150 lbs of weight. If im off on the numbers please correct me. These are the only things i would consider doing because they dont effect the safety, or drivability of the car. Doing stuff like removing the AC, or sound deadening material or bumpers interior is a deal beaker.
Youre never gonna be able to drop enough weight to catch or be on par with the Shelby due to the IRS.
Combine this with a kenne bell and you have a ZL1 capable of killing a Shelby in all facets of performance
coanbread23 is offline   Reply With Quote
Old 07-10-2012, 01:06 AM   #20
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It's STRONG. Take a goooood long stare at the differential to give you some idea. I like to use the word "dense". Lots of stuff in a relatively small area...
Old 07-10-2012, 01:39 AM   #21
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
There's basically 3 types of weight on the car; static dead weight, unsprung weight, and rotational weight. The best type to reduce is unsprung rotational as that not only reduces a small amount of dead weight, it more importantly reduces the critical spinning weight that affects the handling and delivery of power to the wheels.
Unsprung is any weight not supported by the springs, such as the wheels, brake rotors, etc. I've read various estimates of the benefits but reducing unsprung rotational weight is about roughly a 10-1 ratio of benefit; reducing 1 lb of unsprung rotational has the same effect on performance that reducing 10 lbs of dead weight does.
So rather than spend thousands on carbon fiber body panels that might reduce 20 lbs of dead weight, spend those thousands on lighter brake rotors, lighter wheels, lighter clutch/flywheel, lighter driveshaft. Most of that isn't visible compared to a CF body panel but boy will you feel the difference.
Here is a link to my build thread where I've documented my quest to reduce weight on my 2010 SS without removing seats, sound insulation, gutting it, etc. The interior is stock.
http://www.camaro5.com/forums/showth...t=45165&page=2
The gross vehicle weight right now with a full tank of gas is about 3,685 lbs. All the numbers and mods with several dyno sheets showing the results of various mods are in the thread. A lot of it would be useful info for you and you get the added benefit of knowing that what I've listed works, without you having to do the research.
I'd be real interested to see what a ZL1 would do with about 100 lbs of unsprung rotational weight removed.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 07-10-2012, 01:58 AM   #22
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Originally Posted by gmgdave View Post
I changed out the battery yesterday. Smaller, 5lbs lighter, and easy. The only issue was reprogramming the windows.
I saved 30 lbs with my battery swap.
It is that big. You ever see it parked next to a Vette?
Try more like 40 lbs and that's with an off road X pipe. Hell the entire stock exhaust weighs 128 lbs. The only way you ate gonna lose 100 lbs is if you run open headers.
Hell yes, losing 66 lbs of wheel/tire made my car faster than all my bolt ons combined!
SUX2BU is offline   Reply With Quote
Old 07-15-2012, 07:13 PM   #23
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
interesting. Rolling stock weight first on list...
2012 ZL1
Old 07-20-2012, 12:36 AM   #24
cam fan
cam fan's Avatar
Drives: fast
Are there any specifically light weight wheels you guys suggest? It's my daily driver (only driver) but would love to shave some lbs for performance!
Magnesium was used on vette once but apparently were extremely dangerous (super flammable).
How much do the p-zeros + RS rims actually weigh?
cam fan is offline   Reply With Quote
Old 08-01-2012, 04:44 AM   #25
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Also curious.
remove badges... 1 lb.
K32 Camaro is offline   Reply With Quote
Old 08-01-2012, 12:53 PM   #26
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Stock 20" wheels/tires weigh in at 260.6 lbs.
Here is my daily driver set up geared more towards straight line performance 196 lbs
http://www.camaro5.com/forums/showthread.php?t=151258
Here is my daily driver set up geared more towards performance in the twisties 212 lbs
http://www.camaro5.com/forums/showthread.php?t=237217
Here are the wheel tire weights of all the wheels I have had on my car.
33.3 lbs 18x4 CTS spare w/ 185/50 18 M&H radial front runners
33.6 lbs 17x5 Weld RTS w/ 185/55 17 M&H radial front runners
44.5 lbs 18x8.5 F14 w/ 245/45 18 no name tires
48.2 lbs 18x11 F14 w/ 315/30 18 Hoosier drag radial
53.0 lbs 18x10 F14 w/ 285/40 18 Goodyear F1 Supercar
53.5 lbs 18x11 F14 w/ 315/40 18 Nitto NT05R drag radial
53.8 lbs 17x10 Weld RTS w 325/45 17 M&H drag radial
54.1 lbs 18x8.5 F14 w 255/50 18 Nitto NT420S
54.5 lbs 18x11 F14 w/ 295/40 18 Falken Azenis RT-615K
56.6 lbs 18x11 F14 w/ 335/30 18 BFG G-force T/A KDW
62.3 lbs 20x8 Stock wheel w/ 245/45 20 Pirelli
68.0 lbs 20x9 Stock wheel w/ 275/40 20 Pirelli
Old 08-02-2012, 01:17 AM   #27
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
look at the cts spare weight. Wow good front runner..
2012 ZL1
Old 08-02-2012, 01:55 AM   #28
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
They are for sale.
http://www.camaro5.com/forums/showthread.php?t=240180
