Old 06-24-2012, 02:00 PM   #1
Jstephen
Jstephen's Avatar
Drives: 2012 Camaro RS LT2 45th
Easy DIY License plate Mod
Ok, so like many, the thought of a license plate frame bring drilled into a bumper is a very scary thought. If you do not want to spend the money on a hid away, or need something in a pinch, you can actually use the factory one, in a slightly different way.
Tools: Drill, Screw Driver, Snips
Purchase Rubber Pads, Zip Ties.
Step 1.
Find the centerline of the factory plate holder. You will use this to line it us with the center of the car nose.
Step 2.
Flip the holder. That right down is up and up is down.
Step 3.
Purchase 4 rubber pads with adhesive tape at your local hardware. These are ones like you might use on the bottom of a chair, or electronic equipment. Adhere these, one each, to the 4 posts, used to attach original holder to the bumper. These pads will rest the holder against the bottom edge of the front fascia of the car.
Step 4.
From the top (originally bottom) of the holder mark a line at 1 ¼”. Draw this line across the entire surface
Step 5.
From the right and left sides, make marks on that line in step 4, at 1 ½” and 2 ½”.
Step 6.
Drill holes at these marks, slightly larger than the zip ties you have purchased. If you get larger zip ties in the future, drill larger holes.
Step 7.
Run the zip ties though the holes you have drilled.
Step 8. Attached the frame, by lining up the center line (step 1), with the nose of the car. Use the original frame cutouts, to position the frame on the grill. Complete the zip tie assembly and pull tight.
Step 9
Trim Zip ties
Step 10
Replace the license Plate
This took all of about ten minutes to complete and I hope you find it useful.
Jstephen is offline   Reply With Quote
Old 06-24-2012, 02:16 PM   #2
Jus1dab
Jus1dab's Avatar
Nice! Wish this was around before they put holes in my bumper.
Jus1dab is offline   Reply With Quote
Old 06-24-2012, 02:42 PM   #3
midnighter
Drives: nothing
I have my original bumper cover w/ drilled holes but have found it doesn't look bad after installing a painted to match plate frame to make the plates look smaller.
Old 06-24-2012, 09:38 PM   #4
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
I just used two toggle bolts to hold mine in. No drilling and it took about 2 minutes.
My Build Thread
http://camaro5.com/forums/showthread...=1#post5036900
Maureen@Rodgers Chevrolet...The best prices and customer service period!!(734)676-9600
Gen5Diy.com.....http://www.gen5diy.com/
Wretched Motorsports..www.wretchedms.com/
Pedders USA
...http://www.peddersusa.com/
bajamoon is offline   Reply With Quote
Old 06-03-2014, 12:55 AM   #5
ender2664
Drives: 2016 2SS
Will you marry me?
ender2664 is offline   Reply With Quote
diy, frame, license plate holder, plate
