Old 06-24-2012, 03:48 PM   #1
tnspd
tnspd's Avatar
Drives: Camaro ZL1 (BERT)
Any ZL1 mods for HP that do not need a Tune
So from what I have been reading are there any ZL1 mods to gain some HP that do not need a Tune. This is rediculous! Everyone I read says you need a tune.......
tnspd is offline   Reply With Quote
Old 06-24-2012, 03:51 PM   #2
DangerZL1
Drives: Accord
There's LPE's CAI that says no tune is required, but the HP numbers haven't been published for it.
DangerZL1 is offline   Reply With Quote
Old 06-24-2012, 09:52 PM   #3
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
I put just a K&N filter in and made a small difference. I'm waiting for the CAI with no tune. Lingenfelter said +20hp over the phone but I want to see the results before I pay $600 for it.
Mr.R is offline   Reply With Quote
Old 06-24-2012, 10:17 PM   #4
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Why is it ridiculous?
You would feel more comfortable running to lean or to much timing for the boost or extra heat your creating .....Tuning is for your engines safety!
2012 and 2013 are examples of what the future holds.......14 and 15 will be unbelieveably tough :(
ADM PERFORMANCE is offline   Reply With Quote
Old 06-25-2012, 07:33 AM   #5
tnspd
tnspd's Avatar
I understand it is for the safety of the engine and I have no problems with tunes from the right shop but you would think that putting on a cold air, the cars system would learn it and adjust accordingly without needing a tune. JMHO.
Old 06-25-2012, 11:16 AM   #6
DangerZL1
Drives: Accord
It would be great if the ECM could adjust the paramaters, but the OEM tune it is designed to only operate in a specific window. I've seen graphs where a CAI picked up 40+ RWTQ. I think we'd be asking too much to have the ECM handle the scaling automatically.
Old 06-25-2012, 11:51 AM   #7
Mr.R
Mr.R's Avatar
One would think the ECM would have a tolerance of +/- 5% so that's about 20-25 RWHP
Old 06-25-2012, 01:55 PM   #8
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Tolerance? A sensor value is what it is. The ECM can't magically create it's own values for a given input and ignore what it truly reads. Not legally anyway. If I push a #3 on a calculator I expect to get a 3 on the display and not whatever the processor decides to give me. The EPA will never allow manufacturers to do this or else emissions standards wouldn't mean a thing and there would be no need for computer controlled engine management systems nor would any car meet modern fuel mileage standards. Not being a jerk guys but you really should invest some time in EFI 101 and learn what each sensor is, the value scale and type of signal it transmits and what the software in the ECM does with the information. You'll have a whole new outlook on what these tuners actually do and the amount of time they invest in providing the products that produce more power safely and still allow you to LEGALLY pass annual inspection. Not to mention its far more fun to actually know how your car works and what's going on with your modern computer controlled hotrod.
RoketRdr is offline   Reply With Quote
Old 06-25-2012, 04:48 PM   #9
thespymaster
thespymaster's Avatar
You can bet in the 14 MY + , the might be locked out from re-programing!
Of course the aftermarket industry will have a fix for it!
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
Old 06-25-2012, 05:02 PM   #10
8cd03gro
Drives: 2005 STi corn fed
Weight reduction doesn't require a tune
But really, especially with forced induction engines, AFR's can be very touchy. You can typically get away with some exhaust stuff, but power is going to come from either making the engine more efficient by freeing up more flow hot or cold, increasing boost, or cooling the intake charge. Any of these are going to require a tune to take full advantage of. If you don't want to void your warranty with a tune, just work on taking advantage of the power you have. Lighter wheels may be a good option.
8cd03gro is offline   Reply With Quote
Old 06-25-2012, 05:12 PM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Pulley down might not require a tune?
I don't know how much boost is being created stock. But the computer should be able to handle the fuel and air adjustments as long as the boost is safe and injectors can keep up.
I'm guessing here. maybe somebody can clarify?
Old 06-25-2012, 06:35 PM   #12
RoketRdr
RoketRdr's Avatar
Stock boost is 9psi and the limit is 12psi with the secondary boost control. Once it see's higher boost than that it will open the by-pass and bleed off the excess boost. If you run a pulley to get higher than 12psi you must have a tune or it will just keep bleeding off the pressure. You also have to pull the vacuum line off the "P" valve and cap it so you can make over 12psi without it bleeding. But even running boost below 12psi it would be best to let a tuner write a tune to optimize the additional air volume because it affects the fuel tables. But yes...the ECM with a proper tune can handle the AF adjustments fine. Its the fuel system that will become a problem once high horsepower levels are reached. Some tuners have already figured out those limits and developed packages to handle the issues.
Old 06-25-2012, 11:07 PM   #13
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Where is the bypass? I'll just unhook it now and save time.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 06-26-2012, 09:22 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I understand there is a tool Lingenfelter makes in order to unlock the factory limit. I read it in GMHTP I think. I think that was ADM's 'V pulley, intake, tuning article.
If you go to a reputable shop, like one of our Sponsors, you'll be just fine. You get what you pay for, though. I definately wouldn't go anywhere that doesn't do a lot of tuning on your specific car.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
