| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2010 Camaro - Bone Stock (for now) Join Date: May 2010
Questions about installing a cam in an l99
I have pretty much decided I an going to put a tsp vvt-3 cam in my car. I am looking to do the install myself, but all I can find is ls3 installs, which I can use most of, but I am concerned about the vvt stuff. Does anyone know of a writeup on this?
I am also going to do the oil pump while I am in there. As well add reunions, out yella terra rockers, any suggestions here? I already have a 3600 stall, anything else I need to order? Thanks in advance for any and all help!
First Camaro:1984 Black Z28
Second Camaro: 2000 Black Z28 Current Camaro: 2010 IOM 2SS I guess it all started with the trip home from the hospital as a newborn in my dad's 1969 Z28 |
I also have HP tuners, and do my own tuning. As well as a CAI cold air. I doubt either of those matter, but figured I would try to get as much information out add I can.
![]() Drives: C6 Z06 Join Date: Feb 2012
As long as you're gonna rip the heads off might as well convert it to an LS3.
The TSP VVT cams require replacement of the lifters....gotta rip the heads off. Their AFM cams work with the existing lifters |
Is there an advantage to doing the ls3 conversion? I can't really find a compelling reason.
#5 | |
Hot Sauce
Drives: 2013 Crystal Red Tincoat SS/RS Join Date: Jan 2010
To get rid of AFM which can be turned off with a hand held programmer.
Fear is temporary,regret is forever
![]() 2SS,Crystal Red Tincoat,9.5 Bravado Wheels w/Continental Extreme Contact DWS 275/40 x 4 |
#6 |
when they dynoed my car, they zeroed out the advance on the cam, and got 452 rwhp. just changing the phaser tables added hp all across the board.
Lots of goodies, 464 rwhp, 404 rwt.
#7 | |
But you can only do that if you replace the lifters..... The standard lift on a an LS3 cam is .55 inch. It depends on how much power you want to make.....but the L99 engine concept was developed for fuel efficiency not power. |
#8 |
From what I was reading, it didn't seem that any ls3 cams where making much if any more power than the vvt-3, can you point me at an ls3cam to look at? I really want to make add much power as I can, and still keep it moderately streetable.
#9 | |
I think with the vvt-3 (TSP cam right?) the lifters have to be replaced (heads come off) so you're deep into a conversion anywho. |
#10 | |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
If you have any long term plans of power... like forced induction, ls3 conversion will be the way to go.
If you plan on staying cam only with a stall then the vvt3 is pretty much rock solid. Here's what a mid sized cam with LS3 conversion sounds like. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
When people talk LS3 conversion they can be confusing. The best way to describe it is in 2 portions, AFM/DOD and VVT. If doing the TSP VVT-3 cam you will be doing the AFM delete which includes the lifters and related components. If at some point in the future you decide to use a non VVT cam the change is the same as changing any cam there would be no reason to pull the heads again. In doing this cam, dealing with the cam phaser is no problem, very simple in fact, just follow the instructions. All of the procedure you will need to follow is the same as an LS3 with the exception of the cam phaser, the cam bolt is never mentioned when changing the cam on the L99 but from what I learned is that it is also a TTY bolt and should be changed but as I said no instructions I've seen mention changing it, I did, If I remember right it is 30-40 bucks.
I can tell you the VVT-3 cam sounds great and runs real strong, you won't be disappointed. |
#12 |
It may make sense for me to just go ls3 conversion, as it could simplify the tunning. Since I will be doing heads any way. No I just need to hear back from the few vendors I reached out to and see what they say.
#13 |
Now you have me reading TSPs webpages for cams.......
If you poke the dynojet button on the top of the cam description it displays the dyno results. It looks like the VVT-3 is around 450 but the highest power LS3 cam made 560....according to their dyno charts....... It all depends on what make sense with the auto. |
#14 |
Interesting, what cam did you see had 560, that may be an for me.
#15 | |
This was on an LS3 Manual...... Serious lift! and serious power. You should just call them and ask them what is the most agressive cam that will work with an auto......including max stall. |
#16 |
I have an email in to them, add well add lethal racing, unfortunately neither company had gotten back to me yet. I was hoping to do this work over the forth of July week, but that may not be able to happen now.
#17 | |
I was able to trap 118 on an auto with his cam in 100F+ and 80-90% humidity. Very impressive cam. Remember you are an auto, so don't look at HP numbers. I was trapping 118 at like 420rwhp, faster than a lot of guys on here with 480-490rwhp.... It's all in the gearing and tune and no better tuner imo than Ted. You might want to start thinking about a new differential though. My differential survived 2 whole days after my cam install. |
#18 |
If you are gonna do the work yourself......don't crack the seal on the motor...the work gets too intricate.
You're really only gonna get top-end power from a cam anyway. Just buy one of those ECS supercharger kits....its total external bolt-on, easier than a cam swap, and doesn't really affect the driveability of the car at low RPMs........550 to the wheels. If thats too much $$...like $5K Then do gears and a tune first......gears will make your car quicker without a cam than a cam will without gears. Just a thought....cams have always disappointed me. |
#19 | |
![]() Drives: 2011 Dodge 3500 dually Mega Cab Join Date: Jul 2009
L99..... VVT cams vs LS3 conversion at the track. Fastest H/C combo.. TSP VVT-3 11.17 @ 121.42 Fastest cam only combo.... TSP VVT-3. 11.47 @ 119.62 Top 5.... 3 VVT/ 2 conv. Top 10... 5 VVT/ 5 conv. The fact LS3 conversions out number VVT cams 9 to 1 makes it even more impressive.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
#20 |
Camslambam: what happened with the diff? Did you just need the posi mod, or did you need an actual new diff?
Kaler: Did you install the cam yourself, and what cam did you go with?
| Thread Tools | |
