sjm autoprod
Old 06-25-2012, 09:43 AM   #1
coloeb
coloeb's Avatar
Drives: 2012 2LT/RS 6L50 automatic TF-3
Exhaust back pressure
First , Let me say that I am not the auther of the following. I found this while doing research on the effects of exhaust modifications. It covers some interesting ground.
Backpressure: The myth and why it's wrong.
I. Introduction
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Engines need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
II. Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
III. Backpressure and velocity
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
IV. So how did this myth come to be?
I often wonder how the myth "Engines need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
V. So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
It seems possible that going too large on this mod does have negative effects on performance. The question remains where can I find the optimum size pipe for my application? I am tempted to believe that GM has already figured this one out. Your thoughts on this ?
Its better to burn out , than to fade away.
coloeb is offline   Reply With Quote
Old 06-25-2012, 11:28 AM   #2
malave7567
malave7567's Avatar
Drives: 2015 Camaro 1SS
good read and great info. This is why I limit my small engine cars to 2" piping. See way too many small engine cars with 2.25"-3.00" and they not only sound like crap, but run worse because of it. Only car I had with 3.00" piping was my turbo rotary, but that could definitely keep the velocity of that exhaust moving with an increase to allowable psi.
malave7567 is offline   Reply With Quote
Old 06-25-2012, 03:37 PM   #3
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
So you're saying that 100% back pressure is wrong? I've been using this: http://kalecoauto.com/index.php?main...products_id=41
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Extendolator • SOLO Hi-Flo Cats and Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 07-04-2012, 01:00 AM   #4
coloeb
coloeb's Avatar
100 percent back pressure would mean you have no exhaust and your engine would not run. The purpose of the x pipe H pipe etc. is to equalize the pressure between the left and right bank of your engine. While it is part of the exhaust its not exactly what we are talking about here.
I have not read anything about the o pipe so I can not comment on it at all , sorry. I will admit I am a bit concerned when I see the term valve float. I will read up on it and post my thoughts later.
Old 07-04-2012, 01:07 AM   #5
coloeb
coloeb's Avatar
Ha Ha Ha very funny man .
Old 07-04-2012, 09:14 AM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Don't get too wrapped up in it. 2.25-2.5 is what these V6 engines like.
Old 07-11-2012, 02:44 AM   #7
samhardy2008
samhardy2008's Avatar
Drives: 2012 3.6 camaro
lmao that is awesome
samhardy2008 is offline   Reply With Quote
Old 07-11-2012, 06:05 AM   #8
HorsePower-Freak
HorsePower-Freak's Avatar
Drives: 2011 Camaro 2SS M6
Look....unless you are an ASE tech, have an exhaust flow bench/dyno in your garage, and have a PHD air velocity/fluid dynamics from MIT its all about LUCK. Doing research and getting the right parts to mix with the right setup and praying to the car gods it doesn't LOWER performance.
I appreciate the article and it was a good read, but where's the Hard Data to support this? Where are the dyno numbers, flow numbers, side-by-side comparisons? Give somebody a computer and the internet and they can be whatever they want to be, which is why I look for at least 3 references in any article to support calims. Just my opinion
Originally Posted by HorsePower-Freak View Post
I know when I punch the gas pedal it makes ma D!#* move, and since that's a muscle.....I consider it a muscle car
HorsePower-Freak is offline   Reply With Quote
Old 07-22-2012, 09:45 PM   #9
coloeb
coloeb's Avatar
I am a licensed Chief Engineer , with 30 years in my field. All my work is on Diesel engines , but the principles of exhaust are fairly straight forward. As I mentioned at the very begining of this thread, I am not the author of this write-up. That being said , I happen to agree with the author and his/her conclusions.
You are correct, that there are no dyno sheets etc. to back the claims made. You can however pick up a textbook and read about these concepts from the same sources your ASE certified mechanics learn from. Its basic engine theory!
The idea behind sharing the article here was help others understand some of the concepts of exhaust mods. You don't have to be an ASE certified mechanic to learn how an engine works.
Old 07-22-2012, 10:01 PM   #10
CAMARU
CAMARU's Avatar
Drives: 2011 2SS/RS/CGM/6M/Black stripes
Coloeb, you are right. Velocity is your friend. That's why I went with 2.75in pipes instead of 3in. If your pipes are too big the gasses pool inside of the pipe and back up the gasses inside the pipe thus increasing back pressure. It is simple physics. If I was running nascar and running wide open all day I would think bigger would be better. And dynos don't change physics.
CAMARU is offline   Reply With Quote
