JUICEDMOTORSPORTS
Old 06-25-2012, 01:56 PM   #1
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
USB quit working
My car has barely over 8000 miles and I rarely use the USB. I do have my wife's i-pod programmed on it as well as my cell-phone. So anyway...the other day I plugged in my phone charger to the USB and...nothing, I pressed auxillary on the radio and it said NO DEVICE FOUND. I tried it again later that day and NOTHING..its dead! Is it a fuse? how do I toubleshoot this? Need some help please.
S-eatin-grin is offline   Reply With Quote
Old 06-25-2012, 02:38 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
FIRST, I'd take it to the dealer.....and while your there, pirnt out and give them a copy of this TSB, get the part on the top and have them install it!
There was a TSB (Technical Service Bullitin) issued (PI0055B) that will address these issues. I have attached the TSB and at the top is the GM P/N that needs to be installed.
The following information was sent to me via:
Scott Settlemire - GM Global Headquarters
Cheryl Pilcher – Camaro Product Manager
Jeff Morris – GM Customer Service.
In the TSB PI0055B, you will find this info:
In the top in the CONDITION/CONCERN section......the 5th bullet, it states "intermittent device operation from one ignition cycle to the next" . This covers it and will solve other issues with the operation of the unit.
NEXT you need to determine the Hardware/Software version you have in your system and how you and the dealer will proceed.
In the next section down, the RECOMMENDATION/INSTRUCTIONS section gives you the inscructions on how to determine the HW/SW version. If your HW version is either a Cx (where the X stands for any of the C versions) or a DA you need to have them REPLACE the entire PDIM unit....hopefully this is where you are at. PRINT OUT THE TSB and take it with you when you go to your dealer.
PI0055B with GM PN#.pdf
There is a thread here that was started in 2009 and is still going....whe I had this same issue, I found the thread and it was 30 pages long, its up to 39 pages now, and still active....I read every page, and did my homework.....even the GM Service Rep was helping and was posting so that all the correct info was put out. I went to my dealer with this TSB, they ordered the part listed on the top of the TSB and my system has performed FLAWLESSLY ever since.
Here is a link to the thread: PDIM Softwear UPDATE
also attached is what your HW/SW window will look like when the proper PDIM is installed.
Old 06-25-2012, 03:19 PM   #3
S-eatin-grin
thanks SirNuke...I actually did read that just couldn't tell if actually applied to my problem. I just dread taking the car to any dealer...as you can tell it is heavily modded and I don't want anyone f-ing with it. Is it something that can be done without me having to leave it there?
Old 06-25-2012, 03:24 PM   #4
Sleez
Sleez's Avatar
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD
mine did that, had to have the pdim replaced under warranty.
Sleez is offline   Reply With Quote
Old 06-25-2012, 03:37 PM   #5
Sir Nuke
Sir Nuke's Avatar
When I had mine done.....I had the tech VERIFY the problem and told the service manager the PDIM needed to be replaced, they ordered the part, and VERIFY yourself that they order the P/N thats on the top of that TSB.....when you get the call that its there.....then I made an appointment to get it installed.....I made mine FIRST THING so i would be the first in line....I was in and out in about an hour and a half....I sat there and watched TV and drank their coffee and ate donuts.
Old 06-25-2012, 04:21 PM   #6
S-eatin-grin
sounds like a plan...thanks again!
Old 06-27-2012, 10:36 PM   #7
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Mine quit working at one point. Took it to dealer and they found the USB had come loose inside the console. Easy fix and updated PDIM at the same time.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
