| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
Another Paint issue, this time its on the Doors
I noticed last week that the door edge, on the close side has paint chipping off. At first, I thought someone had opened the door and hit a white car or something white, but when I looked close I could tell the paint is just flaking off. Its all up and down the edge, on both doors.
I called the body shop manager at the dealer I bought it from, and set-up an appointment to bring it in. She tried to tell me over the phone that usually happens when someone opens the door and hits something. I assured her this was not the case, and made sure she understood it has in no way came in contact with ANYTHING! I hope she got the point that I am not to be messed with on this issue. We shall see Thursday. If it was something I had done out of shear stupidity, I would take my lumps, but its a legit issue. Guess I will be buying some door guard strips after I get it back fixed. Anyone else having this issue???
2012 Ashen Grey Metallic 1LS
...and the trees are all kept equal by hatchet, axe, and saw............RUSH KC Chiefs fan since 1994 / ST. Louis Cardinal fan since 2001 / Dale Jr. Fan since 1999 |
Anabolic Connoisseur
Drives: 2012 Camaro 2SS/RS LS3 - 2007 Tahoe Join Date: Sep 2010
Wow that sucks man. I will have to check mine for sure. Post a pic please
![]() Drives: 2011 yellow 2ss Join Date: Apr 2012
Hey I have the same on the bottom ledge of my doors and I know I didn't hit anything there or that is also impossible to "fling" debris there with my wheels but hey they call it "road rash" go figure but like you I'm not going to take it lying down. We need to get GM to own up and correct and I think the only way to do it will be in numbers.
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
Thanks Brandon. Its good to see someone in the CS department out here at the tip of the sword. I am confident right now that the dealership will take care of this issue. I expect to see allot of people chiming in on this thread as they check their own doors. Pretty sure I am not an isolated car effected by this. I will keep you informed.
#6 |
Could you post a pic of the area chipping?
#7 |
I will post pics later tonight. Its 100 degrees outside right now and its all the way down in the parking lot at work.
#8 |
ok.. i still need to remember to check my doors. will be on my to-do list this evening
#9 |
Bumblebee1961
Drives: 2012 Camaro SS Transformers Edition Join Date: Apr 2010
I don't have pics and am at work in Russia but my 2012 has a paint issue on the drivers door edge at the very top of the door.
I will get pics as soon as possible. Mine is not chipping yet but the paint looks like it was run off until it dripped. ![]() Then about halfway down the drivers door under the mirror there is a thin spot looks like a fish eye. I will contact the dealer after I get back as I also have a problem with the Transformers Stripes and the left front headlight. The stripes I do have a picture of.
Good bye 2010 Little Bee
, Hello 2012 Big Bee .Mods: SLP Blackwing Cold-Air Induction and Loud Mouth 2 axle back exhaust. ZL1 side skirts with carbon fibre wrap. |
#10 | |
![]() Drives: 2012 Camaro 2LS yellow/black Join Date: Jul 2012
Little bubbles along the crease on the inside of door. I noticed a few the day I bought it, dismissed it as an imperfection. Then a month later, noticed more bubbles (not sure if more formed or was there from the beginning), and a speck of paint had flaked off. What's underneath is the soft gray primer paint. I hope this isn't caused by rust, maybe just a manufacturing imperfection. Should I just put touch-up paint on it myself or ask the dealer to verify this isn't rust forming? jimblist at zzz gmail zzz com |
#11 | |
#12 |
I took my Camaro to the dealer.
Luckily, my problem isn't rust. Rather, car doors are bonded with epoxy, something like Liquid Nails, then painted over. This epoxy on my car is flexible/bendable, maybe it failed to harden entirely. So the paint tore in little spots. Passenger door's epoxy is also flexible but its paint is fine (less slamming of that door of course). I talked with a painter and I decided to just apply touch-up paint myself rather than sanding down the original paint (some tearing will keep happening anyway because how it's made). I'll have to monitor it in case if ever tears out to the very edge of the door, in that case, maybe professional repainting will be necessary. That is, right now it's just many pin-holes, it could turn into tears/rips. jimblist at zzz gmail zzz com |
#13 | |
![]() Drives: 93GMC sierra stepside/2012 SS Join Date: Dec 2011
I actually apply epoxy/sealer that is seen around the doors, hood and trunk but on a different vehicle |
#14 |
![]() Drives: SS/RS Join Date: May 2010
My paint job is also chipping on the side edges of the door and I also have not hit my door on anything. Sucks..
#15 |
Yes, it is probably a sealer epoxy rather than liquid nails.
So far the touch-up paint is holding. Thanks for the replies. jimblist at zzz gmail zzz com |
| Thread Tools | |
