Old 06-26-2012, 03:15 PM   #1
KD Innovations
Drives: 2012 ZL1, 2009 CTS-V
Here is the ZL1 New Era Intake
Here is the power coated intake with replacement windshield washer reservoir.
Gains have been very good, especially with relocating that huge stock windshield washer rezzie out of the way with something more reasonable.
We will be headed to the track this week again for more testing.
KD Innovations is offline   Reply With Quote
Old 06-26-2012, 03:19 PM   #2
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
All I see is a red X, can you e-mail the picture to
thomas.savu@barksdale.af.mil
Thanks!!
BoostedX2 is offline   Reply With Quote
Old 06-26-2012, 03:21 PM   #3
charly_rock
charly_rock's Avatar
Drives: soon => ZL1 #1512
charly_rock is offline   Reply With Quote
Old 06-26-2012, 03:31 PM   #4
DangerZL1
Drives: Future ZL1 Owner
Thanks for the pics. It looks good. Do you have another pic showing the entire unit with the K&N attached?
DangerZL1 is offline   Reply With Quote
Old 06-26-2012, 03:48 PM   #5
KD Innovations
Working on the finished product instal pic. Hope to have it today. This one is going on Aaron's car.
Old 06-26-2012, 04:05 PM   #6
jaggedx
Drives: Lots of stuff plus a 2012 Black ZL1
Good gains? Do you have any numbers? Are you using any tuning mods?
jaggedx is offline   Reply With Quote
Old 06-26-2012, 04:25 PM   #7
KD Innovations
Gains are good. With this alone and a tune we ran 121.85 mph in the 1/4. This was a bit slower but the only video I have.
Old 06-26-2012, 04:36 PM   #8
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
are there gains to be had without tuning. How can I get a tune where
I live there are no shops that do that
CAM....ZL1 is offline   Reply With Quote
Old 06-26-2012, 09:45 PM   #9
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
New Era intake gained 11 rwhp on the stock tune, and 31 rwhp with tuning. If you dont have a tuner in your area, we offer remote tuning with hptuners software. The 1/4 mile trap speed mph achieved with this intake speaks for itself on how efficient it is.
mike@newera is offline   Reply With Quote
Old 06-26-2012, 11:52 PM   #10
gbosh
Drives: 2012 ZL1 Camaro
Take the pan off the bottom of the car and put a regular hood on the car cause you don't need down force for drag racing. All the stuff for down force adds aerodynamic drag! Does anybody want down force on the front end when drag racing? Not needed. When drag racing the idea is to transfer weight too the rear and make the front as light as possible. Try it you might like higher trap speeds.
gbosh is offline   Reply With Quote
Old 06-27-2012, 12:10 AM   #11
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Ummm....wrong. The hood extractor is just that. An EXTRACTOR. It removes heat build up from under the hood that's generated by the super charger and the front stack. The frontal air now quickly moves through the stack and out from the hood with no resistance removing heat. Without the extractor you have...resistance. The pan on the bottom has very little to do with downforce and was designed to channel air for cooling. Hence the reason why it has NACA ducts directing air UP and doesn't span the length of the car. And downforce does NOT create drag. Especially on a car that has a belly pan and is low to the ground. Ironic that DRAG racing involves the nose of a car pointed at the sky and creating DRAG because it lost its aerodynamic properties with all the air trapped underneath like a scoop. The lower the car is to the ground (downforce) the more aerodynamic it becomes and the less drag/resistance that's exerted on the body. You know...Bernoullis Law. The whole reason why airplanes fly and race cars are seeking MORE downforce to REDUCE drag? Better go back to school. Try it...you might like it.
RoketRdr is offline   Reply With Quote
Old 06-27-2012, 12:36 AM   #12
RoketRdr
RoketRdr's Avatar
Will we possibly be seeing this intake in carbon fiber?
Old 06-27-2012, 05:07 AM   #13
DangerZL1
Originally Posted by RoketRdr View Post
Ummm....wrong. The hood extractor is just that. An EXTRACTOR. It removes heat build up from under the hood that's generated by the super charger and the front stack. The frontal air now quickly moves through the stack and out from the hood with no resistance removing heat. Without the extractor you have...resistance. The pan on the bottom has very little to do with downforce and was designed to channel air for cooling. Hence the reason why it has NACA ducts directing air UP and doesn't span the length of the car. And downforce does NOT create drag. Especially on a car that has a belly pan and is low to the ground. Ironic that DRAG racing involves the nose of a car pointed at the sky and creating DRAG because it lost its aerodynamic properties with all the air trapped underneath like a scoop. The lower the car is to the ground (downforce) the more aerodynamic Hit becomes and the less drag/resistance that's exerted on the body. You know...Bernoullis Law. The whole reason why airplanes fly and race cars are seeking MORE downforce to REDUCE drag? Better go back to school. Try it...you might like it.
You're being a bit harsh. Actually both of you are right. The hood extractor prevents unwanted lift from air entering and building up under the hood which reduces lift and it also aids in cooling. The belly pans reduce turbulence under the car without negatively affecting cooling. Also, downforce is created by aerodynamic drag (friction) and the weight of a car. If the rear spoiler is creating 150 lbs of downforce at speeds above 150 MPH, it is doing this by causing friction as the car moves through the air.
Old 06-27-2012, 10:41 AM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Just so I'm clear:
I haven't noticed preliminary base line runs, but I suspect you're A6 was running around 115-117. After tuning, this intake picked-up from 6-8 MPH? I'm not questions - I'm only asking for clarification
Thanks
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
